Author Topic: CB500, 73, carb rebuild kit  (Read 593 times)
Offline gary p.
« on: November 21, 2023, 12:24:44 PM »
I took a chance, more on a whim, and ordered a kit from Walmart (where knew?).  The kits included brass, orings and a gasket.  The brass was rough.  Nothing was marked. The needle had a burr at the tip. The holes in the jets were ragged around the edges. (See photo). No idea if the rings were the correct size.  I’m taking it back for credit.
Where are y’all buying proper rebuild parts for the carbs?
Re: CB500, 73, carb rebuild kit
« Reply #1 on: November 21, 2023, 01:33:42 PM »
Confirm what brass parts you have, if OEM, most times they can be cleaned and reused.
As you just learned, aftermarket kits are worthless.
« Reply #2 on: November 22, 2023, 07:05:02 AM »
If you want O ring kits ask Nurse Julie a member, she can supply in ethanol proof viton
Offline Deltarider
  • I'm back
« Reply #3 on: November 22, 2023, 07:28:55 AM »
I can't believe the junk they sell overthere... I had to rub my eyes... really... I can't believe it!
CB500K2-ED Excel black
