Author Topic: Engine Model Kits  (Read 3156 times)
Offline Sampsond
Re: Engine Model Kits
« Reply #25 on: June 10, 2024, 07:24:39 PM »
No, I have that part. Your picture shows the front of the cylinders. I need the rear part that the actual cylinder sleeves slide into. I will try to attach a picture. The part I need is on the far left and labeled "J". The part in your picture is on the far right and labeled with a "1" and a "2" with a circle around it.
I hope all of this makes sents.
Offline Killer Canary
  • Typical Bran Muffin
« Reply #26 on: June 10, 2024, 08:35:17 PM »
Front.
Kawi GPz900, H1
« Reply #27 on: June 10, 2024, 08:37:02 PM »
Back.
Kawi GPz900, H1
« Reply #28 on: June 10, 2024, 08:39:57 PM »
Left.
Kawi GPz900, H1
« Reply #29 on: June 10, 2024, 08:41:33 PM »
Right.
Kawi GPz900, H1
« Reply #30 on: June 10, 2024, 08:43:04 PM »
Top.
Kawi GPz900, H1
« Reply #31 on: June 10, 2024, 08:45:05 PM »
Bottom.
Let me know if you need measurements.
Kawi GPz900, H1
Offline Sampsond
« Reply #32 on: June 11, 2024, 06:42:33 AM »
Thanks so much! These pictures will really help. I can probably figure the measurements from the pieces that attach to it but if I  can't I'll post my needs here again.
Now to find appropriate materials to start construction.
Again, thanks for taking the time to send these pictures.
« Reply #33 on: June 11, 2024, 11:47:30 AM »
Keep us posted.
I'd like to see how you make out.
Kawi GPz900, H1
Offline Sampsond
« Reply #34 on: August 05, 2024, 01:26:26 PM »
I've finally given up on trying to duplicate the part. I had it all planned out in my head but when it came down to actually building something it got to be way to complicated.
I found the part I needed on e-bay and sent away for it. It cost me almost as much as I had payed for the rest of the kit so now the whole thing isn't such a bargain. :'(
« Reply #35 on: August 05, 2024, 06:04:03 PM »
Sorry to hear it. That blows.
If you'd had the part to borrow you could've made a mold from it and cast it in resin.
Kawi GPz900, H1
« Reply #36 on: August 06, 2024, 11:05:50 AM »
If kits are still being made you can sometimes buy the needed part contacting customer service and showing them your part problem... Even if you arent the original purchaser/owner they can help.
But if it is not in production, then things get tougher...
