Author Topic: 1976 Honda cb750K  (Read 30830 times)
Offline BenelliSEI
  • 1969 cb750
Re: 1976 Honda cb750K
« Reply #475 on: February 22, 2024, 03:23:09 PM »
Looking for something else today and found THREE of the chain oiler lock tabs I needed a week ago! I need to spend a few hours and do an inventory, and stop buying stuff I already have!
« Last Edit: February 23, 2024, 08:34:53 AM by BenelliSEI »
Offline willbird
« Reply #476 on: February 22, 2024, 03:48:33 PM »
Where do you buy a tea caddy?
I did a quick search at Maomart and they have smaller ones, but not ones made for 1/4 ounce of tea like these guys are rocking LOL.
« Reply #477 on: February 23, 2024, 07:13:24 AM »
My wife uses them for tea, I will steal one from the silverware drawer! Or go to Amazon...
https://www.amazon.com/dp/B0BYSDYPNZ/ref=twister_B0BYSC4NNZ?_encoding=UTF8&th=1
Offline BenelliSEI
  • 1969 cb750
« Reply #478 on: February 23, 2024, 09:33:06 AM »
I had a nice, new set of rubber intake manifolds on the bike. Yesterday I measured the “carb gap” between them and the air box connectors. Mmm, not enough space. Turns out they are for 1969-71. Ordered a K2/K6 set from vintagecb750.com. Not cheap, but came next day and look well made and pliable. Test fit is next.
« Last Edit: February 23, 2024, 09:34:45 AM by BenelliSEI »
« Reply #479 on: February 23, 2024, 10:40:14 AM »
I'd be interested in your assessment of those new boots. The ones from EMGO were junk, lasting about 2 years and self-destructing, usually cracking right at the clamps. This indicates insufficient fiber in the rubber compound itself, which is an expensive component. The EMGO versions used simple hydrocarbons and some silicone: this gave them a surface sheen, but inadequate temperature tolerance. They got hard from engine heat in a very short time, then shrank, which caused the cracking. Modern ones made with silicone elastomers could work, but they will be much softer overall (squishier) and will require a judicious screwdriver to prevent the clamps from cutting into them when new.
Offline BenelliSEI
  • 1969 cb750
« Reply #480 on: February 23, 2024, 05:46:55 PM »
I’ve not tried these before. No numbers, no stamping, no ID of any kind. Just the label on the box. Installing the clamps usually gives an indication. Will report.
Offline Galactica
« Reply #481 on: February 24, 2024, 10:40:45 AM »
I got carb holders and boots from Vintage.  They seem fine.  Time will tell.  I got several sets over the years for my Kawasakis from Vintage’s sister store, Parts N More.  Put tons of kms on this with no problems.
Offline BenelliSEI
  • 1969 cb750
« Reply #482 on: February 24, 2024, 11:49:45 AM »
Popped the intake manifold rubber on today and they fit really well. Lined up nicely and the carb gap measure up OK too.
« Last Edit: February 24, 2024, 01:17:40 PM by BenelliSEI »
Offline BenelliSEI
  • 1969 cb750
« Reply #483 on: February 24, 2024, 11:51:50 AM »
Finished up another carb this aft.
Offline BenelliSEI
  • 1969 cb750
« Reply #484 on: February 24, 2024, 11:55:07 AM »
-12C degrees this am, so not in a rush. These were decent to start with (thank you WideAWAKE), now really good. I’m out of those impossibly small split pins for the choke linkage rods. Need to pick up a package, next week. I need to remember to install them all BEFORE screwing down to the rack plate. So much easier.
« Last Edit: February 24, 2024, 12:06:46 PM by BenelliSEI »
Offline gearsoup
  • Maine, USA
« Reply #485 on: February 24, 2024, 01:20:35 PM »
Since the conversation has turned to carb boots; I just bought a set of OEM boots for my '76. They're still in the package, but I was a bit surprised at how stiff they are. Are they supposed to be rather squishy, or are they only supposed to yield a bit to moderate hand/finger pressure?
I've not yet taken the carbs off my bike, so these were bought under a "just in case" thought.
Current Project: CB750-K6 (hoping for OEM look)
Future Project: CB750-K8  (likely go wild on this build)
Offline BenelliSEI
  • 1969 cb750
« Reply #486 on: February 24, 2024, 01:27:52 PM »
“Yield a bit” is a good description. Sound fine. OEM from Honda? Good choice.
Offline gearsoup
  • Maine, USA
« Reply #487 on: February 24, 2024, 02:34:08 PM »
OEM from an eBay seller: https://www.ebay.com/itm/225990212404
Offline grcamna2
« Reply #488 on: February 24, 2024, 03:38:50 PM »
Well known quality seller with a great deal  8) 8) 8)
Offline BenelliSEI
  • 1969 cb750
« Reply #489 on: February 26, 2024, 05:36:05 AM »
Offline BenelliSEI
  • 1969 cb750
« Reply #490 on: February 26, 2024, 12:29:01 PM »
#2 carb done this am and then Gary showed up and ended up working on his TransAlp. His oil leak (very minor) is definitely coming from the rocker cover on the rear cylinder. Trying to decide if it can come off with the engine in the frame! Might be easier to ignore…..
« Last Edit: February 26, 2024, 12:30:57 PM by BenelliSEI »
Offline lash
« Reply #491 on: February 26, 2024, 01:54:30 PM »
Tell him to carry a paper towel in his pocket. What oil?! 🥸
Offline BenelliSEI
  • 1969 cb750
« Reply #492 on: February 26, 2024, 02:38:18 PM »
Agreed, but he’s looking for stuff to do. I suggested he change the change sprockets and chain on the Varadero, but he went home instead!
« Last Edit: February 28, 2024, 08:08:16 PM by BenelliSEI »
« Reply #493 on: February 26, 2024, 07:20:21 PM »
The real Honda OEM boots are hard. This makes them hard to install-remove, too! I use silicone grease on them and the engine's spigots, and sometimes have still had to employ a strap wrench to get them on.
Offline BenelliSEI
  • 1969 cb750
« Reply #494 on: February 27, 2024, 04:04:44 PM »
Spent a bit more time on the carbs today. I think I take too long on them, but I find if I get them just right my project bikes run great right from the start. We’ll see.
Offline BenelliSEI
  • 1969 cb750
« Reply #495 on: February 28, 2024, 02:03:53 PM »
Finished up the last carb today. It had the weirdest black, crusty staining in the bowl. Would not come away, so “borrowed” one from another set. Had to run some errands in town and stopped at 3-4 shops before I found a pack of cotter pins small enough to pass through the operating levers for the choke mechanism! They really are tiny.
CCS Industrial Fasteners, Peterborough, Ontario. The counter guys searched for quite a while and finally found a bag of them. They were so dusty they gave them to me. Great service!
Setting float heights and bench sync next time, and getting close to firing it up. Need to dig through my tub of manifold clamps and find a nice set.
« Last Edit: February 28, 2024, 02:58:53 PM by BenelliSEI »
Offline denward17
« Reply #496 on: February 28, 2024, 03:18:44 PM »
Good progress John.
You probably don't have riding weather for a few more weeks?
Offline BenelliSEI
  • 1969 cb750
« Reply #497 on: February 28, 2024, 08:06:59 PM »
Good progress John.
Dennis….. not in any rush. Winter came back here with a vengeance today. Might be a few months yet!
Offline BenelliSEI
  • 1969 cb750
« Reply #498 on: February 29, 2024, 12:46:24 PM »
Winter is back and the shop was +60F today. Started off by polishing a few of the original manifold clamps. Mindless work, that changes little, but really makes the finished product look right. Also replaced the dead oil pressure sending unit with another one I had in a bin. Easier to do this before the carbs go back on. It sends a ground and lights up the oil light. Hopefully it will go off too!
« Last Edit: February 29, 2024, 04:03:25 PM by BenelliSEI »
Offline BenelliSEI
  • 1969 cb750
« Reply #499 on: February 29, 2024, 12:50:54 PM »
Set the float heights and added in a fresh set of bowl gaskets. Cleaned out my small ultrasonic tank and was astounded at the amount of fine silt in the bottom. These carbs were pretty good looking to start with (I almost left them alone). I did them one at a time, rotating them regularly in the tank, for about 40 minutes each. Had the heat around 30C. They are spotless.
« Last Edit: February 29, 2024, 04:04:43 PM by BenelliSEI »
