Author Topic: 750F1 Pad & piston jammed on front brake  (Read 1967 times)
Offline BenelliSEI
  • 1969 cb750
Re: 750F1 Pad & piston jammed on front brake
« Reply #25 on: October 21, 2023, 07:09:15 AM »
+2! Here are the pliers you must have. Order two sets so when the tip finally snaps off the first set, you don’t get stopped in your tracks! Cheap sh*t, but they work.
This set is from Vintagecb750.com
Offline Kelly E
  • Geriatric Hooligan
« Reply #26 on: October 21, 2023, 03:57:03 PM »
Definitely always have a backup set of those I've on my 3rd set.
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
« Reply #27 on: October 21, 2023, 08:26:53 PM »
It is a question of metallurgy and poor heat treat...
If they were made with good metal and given a good heat treat they would last, but then the company would have to charge a ton for them. Sometimes I don't mind paying for a good quality tool knowing I won't have to buy it again as long as I don't lose it or abuse it.
Offline scunny
  • don't call me expert
« Reply #28 on: October 21, 2023, 11:24:37 PM »
who loses tools?
I will now go into a corner and cry.
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline BenelliSEI
  • 1969 cb750
« Reply #29 on: October 22, 2023, 07:53:36 AM »
Mostly the problem is those clips are often seriously stuck in place and the pin ends are extremely small…….
Offline Kelly E
« Reply #30 on: October 22, 2023, 08:55:04 AM »
Now when the MC snap rings are really stuck I use a pick to try and to get each hole on the snap ring to move some before I get out the snap ring pliers.
1983 Honda CB 1100F
« Reply #31 on: October 22, 2023, 09:04:23 AM »
Soak it with strong vinegar to help dissolve the rust
« Reply #32 on: October 23, 2023, 04:23:44 PM »
 Cleaning vinegar is stronger, as is week killer vinegar.
  I just thinned a set of snap ring pliers to fit in the master cylinder. My set had a pair that matched so I sacrificed them to make one more usable.
  Some of the F brakes have an o ring on the OD of the piston side pad. I assume it's to keep dirt out. I removed one of mine, the pad seemed to hang up because it was there. I also got a new aftermarket piston that hung up in the bore of two different calipers, I spent a few minutes polishing it with red Scotchbrite pad while talking to a neighbor. Now it slides in and falls out with no seal.
« Last Edit: October 23, 2023, 04:48:16 PM by Don R »
Offline Kelly E
« Reply #33 on: October 23, 2023, 05:24:44 PM »
I thinned a set of long handle 90° needle nose pliers and ground tips into them to get out seized fork slider snap rings. They can be every bit as hard to get out as the MC snap rings. The next MC I take apart I'll get to try and see if my new Kowa snap ring pliers will fit down in there.
1983 Honda CB 1100F
