Author Topic: Oil Tank  (Read 338 times)
Offline ViniToo
Oil Tank
« on: October 05, 2023, 04:02:10 PM »
Is the smaller lower fitting on the back of the oil tank for a breather hose that just vents to the ground?
Offline Lucien Harpress
Re: Oil Tank
« Reply #1 on: October 05, 2023, 04:14:24 PM »
Experts will be along shortly, but as I recall the smaller tube connects to the rear of the engine block, while the larger one vents to atmosphere.  What year is your bike?
-1970 CB750 K0
-1980 KZ1300
-1976 Yellow GL1000
-1965 CA77 "Dream"
-1997 Valkyrie
-1975 Velosolex
Offline BenelliSEI
  • 1969 cb750
Re: Oil Tank
« Reply #2 on: October 05, 2023, 04:41:26 PM »
Year really matters. Major differences in the venting systems…..
Offline newday777
Re: Oil Tank
« Reply #3 on: October 05, 2023, 05:34:24 PM »
On what bike? (Should be in the question)
Stu
My current rides
Prior bikes....
Re: Oil Tank
« Reply #4 on: October 05, 2023, 06:44:49 PM »
...what he ^^ said...
Re: Oil Tank
« Reply #5 on: October 05, 2023, 08:39:44 PM »
That should be connected to the spigot on the rear of the crankcase.
Offline ViniToo
Re: Oil Tank
« Reply #6 on: October 06, 2023, 06:27:47 AM »
Sorry, dumb not to mention the bike. 1975 750k. It is the one that connects to the back of the gearbox. I did not have that this way and it spewed oil all over the rear of the bike when I rode off for 15 mins plus.. It did not do this as I had it running in the garage or even on a small trial run around the neighbourhood. DOH!!! It seems all good now. Should this have clamps on it? Thx for the replies.
Offline newday777
Re: Oil Tank
« Reply #7 on: October 06, 2023, 06:45:12 AM »
Good that you got it fixed. No clamps should be needed if the hose is not out of shape.
Stu
My current rides
Prior bikes....
Offline willbird
Re: Oil Tank
« Reply #8 on: October 06, 2023, 08:50:36 AM »
When I redid my K2 back in the early 1990's I used the 3/8 or whatever size rubber hose from the auto parts store for that line (pretty sure it was that one) the Honda non synthetic engine oil and the heat involved turned the line into bubble gum and 3-4 weeks after I got the bike on the road it sprayed oil all over the rear tire and everything else in that neighborhood.
