Author Topic: Oil Pump  (Read 2078 times)
Offline Floshenbarnical
  • Money pit enjoyer
Re: Oil Pump
« Reply #25 on: March 16, 2024, 11:41:08 PM »
Did you replace that #@$! shaft seal in between the 2 chambers? If not, the pressure comes out low, and lower when hot.
If your new seal on the pressure relief valve is too tight the pressure goes high, vice-versa if the new spring was not the right calibration - which I have often found in the "kits" sold to rebuild these pumps. I use the old spring, and if the pressure is still lower than 60 PSI at idle engine speed, have added thin shims under that spring to raise the bypass pressure a bit - but, this also involves dribbling more oil...
Dribbling right into the #$%*ing eyes! Lol
"All things change in a dynamic environment. Your effort to remain what you are is what limits you."
'77 CB750 SS
