Author Topic: K4 repop right hand control switch has binding of the throttle tube  (Read 420 times)
Offline newday777
I was asked to install a new repop throttle switch control on a friend's K4 to replace the badly stained housing and bad starter button. He bought the switch, I believe from David Silver from the bubble wrap and label it had on it.
But the new housing binds the throttle tube when you tighten the screws as it should be, so much so the throttle won't turn. I've tried a couple of tubes and get the same results so it has to be in the housing slot where the tube resides or the casting being too short.
Anyone else run into this problem with a new repop switch?
Edit.... I just want to know if anyone else has run into this problem.
It's binding without the cables attached to the housing.
« Last Edit: October 22, 2023, 05:30:26 AM by newday777 »
Stu
My current rides
Prior bikes....
Re: K4 repop right hand control switch has binding of the throttle tube
« Reply #1 on: October 20, 2023, 03:26:12 AM »
id find the hang up,then decide if it just needs a little fine fettling like with a file or so?repro stuff may be not quite right but only a touch here or there makes it as good as genuine fit?
Offline newday777
« Reply #2 on: October 20, 2023, 03:33:16 AM »
I didn't ask about making it work Dave. I asked if anyone else has run into this.
I've been trying to grind out the housing with a dremel....
Stu
My current rides
Prior bikes....
« Reply #3 on: October 20, 2023, 03:40:09 AM »
ok cool,your on it then,sorry i couldnt answer your question directly.
Offline denward17
« Reply #4 on: October 20, 2023, 04:46:33 AM »
I just installed a switch on a K8 from vintagecb750 and did not have this issue.
Offline newday777
« Reply #5 on: October 20, 2023, 04:53:41 AM »
K7/8 use different switch assembly.
Stu
My current rides
Prior bikes....
« Reply #6 on: October 20, 2023, 05:04:54 AM »
If there is contact with throttle cable "tubing", adjust them might help, grind alu housing not.
Offline newday777
« Reply #7 on: October 20, 2023, 05:11:17 AM »
Per
It is not the throttle cables. It is the throttle tube without the cables, contacting the housing top section. Without the cables on the housing.
Stu
My current rides
Prior bikes....
