Author Topic: Honda Engine Paint  (Read 2023 times)
Offline Tracksnblades1
Honda Engine Paint
« on: December 20, 2023, 07:26:18 AM »
Just wondering out loud…whether Honda’s Marine offering is anywhere close…
I don’t have a Honda outboard to compare….
Gently Silver Metallic describes it pretty well…
« Last Edit: December 20, 2023, 08:50:17 AM by Tracksnblades1 »
Age Quod Agis
Offline jlh3rd
Re: Honda Engine Paint
« Reply #1 on: December 20, 2023, 09:32:20 AM »
Is that for engines?  heat and gas proof?
Wonder if it matches vintage bike silver.
« Reply #2 on: December 20, 2023, 11:05:20 AM »
It’s for Honda’s outboard engines. Honda Marine..
That’s the right questions. Just wondering if anyone had ever compared the color to the motorcycle engines…
Age Quod Agis
Offline Flyin900
« Reply #3 on: December 20, 2023, 12:18:25 PM »
I have used the Dupli Color engine enamel in the Aluminum colour it is CDE1615 in Canada and DE1615 in the US. It is the closest match to the original Honda paint I have found. If your doing the entire engine then no one will discern any difference from the stock colour. I have blended original painted engines with some parts painted in the 1615 aluminum and it is hard to tell the difference without really critical judgement.
When cured it is oil, gas resistant and good for 500F. If you hit that temp on a air cooled engine, you will have more problems than paint issues.
I have painted probably 20+ engines over the past 15 years with no issues. Again it's all in the prep work as any paint job is to the end result.
Here is a new engine primer product also from Duplicolor that has been around for about a year and I have used it a couple of times so far.
« Last Edit: December 20, 2023, 02:46:55 PM by Flyin900 »
1978 CB550K - Super Sport
1982 CM450A - Hondamatic
1982 CB900C - Custom
1983 CX650E - Eurosport
Offline BenelliSEI
  • 1969 cb750
« Reply #4 on: December 20, 2023, 05:33:58 PM »
+1 to Duplicolor. I’ve also used it a lot and it is an excellent product. They also make a “Filler Primer” which I used some years ago on a very corroded motor. Smothed it over beautifully and held up 100%.
« Reply #5 on: December 20, 2023, 06:30:22 PM »
I use the Duplicolor too, but in their color "Cast Coat Aluminum". It's a dead ringer for the OEM paint color..
Offline grcamna2
« Reply #6 on: December 20, 2023, 06:33:23 PM »
I like the CDE1615 'Flyin900', and it looks like it has fine metallic in it too !  8)
« Last Edit: December 20, 2023, 07:53:16 PM by grcamna2 »
Offline grcamna2
« Reply #7 on: December 20, 2023, 06:34:17 PM »
What Duplicolor # is it ?
« Reply #8 on: December 20, 2023, 07:35:31 PM »
I like the CDE1615 and it looks like it has fine metallic in it too !  8)
That’s what’s important to me.  The very fine metallic….
Makes the Honda connoisseur wonder whether it’s live or Memorex…..🤫
Age Quod Agis
Offline grcamna2
« Reply #9 on: December 20, 2023, 07:55:35 PM »
Here in the USA,I've looked for that CDE1615 but every time I think I found it,I've only ever gotten the non-metallic #DE1615..  ::)
Offline newday777
Stu
My current rides
Prior bikes....
Offline Flyin900
« Reply #11 on: December 21, 2023, 04:41:29 AM »
[/quote]
The US part number doesn’t use the C as I noted in the original post you drop the C from the part number. Likely for Canada they add the C for CDE1615 and the US no C as in DE1615.
I don’t see any metal flake in the colour just a bright sliver colour to my old eyes. :)
I will check out Hondaman’s report on the cast aluminum also yet I found the DE1615 the closest when doing a “blow in”. Blending old original Honda motor paint and painting only small parts or sections on the motor.
« Last Edit: December 21, 2023, 04:46:34 AM by Flyin900 »
Offline grcamna2
« Reply #12 on: December 21, 2023, 11:57:05 AM »
Duplicolor #DE1615 is a great match for Honda engine paint and it is definitely 'Non-Metallic'  :)
As I mentioned in another post above:I can't get that metallic version of it anymore.
I like the metallic version of it aLot.
Offline ADW
« Reply #13 on: December 24, 2023, 08:48:05 AM »
When I restored my 1979 CBX1000, I painted the VHT SP995 Cast Aluminum on the tach drive cover, and painted the cam cover with DE1650 Cast Coat Aluminum to get a "side-by-side" view of what each color looked like. Here's a photo of the tach drive cover on the cam cover.
I left the tach drive alone for just such an occasion as this, when someone would want to see the difference between the two side-by-side. I'm SUPER-glad I didn't use the VHT SP995 Cast Aluminum (tach drive)...the flake in it looks really "pimped out". Can't imagine how awful the whole engine would look with that color! The DE1650 is the one for sure. I painted the whole engine with it.
« Last Edit: December 25, 2023, 08:34:55 AM by ADW »
Offline jlh3rd
« Reply #14 on: December 25, 2023, 04:25:02 AM »
There's a lady who's deceased husband restored a cb 400F and she brings it to Barber. The engine is painted with a flake type silver which now appears to be the vht sp995.
Pimp is a good description.
Offline Ujeni
« Reply #15 on: December 26, 2023, 10:09:00 AM »
I used Duplicolor engine enamel for many of my restorations for years. Good stuff. Then I came upon POR15 engine enamel. A far superior product. I painted two oil pans to compare. I let them cure exactly to manufacturer specs. I could easily "key" the duplicolor paint. The POR15 engine enamel was undamaged after many attempts. It is an EXACT match for Honda's engine color (aluminum). Plus, you can spray it with a gun to get perfect coverage. I use it on all my engines now. I'm a convert.
POR15 Engine Enamel
Hope this helps folks out there.
Ujeni Motors
Sandcast #410
Sandcast #538 Watch the restoration!
Sandcast #6592 All original daily driver.
« Reply #16 on: December 26, 2023, 05:43:02 PM »
POR15 Engine Enamel
Sounds like ImRon…
Does your POR15 have the micro metallic in it..?
Age Quod Agis
Offline grcamna2
« Reply #17 on: December 26, 2023, 06:03:51 PM »
POR15 Engine Enamel
The link doesn't work for me.
« Reply #18 on: December 26, 2023, 07:10:45 PM »
POR15 Engine Enamel
https://por15.com/collections/topcoat-paint
Age Quod Agis
Offline BenelliSEI
  • 1969 cb750
« Reply #19 on: December 27, 2023, 06:29:33 AM »
POR15 Engine Enamel
Sam….. Thanks for this info. Discovered a Canadian Distributor which is even better. I’ll be using this on the S/C project for sure! Happy New Year!
« Last Edit: December 27, 2023, 08:14:22 AM by BenelliSEI »
Offline Rayzerman
« Reply #20 on: June 12, 2024, 01:00:42 PM »
Newbie to restoring a CB350F..... cannot tell if the engine is painted, looks like unpainted.... engine side covers/cases are polished. I'd like to stay as close to original as I can.  Thanks in advance.
Offline grcamna2
« Reply #21 on: June 12, 2024, 03:23:06 PM »
Do they sell the POR15 engine enamel in a rattle can also ?
« Reply #22 on: June 12, 2024, 06:01:55 PM »
The color Honda used on the engines looks like their aluminum castings. When the engines are not painted you'll see all sorts of marks, streak, lines, etc. of colors in the aluminum itself in most of the engines. The best of them (without paint) were the K7/8 cases, which seemed to have really good molds. The 550F were also quite good. The 350F engines I have rebuilt all got new paint because their general surface appearance had blemishes, especially the cases.
Offline Ozzybud
  • Honda Lover
  • Honda Lover
« Reply #23 on: June 12, 2024, 06:53:59 PM »
I use Duplicolor DE1615 Aluminum. It has a fine metallic just like original and Then i topcoat with urethane Catylized Clear.
Rattle cans never fully "cure" as they harden via Evaporation not chemical reaction. Gas will dissolve it 10 years down the road.
The Honda Cloud Silver is The perfect match but it is getting hard to find. The dupli color is a very close match and available everywhere.
1976 Z50A YELLOW
1970 CT70 BLUE
1971 CT70H ORANGE
1972 CT70H GREEN
1973 CL200 BLUE
1973 CB350F RED
1975 CB360T RED
1975 CB400F BLUE
1975 CB550 ORANGE
1976 CB750F RED
Offline newday777
« Reply #24 on: June 12, 2024, 07:03:56 PM »
Welcome aboard the forum
Yes Honda painted the cases.
Most of us use the Duplicolor EDE1615
Ceramic Aluminum Engine paint.
Very close match to original.
Stu
My current rides
Prior bikes....
