Author Topic: CB750K6 No Electrical Power  (Read 928 times)
Offline M 750K6
Re: CB750K6 No Electrical Power
« Reply #25 on: December 06, 2023, 02:54:37 PM »
There is a jumper wire between black and brown or brown/white at front. Connectors in headlight bucket.
Visible in Honda diagram.
That will be missing if replacing the entire loom.
Gauges etc will not lit without it.
Aah, the headlight bucket looks like a nest of vipers! Thankfully, I mechanically labelled on disconnection and did the same in reverse. My tacho and speedo are lit. In the bowl, I do have one female side of a bullet connector that is unused, which I assumed would be indicators as running lights.
Online BenelliSEI
  • 1969 cb750
« Reply #26 on: December 06, 2023, 03:08:34 PM »
Well done Martin! You can check the oil and neutral light curcuits by simply grounding the wire that attaches to the sensors. With the key on, power is fed to the lamps. The switches deliver the ground on zero pressure and when in neutral.
Offline rotortiller
« Reply #27 on: December 06, 2023, 04:16:29 PM »
where does the package say what amperage they are?
On the back side.
Online HondaMan
« Reply #28 on: December 06, 2023, 05:03:23 PM »
Be advised about AGX (or, for that matter, any AG[other letters here] type of fuses: they are not vibration-rated: they are made for stationary applications (often called "appliance applications"). This means they will not stand up to physical vibration and shock while carrying current. Their tiny (skinny) portion of the element inside the glass gets very soft when carrying current near their rated load, and this is when road bumps then break the element. It then "blows" as if there was a short, and looks the same.
For a while in the early 2000s we were using upsized such fuses (like 20A in a 15 slot or 10A in a 7A slot) to try to prevent the hot-break scenario. It sort of works, but it also puts the wiring at risk if the current is actually higher than as rated for the wire size (15A or 7A, etc.). I repeatedly blew 20A and 25A main fuses in my 750 while riding and hitting potholes: not the best way to ride in rush-hour interstate-speed traffic! That's how I started using the modern ATC fuses instead.
The SFE (automotive-rated) fuse type had supports along the length of the element up to the edges of the narrowed area, or else it had a 'doped' section in the middle of the element that had more resistance than the whole length of the element, so it would concentrate the heating just at the very center of the fused link. Thus the rest of the length of the element was there to support the hot section. The AG(any letter here) type of fuse is a full-length-doped element, and can blow anywhere along its length. It also gets hot and soft all along the length.
That's the big-deal difference. ;)
Offline M 750K6
« Reply #29 on: December 08, 2023, 02:17:44 PM »
Engine's in and remaining wires connected up. Tell tales are back. 👍
Tomorrow I'll put the oil tank back on put some oil into the valve cover and tank, for it to settle, while I get on with the exhausts. I'm dreading that, I suspect it will be a 3 hands job!
