Author Topic: 1976 Honda cb750K  (Read 26038 times)
Offline BenelliSEI
  • 1969 cb750
Re: 1976 Honda cb750K
« Reply #675 on: March 31, 2024, 04:14:57 PM »
The “brine” we’ve been spreading here seems even more corrosive than raw salt. I try and stay off the roads with the old bikes until we’ve had a few good rains…….
Offline BenelliSEI
  • 1969 cb750
« Reply #676 on: April 01, 2024, 01:42:04 PM »
    Forecast here is for more snow and rain starting tomorrow so what the heck. I took the K6 out for its maiden voyage. Did 58 miles on a sunny (chilly!) afternoon and it runs really well. 55-65 psi oil pressure on the run and +20 at a hot idle. I did notice an oil track that I hope is just coming from the cam cover. Will check it out tomorrow.
    The motorcycle had a weird pogo stick kind of bounce for the first 5-10 miles that seemed to disappear. The Bridgestone Accolade tires had zero miles on them when I picked up this bike. It spent 7-8 years in the back of my shop (covered, warm and dry). I wonder if the front tire had a “flat spot” that eventually pounded out? I also forgot to check tire pressures so it may be a bit hard too.
« Last Edit: April 01, 2024, 01:44:07 PM by BenelliSEI »
Offline denward17
« Reply #677 on: April 01, 2024, 02:25:49 PM »
Good first ride John!
Hopefully the oil leak will be easy to fix, may even cure itself with engine heat.
Offline grcamna2
« Reply #678 on: April 01, 2024, 03:58:26 PM »
Your bike is looking good John.
Offline BenelliSEI
  • 1969 cb750
« Reply #679 on: April 01, 2024, 04:13:39 PM »
Den….. in my experience, not much fixes itself. Fingers crossed.
Bill….. Thanks for that, it was a good first run.
« Reply #680 on: April 01, 2024, 04:59:55 PM »
Great oil PSI!
The 'pogo' feeling in the front end likely came from the inner dampers not yet being filled with the oil. If you check their level now, you will find them about 3.2 ounces low, which is the oil that stays inside the inner damper when the post-3/1972 forks are drained. That's why they are always so messy when the lowers get removed to replace a seal: they are stingy about giving up that inner oil!
This only happens with the forks after the 3/1972 change. The earlier dampers have external oil valving on the fork tube, which lets air into the lower end of the tube when you drain those - and that's why it takes a long time to drain those, as the later ones drain 'quickly' because they are still harboring about 30% of the oil. ;)
Offline BenelliSEI
  • 1969 cb750
« Reply #681 on: April 01, 2024, 06:13:09 PM »
Great oil PSI!
Mark…..Thanks for that, explains the “improvement” as I went along. I know I completely dismantled them and really scrubbed all the crud out so they were completely empty. Do you add the “extra” or just leave it?
« Reply #682 on: April 02, 2024, 01:06:17 AM »
Great oil PSI!
I have to pump the later (341) fork to drain the oil when doing an oil change.
I found that 175ml in each leg after oil drained and pumped out.
(Measured with fork completely collapsed without springs, 160mm from top.)
Completely dry,  more is needed, 60-70ml more/each if I have got it right.
Taking it apart for gator boots replacement (cheap aftermarket has very short life) or oil seal replacement I clean the lowers inside. Flush it with naphta.
Did that this winter on my K2-1975.
Remove the lowers with fender as one package easiest for me. (Wheel off before.)
« Last Edit: April 02, 2024, 02:31:16 AM by PeWe »
Offline Shtonecb500
    • Youtube profile
« Reply #683 on: April 02, 2024, 10:35:19 AM »
Bike looks super clean, congrats on the first ride and good luck with the minor issues.
73/74'' CB500/550 resto-mod - sold
75' 750f 91' cbr f2 swap cafe - mock up
74' 750 chopper hardtail - complete - sold
74' CB750/836kit - Black mix & match - daily rider - always tweaking
71' cb500 K0 survivor - complete
71' K1 - CANDY GOLD/BROWN Winton kit - in process
Offline BenelliSEI
  • 1969 cb750
« Reply #684 on: April 02, 2024, 11:33:23 AM »
Thanks! The oil was coming from the (missing) tach cable seal. I pulled out two old ones ages ago. Didn’t have one and forgot to order a replacement!! Got a few coming today…….
Offline grcamna2
« Reply #685 on: April 02, 2024, 11:40:19 AM »
John,did that storm come through your area ?
Offline BenelliSEI
  • 1969 cb750
« Reply #686 on: April 02, 2024, 01:12:13 PM »
Not yet. Very grey and windy. It’s coming.
Offline BenelliSEI
  • 1969 cb750
« Reply #687 on: April 02, 2024, 02:02:44 PM »
Den….. tightened up all the covers and have run it a few more times. Seems you were right and it has “healed”!
« Reply #688 on: April 03, 2024, 07:13:03 AM »
Bike looks great, nice job John!
Offline BenelliSEI
  • 1969 cb750
« Reply #689 on: April 03, 2024, 11:52:11 AM »
Thanks Steve. I’m really pleased with it; it’s running really well. I need to replace the tach seal and the rubber gasket on the gas cap (parts arrived today) and that’s about it. The side cover emblem I was missing came from Saskatchewan today too. Thank you Lyle, in the parts dept. of Shrader Honda! They’d been in their inventory for so long, he was extremely “friendly” with his pricing!
Of course it’s snowing hard right now(!) so it might not get out again, for a few days.
« Last Edit: April 03, 2024, 11:56:18 AM by BenelliSEI »
Offline grcamna2
« Reply #690 on: April 03, 2024, 03:04:14 PM »
These sidecover emblems will certainly be 'the icing on the cake' to your Very nice 76' John.
Offline BenelliSEI
  • 1969 cb750
« Reply #691 on: April 03, 2024, 05:23:58 PM »
Certainly a nice set! Stu also sent me the one I need, so these may get “put aside”.
« Reply #692 on: April 03, 2024, 08:49:42 PM »
Real diamonds made when  bike was made, not newer, right? ;D
Offline BenelliSEI
  • 1969 cb750
« Reply #693 on: April 04, 2024, 06:16:09 AM »
Per….. Lyle said these were in their inventory “since the late 70’s”!
Offline BenelliSEI
  • 1969 cb750
« Reply #694 on: April 04, 2024, 06:17:04 AM »
Won’t be riding for a few days. View out our kitchen window, this morning.
« Reply #695 on: April 04, 2024, 06:45:31 AM »
I had -8.5C this morning when I took the bicycle to my job 06:00.
No snow nor ice, yet. It can happen the first 10 days of April as the last 4 years.
« Reply #696 on: April 04, 2024, 06:46:06 AM »
Looks pretty but no thanks! Will be sunny and 86* here today....
« Reply #697 on: April 04, 2024, 06:47:16 AM »
Those must be extra correct with those labels then! ;)
Online newday777
« Reply #698 on: April 04, 2024, 07:07:57 AM »
Well I won't be riding until we get some good washing rain again as the storm you sent my way John started as rain yesterday and turned to heavy wet snow after sundown. Awoke to 6" this morning. This is looking out the shop door going up the hill to the upper section of the barn.
Probably a week according to the forecast so far before it rains enough to wash the salt off the roads and the mud dries up again....
Stu
My current rides
Prior bikes....
Offline BenelliSEI
  • 1969 cb750
« Reply #699 on: April 04, 2024, 07:44:15 AM »
Yep! Same here, we have at least 10-12” of heavy snow and our power is out. I have a generator big enough to keep the furnace and fridges running, so we are comfortable…….
