Author Topic: Which carbs to connect to which port on a 2 port 750 K0 petcock?  (Read 556 times)
Offline Scootch
  • Someday I'll know what I needed to know years ago
After refurbish and working with the petcock on my bike I have come to realize that there seems to be quite a bit more to the lowly petcock than just a valve. I read some of the missives that have been written in this group. So one of my questions is in the title. Another one is if anyone has a "schematic" for the double outlet petcock? I'd like to understand how the fuel travels through it under the normal and reserve conditions.
Online bryanj
Re: Which carbs to connect to which port on a 2 port 750 K0 petcock?
« Reply #1 on: November 16, 2023, 03:57:01 PM »
Both outlets are connected inside the petcoke and will supply both mai, via the brass tube, and reserve, bypassing the tube.
It does not matter which pipe connects to which outlet
Offline The Lone Builder
  • "Still running against the wind"
    • Belfast-2-Belfast-By-Bike
« Reply #2 on: November 19, 2023, 04:50:42 AM »
Here are a couple of pics that might help.
CB750 K2 - From Belfast-2-Belfast
CB750 K1 - The less, said the better!
CB450 K1 - Stalled.
CB400F Supersport - Not Rusty any more!
Follow my journey through Africa @ http://Belfast2BelfastByBike.com
Offline Scootch
« Reply #3 on: November 19, 2023, 05:46:25 AM »
Thank you for the pics!
« Reply #4 on: November 19, 2023, 08:56:58 PM »
 What blew my mind was realizing the petcock to tank screws need proper washers to seal them or the petcock will leak through.
Offline Scootch
« Reply #5 on: November 20, 2023, 04:37:24 AM »
Yes exactly. Mine was leaking. PO had used copper washers and they were large. When I rebuilt I used the fiber washers. It still tended to leak a small amount. Turns out I needed to torque the screws a bit more. So far it is not leaking. Fingers 🤞
Online bryanj
« Reply #6 on: November 20, 2023, 06:01:50 AM »
Don, a lot of people have been caught out by those washers
« Reply #7 on: November 20, 2023, 06:18:30 AM »
 A lot of the replacement petcocks on ebay come with lock washers shown in the pictures, I suspect there are a lot of frustrated buyers.
Offline Scootch
« Reply #8 on: November 20, 2023, 06:39:42 AM »
That's why I learned quickly not to be penny wise and pound foolish. Get genuine Honda parts from places like South Sound Honda or Yamiya or equivalent. Saves in the long run.
