Author Topic: Another project-1976 Honda CB550K  (Read 53318 times)
Offline denward17
Re: Another project-1976 Honda CB550K
« Reply #50 on: January 02, 2024, 08:41:42 AM »
Touching up some frame paint today.  Had a lot of surface rust where the battery leaked at one time I suppose.
Took a wire brush to it on a drill, sanded and cleaned with dawn dish soap, wiped it off good with acetone, then sprayed all the crevices good with brake cleaner.
This is after 2 coats of VHT, will spray one more coat and leave it be.
Offline BenelliSEI
  • 1969 cb750
« Reply #51 on: January 02, 2024, 10:30:17 AM »
Looks good! I need to get back to work too!
Offline Mark1976
« Reply #52 on: January 02, 2024, 10:40:47 AM »
   Looks pretty good, give it a couple days to allow it to fully setup.
Start with the end in mind...
Offline denward17
« Reply #53 on: January 03, 2024, 05:10:23 PM »
Back end complete....moving on to another section...
Offline BenelliSEI
  • 1969 cb750
« Reply #54 on: January 03, 2024, 05:51:42 PM »
And looking pretty fine. Nice progress!
Offline grcamna2
« Reply #55 on: January 03, 2024, 07:18:29 PM »
+1  8) :)
75' CB400F/'bunch o' parts'
Offline Mark1976
« Reply #56 on: January 03, 2024, 07:24:36 PM »
   Great looking rear wheel, all the chrome looks great as well..l
Offline denward17
« Reply #57 on: January 04, 2024, 10:32:42 AM »
Was going to start on the front end next, forks need to come off.
But I can't seem to find a way to safely hold the front end off the ground whilst I work, so decided it would be easier with engine out next.
So I think that it is what I will do next, take the engine out for a good cleaning and fix some oil leaks.  While the engine is out, I feel like I can safely hold the front end off the ground to work there.
« Last Edit: January 04, 2024, 12:32:03 PM by denward17 »
Offline denward17
« Reply #58 on: January 04, 2024, 12:34:20 PM »
Had my seat recovered and picked it up today.
Seat cover came from gumtwo32 (Ebay) and looks nice.  https://www.ebay.com/itm/153929426581
Hardware and trim from David Silver.  Have about $250 in it, upholstery shop charged me $150.
I am pleased with the result.
« Last Edit: January 04, 2024, 12:36:32 PM by denward17 »
Offline BenelliSEI
  • 1969 cb750
« Reply #59 on: January 04, 2024, 01:09:08 PM »
Den….. Always a bit dicey. Here’s my set up. Seat looks really nice!
Offline denward17
« Reply #60 on: January 04, 2024, 01:47:22 PM »
^Hmmm.....nice lift, wished I had one, that would help
Offline exponent
  • Obsessed
« Reply #61 on: January 04, 2024, 02:06:32 PM »
I recommend a lower fork tree cantilever front stand. I had to put two 2x4s under the wheels to get everything high enough.
'78 550K 2106630
Offline BenelliSEI
  • 1969 cb750
« Reply #62 on: January 04, 2024, 03:57:25 PM »
Den….. before the lift I would back the bike into a corner of my garage. Two “eye bolts” screwed into the baseboard about 2’ out from the corner, for the straps. Jack the two by four up with a scissor Jack and slide in a pair of cheap Jack stands or even a set of milk crates. It worked very well and with the straps pulling down and back was totally safe.
« Reply #63 on: January 05, 2024, 07:51:21 AM »
I use a 4" ratchet strap attached to a large eye bolt screwed into the ceiling joist in the garage, works well.
Offline denward17
« Reply #64 on: January 05, 2024, 08:13:50 AM »
Yes, I did that as well, and will use it once I get the engine out.  My space is limited, it amounts to a 24x24 garage with an extra walled off workshop area in the front being 8x16, which is used up with tool chest and work benches, and of course my working area for the bike.  The 750 is stored in the main garage right now.
I'm almost ready to get the engine out, I'm having a hard time getting that top engine hanger bolt out, letting it soak with PB Blaster, will try some heat afterwards.  I may need to go buy a bigger hammer to.
Offline denward17
« Reply #65 on: January 05, 2024, 12:22:13 PM »
Went and got a 3lb hammer to help with the hanger bolt, it came out a little while later....finally.
Several soaks of PB blaster and alternating heat cycles directly on the bushing.  I also used some big pliers to hold the bushing while turning the bolt to help break it loose, needed a 24" breaker bar.
« Last Edit: January 05, 2024, 12:24:05 PM by denward17 »
Offline grcamna2
« Reply #66 on: January 05, 2024, 12:34:11 PM »
Wow !  victory over that thing  :o
Offline BenelliSEI
  • 1969 cb750
« Reply #67 on: January 05, 2024, 01:41:13 PM »
Well done!
Offline denward17
« Reply #68 on: January 06, 2024, 11:52:05 AM »
Engine out today, and started replacing some of the electrical connectors....parts from Oregon motorcycle parts...
Offline BenelliSEI
  • 1969 cb750
« Reply #69 on: January 06, 2024, 06:01:03 PM »
Some people on here advocate “leave well enough alone”. I like your approach. Nice work.
Offline Little_Phil
« Reply #70 on: January 07, 2024, 01:32:08 AM »
Had the same problem. Cycles of heat lubricant, time. Surprised I didn't break the cases as I used a small lump hammer on it.  Had to drill out one side, then more treatment and it moved a a fraction each heat cycle. But I won.
Well done.
Offline denward17
« Reply #71 on: January 08, 2024, 01:31:08 PM »
Front wheel/old tire off today, bearings out.
Now to clean up the hub and start on the new spokes and rim......and new bearings....
Offline BenelliSEI
  • 1969 cb750
« Reply #72 on: January 08, 2024, 02:57:22 PM »
Pulling off the old ones is such a pain! You have certainly become a “Jack of all trades”! Well done.
Offline denward17
« Reply #73 on: January 09, 2024, 01:08:01 PM »
Hub cleaned and ready for bearings.....then spokes/rim.  Hopefully tomorrow, bearings are in the freezer for install first thing in the morning.
Offline BenelliSEI
  • 1969 cb750
« Reply #74 on: January 10, 2024, 08:10:10 AM »
Were you able to “save” the retainer? I keep one on the shelves, just in case!
