Author Topic: CB750 cylinder compatability  (Read 673 times)
Offline timtune
« on: November 21, 2023, 01:05:07 PM »
I need a set of cylinders for my motor from 72. Just wondering if later years can also be used? Any help appreciated.
Offline newday777
Re: CB750 cylinder compatability
« Reply #1 on: November 21, 2023, 01:17:54 PM »
Yes through 78K will fit as well as 75/76F.
The 77/78F2 have some differences.
Stu
My current rides
Prior bikes....
« Reply #2 on: November 21, 2023, 06:43:25 PM »
If your 72 750 was built after 3/1972 it may have the 8 rubber 'dowels' around 8 short steel dowels in the inner stud holes.
If built before that, these will not be there.
Either type will work, but if yours doesn't have them now and your new cylinders have them you will have to change your gasket kit to the later type to get the seals. You can probably also buy them separately, but you'll need the little metal dowels, too.
Offline timtune
« Reply #3 on: November 22, 2023, 06:47:33 AM »
Thanks All so much. This is a great site with fine people!
« Reply #4 on: November 22, 2023, 05:01:28 PM »
I have a set (2 actually) of cylinders with pistons and rings that are bored 836cc size, if you're planning on going that far. The customers changed their minds about the big-bore AFTER I had them done(!). They are available for what I've got in them, with or without a cylinder swap in trade.
