Author Topic: Forum subsections?  (Read 20245 times)
Offline gearsoup
  • Maine, USA
Forum subsections?
« on: October 07, 2023, 03:55:20 AM »
The layout of this forum perplexes me. Why have just (essentially) one dumping ground for new threads as opposed to a more structured layout?
Body/Trim
Brakes
Carbs
Engine/Exhaust
Electrical
Wheels/Tires
etc
etc
Too much work to make that possible?
Current Project: CB750-K6 (hoping for OEM look)
Future Project: CB750-K8  (likely go wild on this build)
Offline newday777
Re: Forum subsections?
« Reply #1 on: October 07, 2023, 05:10:04 AM »
Body/Trim
Brakes
Carbs
Engine/Exhaust
Electrical
Wheels/Tires
etc
etc
I haven't seen that on any of the forums I've been on in the past 14 years. Have you to give examples of how they are set up?
Stu
My current rides
Prior bikes....
Offline gearsoup
  • Maine, USA
« Reply #2 on: October 07, 2023, 05:10:22 PM »
vintagehondatwins.com as one example, see attachment
Offline Gordon
  • 750K1, 550K2
« Reply #3 on: October 14, 2023, 10:16:25 AM »
The Tips & Tricks section is split up into specific subsections like this, because it's already known exactly which subsection each topic should go into, and if you're looking for info on a specific topic you can more easily find it that way.
The main Tech forum is not split up into subsections for a few different reasons.  One is that the person in need of help won't always know which area their topic should go and would very often choose the wrong one, so we'd have to move topics around too often.  Also, topics may originally be started in the correct section, but it turns out it's actually something else, or it falls into multiple categories.  Then what?
Another one is that there just aren't that many active users here at any given time, and it's a lot of extra effort to click through multiple sub-forums just to check on what few new threads there are.  Many people won't bother to check all of them, so a lot of posts will be largely ignored.  I can't remember for sure because I've been on this forum for over 20 years in all its different iterations, but I believe we tried something like that for a while, and it just didn't work.
This forum has been around for a very long time, and a lot of different things have been tried over the years.  When considering the available resources for the forum and the needs of this community, what we have now is what works best.
Offline gearsoup
  • Maine, USA
« Reply #4 on: October 14, 2023, 11:41:11 AM »
Ha, fair enough!
