Author Topic: 1972 750 front brake lever takes effort  (Read 361 times)
Offline kmschwarz
« on: October 12, 2023, 03:16:09 PM »
Updated with pictures
Shown is aftermarket master cylinder, drilled disc, and new brake line, rubber, usually snaked and hidden behind Bates headlight.  And a view of the bike itself.  I can lock the front in the garage and move the forks up and down.   Why is there a small brake line to the caliper, seems not rubber.
Having problems with my front brake.  It requires quite a bit of effort to brake, and (sorry, kinda vague) just doesn’t feel right.   I replaced the handle bar assembly with an after market replacement.  Replaced the piston with a new OEM part.  New disc pads, and the rotor was drilled Swiss cheese style.   My other bike is a HD ultra classic, and the brakes are robust and smooth (dual disc).  Is early disc brake performance that much different?
I have pretty much rebuilt the entire system, except the caliper body itself.   For bleeding, I use the little bottle with magnet, and bleeds clean and solid.   Had the bike since 1983.  Kinda at my wits end.   1972 750
« Last Edit: October 13, 2023, 02:12:52 PM by kmschwarz »
Re: 1972 750 front brake lever takes effort
« Reply #1 on: October 12, 2023, 03:25:44 PM »
A 70'brake will in no way compare to a 2000 brake but in itself is way better than any 60's brake
Offline newday777
« Reply #2 on: October 12, 2023, 03:26:23 PM »
If your master cylinder was emptied, you have to 1st bleed at the master cylinder banjo bolt, then the caliper. Old School term is bench bleeding the master cylinder.
Stu
My current rides
Prior bikes....
« Reply #3 on: October 12, 2023, 03:43:45 PM »
What is the size of the piston in the aftermarket master cylinder? The stock MC had a 14mm piston, and was on the large side. The larger the piston, the more effort it takes when squeezing the brake lever.
Online jonda500
« Reply #4 on: October 12, 2023, 03:44:45 PM »
What pads did you get?
My cb450 dohc twin leading shoe drum brake was noticeably more powerful that the early honda disc brakes!
John
A starter clutch thread:
