Author Topic: Another project-1976 Honda CB550K  (Read 16394 times)
Offline denward17
Re: Another project-1976 Honda CB550K
« Reply #175 on: January 26, 2024, 06:16:54 PM »
^LOL.... ;D
Offline denward17
« Reply #176 on: January 29, 2024, 02:28:46 PM »
Finished up the brake system on the front today, bled the master/caliper, will let it be for a while to make sure no leaks as all hoses were replaced as well.
Started looking at these carbs, they are next on the agenda.  Will be tearing them apart and cleaning, install new Honda o-rings, gaskets and such.
These are 087A with #100 mains, #38 pilot, and a D26 needle, in the 4th notch from top.  I took one carb apart.
They are dirty.....
Offline Mark1976
« Reply #177 on: January 29, 2024, 03:28:17 PM »
   Not a bad looking rack, (I've said that more than a few times in my life.) They'll clean up well.
Start with the end in mind...
Offline grcamna2
« Reply #178 on: January 29, 2024, 05:46:08 PM »
Lol  ;D
I like those carbs;they should clean-up good.
Offline denward17
« Reply #179 on: January 30, 2024, 09:52:54 AM »
Glad I decided to take them apart......Pictures tell the story, and judging by the parts inside and some of the screws/bend tangs, they have been worked on before.
This is the #1 carb, emulsion tube has quite a bit of crude, #2 carb main jet has crude.
Offline Mark1976
« Reply #180 on: January 30, 2024, 10:15:32 AM »
   Not bad, it'll clean up...
   But is it kehin brass?
   This was mine a couple three yrs ago. They cleaned up, but the mains and pilots were a complete loss... get good quality internals.
Offline denward17
« Reply #181 on: January 30, 2024, 10:21:48 AM »
Unfortunately not, Looks like Keyster parts, but not sure.  Your pic looks bad.
Offline Mark1976
« Reply #182 on: January 30, 2024, 10:38:04 AM »
 Believe it or not, they cleaned up worked like a charm. I may have changed out everything but the emulsion tubes. I don't remember, I'd have to go back to the thread and see.. The bike came out ok as well, sold it in like 2 days, got to ride it all summer and it returned every penny that went into it plus a little extra. A great little bike.
Offline denward17
« Reply #183 on: January 30, 2024, 11:10:17 AM »
^Nice looking bike..
Offline BenelliSEI
  • 1969 cb750
« Reply #184 on: January 30, 2024, 11:49:14 AM »
Dennis….. the lessons I have learned with carbs is spend as long as it takes and do everything. Doing the complete job ensures you only have to do it once. On my K6 the plan is to finish the rest of the bike, clear off a bench and then do the carbs. After I clean out the ultrasonic tank and load it with fresh “juice”!
« Last Edit: January 30, 2024, 11:50:50 AM by BenelliSEI »
Offline denward17
« Reply #185 on: January 30, 2024, 12:38:00 PM »
My carb bodies just got in the tank for a bath (Aircraft Simple Green and Dawn).
Do you use the same juice for the brass parts?  I was planning to, except clean juice.
Offline BenelliSEI
  • 1969 cb750
« Reply #186 on: January 30, 2024, 02:30:14 PM »
I have a case of old aerosol cans of a really strong carb cleaner, that somebody gave me. Strong stuff. I spray enough to fill a small container with the liquid and soak over night. Blow them out and they are spotless……
Offline Mark1976
« Reply #187 on: January 30, 2024, 03:07:54 PM »
Exactly what I do..... they'll look as good as new....
And then you can inspect for markings...if it's not kehin,  deep 6 it...
Offline denward17
« Reply #188 on: January 30, 2024, 03:45:34 PM »
I found out during disassembly that I had 1 pilot that was keihin of the same size, the rest is of unknown origin.  In another thread someone said the D26 needles were Keyster I think.
I checked with SoundSound Honda today, they say the needle set kits are unavailable, but I didn't inquire about the mains or pilots.
Offline denward17
« Reply #189 on: January 30, 2024, 03:47:01 PM »
John, do you clean the brass one carb at a time to keep them separate, or does that not matter?
Offline BenelliSEI
  • 1969 cb750
« Reply #190 on: January 30, 2024, 04:39:01 PM »
I usually lay out a huge egg tray and put everything back where I found it, but truthfully I don’t know why!
« Reply #191 on: January 30, 2024, 06:39:33 PM »
I feel like anything moving metal on metal wears as a mate and should be kept together...slides and carb bodies, jet needles and needle jets, float needles and seats.  But really, I am sure I have gotten stuff mixed up or had to replace something and I have no scientific evidence that this practice is important...But really, its just as Benelli said, you just don't want to have to dig into those carbs twice, especially on the 550.  Lots harder to work on than a 750 in my opinion.  And if some little overlooked detail is causing a carb problem, it can just be really hard to find.
Offline grcamna2
« Reply #192 on: January 30, 2024, 07:49:54 PM »
I brought a 12 pk./case of 12oz. cans of Berkebile 2+2 carb. cleaner(strong stuff)from Pa. when I moved out here to Ca. and I still use it occasionally for tough carbs.
« Reply #193 on: January 31, 2024, 07:20:48 AM »
I checked with SoundSound Honda today, they say the needle set kits are unavailable...
A lot of info here and good parts...
https://www.jetsrus.com/index.html
Offline denward17
« Reply #194 on: February 01, 2024, 08:26:03 AM »
Carbs cleaned, tops and bottoms cleaned up pretty nice, with a little dremel work and polish.
Brass is soaking in carb cleaner.....
Hopefully get back together next week.
Offline Mark1976
« Reply #195 on: February 01, 2024, 10:15:15 AM »
Looking better already ...
Offline BenelliSEI
  • 1969 cb750
« Reply #196 on: February 01, 2024, 11:34:35 AM »
What you end up soaking in?
Offline denward17
« Reply #197 on: February 01, 2024, 12:28:01 PM »
Local auto parts store, some aerosol Gumout carb cleaner.  It is not not great, I am going to have to scrub some of the brass with a nylon brush I think.
Offline denward17
« Reply #198 on: February 01, 2024, 03:52:32 PM »
Decided to mix up a concoction: Dawn, Simple Green Aircraft and a little white vinegar for the brass.
Put each set in a small plastic snack bag, put them in the ultrasonic cleaner for about 30 mins.
They turned out much better than soaking in carb cleaner for over a day.
Offline Mark1976
« Reply #199 on: February 01, 2024, 05:48:17 PM »
   If ya get stuck, I'm pretty sure I've got 4 kehin 38 pilots. I'll look... that aftermarket brass is just not worth the frustration.
