Author Topic: Look, squirrel! Or, how bike projects shift quickly; new CB750 K6 project for me  (Read 5922 times)
Offline gearsoup
  • Maine, USA
I've got a Vevor 30L ultrasonic, carb clear solution for the ultrasonic  (https://www.kmcarburetor.com/products/sc-20-ultrasonic-cleaning-chemical-1-gallon?_pos=1&_psq=sharpe&_ss=e&_v=1.0)
Also, I should be wrapping up my Vapor Blast cabinet this week  8)
Current Project: CB750-K6 (hoping for OEM look)
Future Project: CB750-K8  (likely go wild on this build)
Offline BenelliSEI
  • 1969 cb750
Perfect match. They’ll be spotless inside and out!
Offline gearsoup
  • Maine, USA
Well...looks like there's something missing here (I think).
Offline gearsoup
  • Maine, USA
What's interesting is that the pipes they offer for the "F" bike do have the bits and bobs I need.... ???
https://delkevic.com/full-system-to-fit-cb750f-super-sport-1975-1976-with-classic-straight-universal-muffler-and-stainless-steel-4-1-headers/
Offline gearsoup
  • Maine, USA
There's nothing on the frame or the overall design that leads me to suspect this was an F bike converted to look like a K. Is there any easy way to check to see if this motor is from an F bike? Or is it more likely that many years ago, the PO just ditched the collectors and clamps when they installed the 2 into 1 pipes?
Do you folks think I'd be better off returning the 4 into 1 kit that I have and getting the F model, or just buying the parts needed to make this set of pipes work? I suspect that (if I do have a K bike front to back) there are bolt holes that aren't going to line up at all.
« Last Edit: March 13, 2024, 09:25:35 AM by gearsoup »
You can identify your frame and engine number by using the guide at sohc4.net.
f you need clamps and split collars, clamps are available as a reproduction and a nice visual upgrade over rusty originals.  You will have to source the spit collars used, I think.
« Last Edit: March 13, 2024, 10:17:46 AM by seanbarney41 »
Offline gearsoup
  • Maine, USA
Good idea. Frame and engine numbers both line up with K6 expectations
Offline gearsoup
  • Maine, USA
Like these? https://4into1.com/chrome-exhaust-pipe-joint-cylinder-set-honda-cb750k-1969-1976/
Or these: https://www.vintagecb750.com/products/7/exhaust/109/gaskets-mounting-hardware
(I think the images below are what I need, based on looking at CMSNL)
« Last Edit: March 13, 2024, 10:42:24 AM by gearsoup »
Offline BenelliSEI
  • 1969 cb750
Those are what you need. The studs come out and they are held in by a Philips head counter sunk screw. I prefer alternates I buy locally that are stainless and use an Allen key.
Offline gearsoup
  • Maine, USA
Good call, I think my local hardware store will have those.
Jeez, hope I don't break any studs on removal. PB Blaster, some heat and proper torque, they should come out ok...... :pray
Offline BenelliSEI
  • 1969 cb750
Look like this….
Offline grcamna2
Look like this….
You've got a good bolt supplier John.
Offline BenelliSEI
  • 1969 cb750
Look like this….
Bill…. Bolts + is relatively new in Canada and I have a store only a few miles away. Fantastic selection and very knowledgable staff. If you look at the picture, they actually had the stock Honda length and also gave me 8 that were 6 mm longer. I cleaned out the threaded holes and was able to use the extra grip length. Great place.
Offline gearsoup
  • Maine, USA
Do you recall the pitch and overall length of those? I might just hit up McMaster-Carr, need some other items from them at the moment
Offline BenelliSEI
  • 1969 cb750
I think I bought a few extras, will look tomorrow and measure them up.
Offline gearsoup
  • Maine, USA
Eh, it's all good. I bought some from McMaster once I found the part on CMSNL, added on a few mm. Figure if they're too long and I can't chase the threads, I can always machine them back if needed.
Offline BenelliSEI
  • 1969 cb750
Good solution. I used a bottoming tap and cleaned out what was there and a bit more.The extra grip is reassuring.
Offline gearsoup
  • Maine, USA
Finished up my vapor blast cabinet the other day. My wife was skeptical about the whole thing, couldn't wrap her mind around why I wanted something like that. Well, the results speak for themselves, so she understands now  ;D
This was just a rough pass on some junk carbs I picked up to practice on, figured if I destroyed them it wasn't the end of the world. Upon total dissassembly, I'm fairly certain the left most carb is toast, the next one in is "maybe" (something heavy dropped on it at one point in its life).
Offline gearsoup
  • Maine, USA
Left most carb and the bowl (only blasted the bowl thus far)
Offline BenelliSEI
  • 1969 cb750
Amazing! That might be the cruddiest carb I’ve seen.
Offline grcamna2
Same !  :o  :D
Nice...I love vapor blasting!
Offline gearsoup
  • Maine, USA
So, good news and bad news
The good: I disassembled and vapor blasted the carbs and carb rack, they came out beautiful!  8)
The bad: "OEM" bottom brass was not OEM, it's aftermarket. The rebuild kit I have is Keyster from vintage750.com. The slide needle is OEM, so...yay? (It's set on 2nd clip from bottom, leave it be?)
I DO have a set of junk carbs (see my vapor blast photos above), but 2 of the carbs are absolutely nasty, the brass is....sketchy at best.  I'll likely just head on over to jetsrus.com and get what I need. Should I replace everything with OEM, or are some of the bras bits okay to leave? Just replace the jets?
Now, onto my second question:  Floats; set them to 26mm. Okay, but from where?
If I look at the service manual, it shows them using a gage, it appears to be resting on the outside lip of the upper body (Not where the bowl sits)
In some videos and pictures I've found, I've seen folks using card stock that fits between the float and the lip where the bowl meets. Which one is correct?
In the attached photos, ignore that the carbs are not tilted back. Having only two hands, I wanted to simulate the measurement process and take photos at the same time. When setting the floats, they will be tipped back properly (just enough to rest on the float needle)
