Author Topic: 5.5mm fuel line extention  (Read 613 times)
Offline KvilleRelic
  • Enjoying wrenching on my nifty 50 CB550 AKA Kzero
« on: December 10, 2023, 08:50:28 AM »
Well I shopped and shopped both online and in person and struck out. I need a barbed coupling for the Honda 5.5mm fuel line for a bottle feed setup, but could only find 1/4" OMG what a tight fit. I am afraid it will be pernament if I sucessfully join these 2 together. I even bought some Tygon 3/16" ID line in hopes to couple to the 5.5, but I cannot find a fitting that works. The struggle is real  :'( Thoughts?
D.
Braap Braap
Re: 5.5mm fuel line extention
« Reply #1 on: December 10, 2023, 05:31:16 PM »
I've used a 1/4" Tee fitting with some [plumber's] Teflon tape wrapped on the nipples to fill in the 5.5mm hose a little better.
Offline KvilleRelic
« Reply #2 on: December 11, 2023, 07:28:05 AM »
I've had the oposite issue because 5.5 fuel line is actually .21" and my 1/4" barbs are .25" .... very tight and hard to undo.
D.
Braap Braap
Offline KvilleRelic
« Reply #4 on: December 11, 2023, 11:17:47 AM »
I may have to do both recomendations ... use this 3/16" y (smaller than 5.5) in combination with Honda man's tip of adding teflon to make it bigger . Trying to make a fuel bottle to hang on a hook so I can keep tank and seat off while tuning carbs.
D.
Braap Braap
Offline newday777
« Reply #5 on: December 11, 2023, 12:36:22 PM »
How old is your fuel line? Maybe try heating it up a bit with a heat gun.
Stu
My current rides
Prior bikes....
« Reply #6 on: December 11, 2023, 03:56:52 PM »
 I've used a gas filter that has smaller ends that step up to bigger. It makes a good adapter between 5.5mm and 1/4"
« Reply #7 on: December 11, 2023, 05:37:02 PM »
I should probably mention that my 'tee' isn't a barbed-type fitting? I think it came from a plumbing store (or Ace Hardware, maybe?). It's brass, and the nipple ends are smooth. That's why I wrapped tape on them, so it would swell the hose a bit when sliding it on - and it's slippery. ;)
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #8 on: December 12, 2023, 04:20:15 AM »
I try to avoid teflon tape on fuel fittings. I have plucked remnants of teflon tape from the float needle seat/fuel inlet from more than one carb. Gravity feed is pretty forgiving, but a zip tie could tighten things up if necessary, especially for temporary test-n-tune purposes.  8)
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline rotortiller
« Reply #9 on: December 12, 2023, 06:11:50 AM »
If you want to stretch tight fitting Tygon heat it up and shove it over the barbed fitting.
Offline SanDogDewey
« Reply #10 on: December 12, 2023, 07:16:43 AM »
I used a tee from Ace hardware as well. Smooth, no barbs and it doesn’t leak. My fuel line are all new 5.5mm.
Offline Bodi
« Reply #11 on: December 13, 2023, 09:06:27 AM »
A lot of hobby shops have brass tube in many sizes, I just found a size that fits snugly and use that. Also got some (wild coloured) fuel proof hose to connect the carb air ports.
Offline KvilleRelic
« Reply #12 on: December 15, 2023, 07:47:47 AM »
I had never thought of hobby shops, great idea thanks.
D.
Braap Braap
« Reply #13 on: December 15, 2023, 07:17:16 PM »
I think that's where my tee came from.
