Author Topic: Young Mechanics (working on your vehicle)  (Read 2311 times)
Offline Kevin D
  • SE Michigan
Re: Young Mechanics (working on your vehicle)
« Reply #25 on: December 20, 2023, 06:04:52 AM »
"Modern" engines have so much that can and will fail.
Fuel injection should not work if crank sensor give no signal. Engine will not even turn when trying to start it.
Same with cam pos sensor.
On top of this plenty of other sensors and crappy plastic valves that will brake and make engine to run like sh!t.
Air mass flow sensor common failer.
Ign coils have short life too, individually sitting on each plug in cavities getting hot in valve cover. Last setup branded Hitachi thanks to my CB750 experiences.
There are multiple brands making them.
Lambda sensors before and after the cat will become dirty and send wrong signals. Cheap version usually not correct.
Bosch is preferred.
Risk that a wrong AFR can ruin the catalytic converter too.
I have fixed my Audi 1.8T engine this year where mentioned sensors (+both lambda), coils(again), breather valve (1 of several, finally cracked wide open causing horrible idle).
Rear engine coolant temp sensor on the list when it give intermittent off in the logs.
Ordered and will be replaced a warmer day outside my garage.
I was worried that the catalytic converter with downpipe had failed due to wrong fuel mix. Sport cat with thicker downpipe from Milltek not cheap to get today. Car has a complete Milltek system from UK.
Car passed the annual test so OK.
Software VCDS and correct cable between OBD2 connector in car to PC collect all alarms.
Search some on Internet to verify the root cause.
Youtube videos show how to replace.
There are several forums with step by step descriptions how to fix common errors.
A carburetor car without ECU have not much that can fail.
The VCDS with cable have saved me lots of money.
I bought it initially to measure turbo charge while driving to verify the ECU software upgrade and crappy collapsing stock turbo inlet pipe, replaced by an alu pipe from USA.
Get all engine alarms within a minute. Car shops take lots of money for that!!
Wow!
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
« Reply #26 on: December 20, 2023, 10:17:43 AM »
Bosch is preferred.
Wow!
Edit: Engine will turn when cam pos sensor fail, but not ignite. My engine started at 2nd longer attempt. Car was home so no problem.
Same with crank sensor, needed a few attempt to start.
Those do not cost much, but can cause issues when far away from home.
Online jgger
« Reply #27 on: December 20, 2023, 12:12:46 PM »
Modern computerized/fuel injected cars do not like it when you press the gas pedal while attempting to start them. The start process is a program built into the computer. Also most don't require you to hold the key in the start position. Holding the gas pedal to the floor shuts off the injectors to keep from flooding the engine. This is weird for us old guys that came from carb and points motors.
Online BenelliSEI
  • 1969 cb750
« Reply #28 on: December 20, 2023, 05:29:25 PM »
Weird is right! The instructions for starting my fuel injected Honda Varadero are simple; DON’T touch anything but the starter button!
Online jgger
« Reply #29 on: December 20, 2023, 06:03:31 PM »
My F 150 has a time or revolutions count. It will crank on its own after you let go of the key, and it hasn't fired yet. I burned a fuse for the fuel pump, so it got no gas to start. It freaked me out when it just kept cranking. Made me feel really stupid by pulling the starter on the side of the road when all it needed was a fuse!
It is throttle by wire too.
« Last Edit: December 20, 2023, 06:05:04 PM by jgger »
« Reply #30 on: December 20, 2023, 06:25:39 PM »
AMEN!
I do have to say that my wife likes the new ones better, though.
I still have trouble remembering, as my motorhome is still old-school....then I get into the JEEP, which is halfway between: gotta hold the pedal open a bit, turn the key, then wiggle the tranny's shifter a little because the Neutral Safety Start switch is worn...always makes me smile. ;)
« Reply #31 on: December 22, 2023, 02:09:17 AM »
gimme a qjet or stromberg any day!i like cars where if you drop a spanner it ends up under the car on the ground,i like to be able to see the ground from above looking down past the engine!i care less for fickle engine light on so computer says no go,then it turns out to be like a sensor is caput but the actual engine is fine?old days tin foil wrapped around a fuse got you home,you need a laptop now if the glove box wont open?
Online jgger
« Reply #33 on: December 22, 2023, 08:05:58 AM »
FYI I bought the one from Harbor Frieght which was not Innova brand, and all the paper work inside the box said Innova. So for the same money as Innova I was able to get a better unit. I was also looking at the Innova readers before the Harbor Frieght purchase.
To answer your question, Innova is a solid company with good reviews/products.
« Reply #34 on: December 22, 2023, 08:24:40 AM »
Thx, good info.  There are at least 10 Innova units, won't buy the cheapest model.  I'm a firm believer in buying quality tools.
https://www.bestreviews.guide/innova-obd2-scanners?origin=google&google_params[matchtype]=&google_params[network]=g&google_params[device]=c&google_params[creative]=679662670956&google_params[keyword]=&google_params[adposition]=&google_params[adgroupid]=161770232348&google_params[campaignid]=20525732582&bs=&google_params[feeditemid]=99228397166&google_params[targetid]=dsa-2197066061652&google_params[loc_interest_ms]=&google_params[loc_physical_ms]=9028253&google_params[devicemodel]=&google_params[target]=&dest=0&sys_id=0|254&gclsrc=aw.ds&gad_source=1&gclid=CjwKCAiAhJWsBhAaEiwAmrNyq--8ADsVx5Em8ZpXabCIbioMZ1WPdu2HXysouaq43r2KRy7OZWfu7xoCKtQQAvD_BwE
Offline CycleRanger
  • No comment about being an
« Reply #35 on: December 22, 2023, 08:29:37 AM »
I have a USB-to-ODBII adapter and the Toyota Techstream software I use with an old Windows XP laptop.
It will read everything on my '02 Tundra and other Toyota vehicles.
It can do real-time monitoring and graphing of discreet sensors.
It will also work as a generic ODBII coder reader for any vehicle.
The USB adapter and software was about ~$35 from an ebay seller.
I've only needed it once on my Tundra to diagnose a failed O2 sensor.
I've used it many times on other peoples cars of various makes.
« Last Edit: December 22, 2023, 08:36:28 AM by CycleRanger »
Offline simon#42
  • liverpool
« Reply #36 on: December 22, 2023, 10:07:25 AM »
as its my job i have loads of them , the best ones i have found for the price are autel .
Offline jlh3rd
« Reply #37 on: December 22, 2023, 11:15:41 AM »
 Was gonna get a zurich from harbor freight a few years ago but they were out. I have a foxwell. It's. fine.
Autel has a good reputation.
And look up bidirectional capability. You might want that.
« Last Edit: December 22, 2023, 05:31:41 PM by jlh3rd »
« Reply #38 on: December 22, 2023, 11:27:03 AM »
gimme a qjet or stromberg any day!.....
My old Volvo 142 1969 B20 engine had one Stromberg. Horrible in winter getting ice plugs despite extra ethanol added in fuel that was the common additive wintertime. Starter spray a must have to start it, rev it since it had no idle due to the ice. If stopped, starter spray the only way.
Tricky when stopped in a traffic queue, open hood, spray lots of starter spray inside airfilter box, start it and keep it going.
Smell of ether mmmm ;D
The rubber diafragm cracked and reduced speed a lot. Good to be not far from home when that happened.
Gas stations had those parts when these cars were new and not that old. Since the late 80's no car parts.
Needle and needle jet had to be replaced. Special tool for needle jet. Vehicle inspection complained about the CO otherwise.
I finally replaced carb by a Weber 36/36. No iceplugs anymore and better response.
But I understand the feeling, old tech with no electronics that can stop you except for point when not serviced in time, finally not open at all.
Easy fix with a screwdriver. ;)
That car could hit things with real rubber covered bumpers and good ground clearance.
Reversed until stop, hitting thick wooden fence normal while parking ;D
My car today is 20 years old on the road tomorrow, but much newer tech than the old Volvo. Climate control is standard in most cars since mid 90's which help against condense in winter.
I can feel when summer arrive, cool air in ventilation. Other seasons warm air when colder than the temp setting of 20*C I very seldom change.
No rust yet as the old cars got after 10 years or earlier.
Bumpers covered by painted plastic covers as part of the car. Expensive to hit things or when getting hit by others.
Low "sport chassie" not always good.  I had problems with my back some years ago. Real pain to enter the car and leave it.
I promised myself next car will be a step (up) into the car.
I have not bought one since the later Audi's  and BMW's have expensive sucking quality with bad engines.
Stretching, jumping cam chains too common and other things.
My choice had been 4WD and 250-300hp.
Todays climate fraud that want to forbid petrol and diesel vehicles  keep me to use my old car.
Next car might be a survival vehicle, diesel that can run on any kind of oil and grease for long distances. Old tech might be the future thing.... ;D
Keep tool box in car with extra fuel...
« Last Edit: December 22, 2023, 12:40:57 PM by PeWe »
Offline Kelly E
  • Geriatric Hooligan
« Reply #39 on: December 22, 2023, 11:51:31 AM »
My wife drove a Volvo 164 for years. I have my 72' MGB/GT with no electronics at all, still running points. That car is dirt simple, dual SU carbs, 4 fuses and no power assist on anything. I can buy anything I need for it, even repair panels stamped on the original tooling. It will survive an EMP if it is shut off. 8)
I also have an old school mechanical injected V8 diesel truck for when it gets ugly. ;D
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
« Reply #40 on: December 22, 2023, 12:22:24 PM »
Volvo 164,  straight 6cyl called B30. Like a 4cyl B20 + 2 cyl.
160hp something was much over here early 70's.
« Last Edit: December 22, 2023, 12:37:35 PM by PeWe »
Online jgger
« Reply #41 on: December 22, 2023, 12:33:03 PM »
Here is the one I got from Harbor Frieght.
« Reply #43 on: December 22, 2023, 01:03:37 PM »
Hey Ranger...you are like the young dudes that need a laptop to work on it!!!
Offline CycleRanger
« Reply #44 on: December 22, 2023, 05:31:32 PM »
A hand held would be more convenient but I like having the Toyota software with all the bells and whistles.
« Reply #45 on: December 22, 2023, 07:28:30 PM »
I make Transistor Ignitions for those points, which stops their wear and makes them last forever. They work great in old Ford and Chevy engines, too!
I started out making them for 'show cars' where the cars had to have the points & condensor in the distributor to win top "all original" awards in the shows, but those parts are really hard to find now. So, I added a switch on them where it can run normally with the points (this also helps with the old dwell meters) for setting timing or running in shows, then they throw the switch to 'Electronic' to stop the wear. The cars get better gas mileage with the box, too. The switch also has an "OFF" position that kills the ignition completely by disconnecting the points, a nice way to prevent quick-thieves from 'hotwiring' an old ignition.
Offline simon#42
  • liverpool
« Reply #46 on: December 23, 2023, 03:48:59 AM »
Like this?
https://www.amazon.com/gp/product/B07M66RH77?SubscriptionId=AKIAIBX4MGJBG42TO3NQ&tag=productsbestrv210637-20&asc_source=google&asc_campaign=99800&asc_refurl=https%3A%2F%2Fbestreviews.com%2Fbest-autel-scanners&cid=99
the ones i have are a bit more advanced but that one would be good . a simple code reader is very limited you really need one that allows you to look at live data , fuel trims , air flow etc . some codes are not what they seem!
