Author Topic: Paintless Dent Repair in Ontario, Canada.  (Read 1431 times)
Offline BenelliSEI
  • 1969 cb750
« on: October 07, 2023, 10:18:37 AM »
The tank on my Sandcast cb750 has a couple of shallow dents, but the paint is not cracked. I’m looking for a magician to push them out so I can just rub down the original finish and then clearcoat. Anyone in Ontario, Canada know such a person? Thanks! John D.
Offline Prospect
Re: Paintless Dent Repair in Ontario, Canada.
« Reply #1 on: October 09, 2023, 08:22:26 AM »
I'm also looking for the magician. Have the same dent on my wrinkle tank.
Current Bikes
1969 CB750  Sandcast #256
1971 CB750K1
1972 CB750K1
1975 CB400F
1975 GL1000 Goldwing
1954 Harley Davidson Panhead
1957 Harley Davidson Panhead
Toronto Canada
Offline BenelliSEI
  • 1969 cb750
« Reply #2 on: October 09, 2023, 08:28:12 AM »
Great….. let me know what you find. The guy that has my tank now is useless. After 8 months he just told me he needs a “special jig” to hold the tank while he is working it. It’s over $1200! I told him I would pick up my tank and make one……. Not going back there.
Offline flybackwards
« Reply #3 on: October 09, 2023, 10:52:32 AM »
Hope its not these guys..
https://www.dentmasters.ca/
Have a Kingston location..
Offline Kaze
« Reply #4 on: October 09, 2023, 11:33:53 AM »
I'm sorry I don't have the answer, but "just in case" you hadn't considered it yet... my suggestion is to broaden your search to include:
1.) auto-body shops. My old boss was the type of body-master you're all looking for -- the type of old-school guy who can remove dents with some cloth and a flat head body-hammer, by tapping the peaks of the dent to push it out, or pushing it out from the inside. He started in auto-body shops before opening his motorbike shop, so that's where I would look.
2.) auto-paint supply shops work with or know of professionals who deal with paint and body.
3.) some high-end motorcycle shops use sub-contrators for things they don't need all the time: Pin-stripers who still do them by hand, body-pros, etc. Our shop worked with a local Harley shop to do some projects. This is my last suggestion, because some shops are really tight-lipped about who they work with. Auto-paint shops have no reason to hide their good info.
I guess finally, you could also look up pushing out dents using an inner-tube and compressed air. (Several people here dislike this idea)
I don't know if he's still in business, but my old boss was Russ Foy, of Custom Classic Paint Works. Last number available is (425) 433-0712.
Ravensdale, Washington.
« Last Edit: October 09, 2023, 09:54:19 PM by Kaze »
One man's rubbish is another man's project.
Online scottly
« Reply #5 on: October 09, 2023, 11:50:09 AM »
I guess finally, you could also look up pushing out dents using an inner-tube and compressed air. But that's only if you like doing things yourself, or ... you know... if your bike isn't worth $15k.
DO NOT use compressed air to try pushing out gas tank dents!!! :o
Offline BenelliSEI
  • 1969 cb750
« Reply #6 on: October 09, 2023, 02:17:55 PM »
Gentlemen…… Thanks for all the good ideas! I actually started making a really strong jig with parts screwed to a solid chunk of 2 X 12” lumber. I machined up two alloy “plugs” that fit snuggly where the rubbers usually fit on the frame and a clamping arrangement for the tab usually held down by the rubber strap. Last piece (not made yet as I have to pick up my tank) is a bracket that will bolt in place of the petcock and then screw to the centre lumber. This should nicely lock down the tank. The main 2 X 12” piece should then be used to clamp it all in a big bench vice. Pictures to follow.
« Last Edit: October 09, 2023, 02:23:06 PM by BenelliSEI »
Offline jlh3rd
  • "just who gets to determine my needs?
« Reply #7 on: October 09, 2023, 03:07:11 PM »
you can look at this guy. He invented paintless tank repair.
I think he sells jigs and tools...
"alleged greed is usually a lazy person's opinion"
Offline Kaze
« Reply #8 on: October 09, 2023, 04:59:07 PM »
Scottly: I've only seen successful attempts using the inner-tube idea. What is the down-side of using this method? (Actual question)
Offline jonda500
« Reply #9 on: October 09, 2023, 09:08:43 PM »
You have little control over where the pressure will press - sometimes the distance between the front mounting points can increase. Apparently it is possible to fix this by carefully squeezing the sides back together with ratchet straps, but I haven't tried that, and don't know how well it would work,
John
A starter clutch thread:
Offline jlh3rd
« Reply #10 on: October 10, 2023, 03:57:10 AM »
PDR as a process dates back to the early 20th century. I really doubt this guy “invented Paintless Tank Repair” because that too has been going on for decades on motorcycles and autos.
if he's lying, i guess I wouldn't use him...
