Author Topic: Don's 81 GS1100e Suzuki nearing good enoughness.  (Read 51309 times)
Offline grcamna2
Re: Don's 81 GS1100e
« Reply #151 on: January 06, 2024, 07:14:08 PM »
« Reply #152 on: January 06, 2024, 08:38:42 PM »
 I think it's a google thing. Anyway, it's this picture except I start it and let it idle. The clearcoat on the forks has yellowed and make them appear gold.
« Last Edit: January 06, 2024, 08:43:59 PM by Don R »
Offline grcamna2
« Reply #153 on: January 06, 2024, 08:53:02 PM »
Yeah  8)
I hope you have someone take a video of you smoking the rear tire  ;D
Online Kelly E
  • Geriatric Hooligan
« Reply #154 on: January 06, 2024, 10:15:13 PM »
Nice job getting it running. 8)
I soak the fork lowers in a tall skinny jar of brake fluid while I have them apart. It turns the clear coat to goo, then I wipe it off with an old toothbrush dipping it in brake cleaner. Saves a ton of sanding. To refinish I start at 320g and then 400g but only sand around the lower never the long way. It will look close to factory and is easy to touch up.
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
« Reply #155 on: January 06, 2024, 11:08:38 PM »
Wow!  Big change of forks between '81 and '82.  Leading axle is gone in '82 and black coated lowers with anti-dive, adjustable compression damping, 3 position pre-load and air assist
« Reply #156 on: January 06, 2024, 11:11:54 PM »
Looks like '81 is the same features just without the anti-dive and with the leading axle
Offline Leino
  • Not much of an
  • in drag racing since 2005
« Reply #157 on: January 07, 2024, 01:11:10 AM »
Big change of a lot of things between 81 and 82  ;D
Offline Leino
  • Not much of an
« Reply #158 on: January 07, 2024, 01:12:55 AM »
I have an early model head (80/81) if anyone needs a spare, not sure if I have the valve cover for it but I can look.
« Reply #159 on: January 07, 2024, 11:33:19 AM »
  It's 32*F here, I scouted a couple of dry streets and the city hasn't needed to salt yet. So, I took it for a spin. I could have warmed it up longer, I did a half mile or so before revving it much, it broke up a little over 5K rpm but improved as it warmed up. The last stretch of dry street saw 7K and it was clean then. Maybe it's not jetted for this air, and like Hondaman says, the valves and seats might need to break in a little after an extended rest.
  As expected, it out pulls my 836 by a fair margin.
  Now for a set of fresh tires. I have to give these old Dunlops credit for no dry rot, they're at least 25 years old.
 How many days until riding season?
https://motoloot.com/products/suzu-key-motorcycle-keychain
« Last Edit: January 07, 2024, 11:50:11 AM by Don R »
Offline grcamna2
« Reply #160 on: January 07, 2024, 01:10:06 PM »
What filters are you running in this cold ?
« Reply #161 on: January 07, 2024, 04:06:37 PM »
 I just pulled the pods off of the Rat Race 836 and used them I think they are Emgo, just mesh with a fabric in between. The K&N's that were on it are toast and they don't make them any more. I tried to soften the rubber in my magic rubber solution (wintergreen oil) and the ultrasonic cleaner but still couldn't get them back on.
 There aren't many good pod filters in the 44/45mm size, same size as the Honda keyhole carbs.  I'm finding some at APE, I'm not sure what type they are, ebay has a lot of china products, either the Emgo ones or there are some foam oval ones. Mine are baffled on the inside to try and straighten out the flow.
Offline grcamna2
« Reply #162 on: January 07, 2024, 04:57:16 PM »
I've got a very good used set of 51/52mm K&N oval pods,I removed them from my 83' GS750ES because I don't like pods. I went back to the stock airbox w/ K&N filter:better mid-range response.
« Reply #163 on: January 07, 2024, 07:47:48 PM »
Don, I am running the APE pods on my kz1000 with vm29's and they are a fine product, especially for the cost
« Reply #164 on: January 07, 2024, 11:05:04 PM »
I assumed as much but it's good to hear from someone that has a set. Thanks. I have a sweet set of velocity stacks but after dragster racing at a couple sandy drag strips, I quit using those.
« Reply #165 on: January 08, 2024, 04:09:30 PM »
 I checked the bike today and the floor under it is dry and clean. Finally, L0L! It's difficult to get off of it and not reach for the petcock, the old Hondas have me well trained.
Online Kelly E
« Reply #166 on: January 08, 2024, 06:57:22 PM »
Nice job buddy  8)
I'm still waiting for testing weather. By the end of the week we'll be down into the teens with big winds. Maybe I'll have to get one of those Snow Bike kits for the GS.  ;D
1983 Honda CB 1100F
« Reply #167 on: January 09, 2024, 08:53:18 AM »
 We got big snow and road salt, so I'm parked too. It's unusual for me to be satisfied this soon with a project. I do still need tires.
  I had a volt meter on the elderly battery yesterday it didn't occur to me to start it and check the charging voltage. The battery was freshly charged and showed 13 volts, I turned the lights on for a minute and it went down to 12.6. I'll call it good.
« Last Edit: January 09, 2024, 08:58:21 AM by Don R »
« Reply #168 on: January 09, 2024, 08:56:49 PM »
 I've been online tire shopping, the Bridgestone BT46 and Michelin road classics are about the same price. J&P Cycles isn't far from here, so I'll likely order from them.
 Edit: the Dennis Kirk web site is easier to use for tires I'm leaning towards the BT46, Bridgestone came on them and are about $100 less than most others.
  Jegs has the K&N oval black rubber air pods (KN RU2450) for about $150 delivered and Summit has the chrome ones (KN RC2454)for $180 with my discount. I guess they do still make them, just $$. I have no idea why these parts are so difficult to find, the search engines suck.
« Last Edit: January 09, 2024, 10:01:32 PM by Don R »
Offline grcamna2
« Reply #169 on: January 09, 2024, 10:07:02 PM »
Don,I hope you get it all nice,then leave the rear tire on,to do for last:burn it up w/ a smoke show in 2nd gear before replacing it  ;D
The neighbors may think something's on fire  :o   You could tell them the throttle jambed-up  ::) :D
« Last Edit: January 09, 2024, 10:23:14 PM by grcamna2 »
« Reply #170 on: January 14, 2024, 04:23:44 PM »
 Last night I was doing the biggest smoky burnout ever, and then I woke up. I checked the temp and it's 16*below zero F. I pulled up the covers and went back to sleep.
Offline grcamna2
« Reply #171 on: January 14, 2024, 05:01:36 PM »
I see.  8)
« Reply #172 on: January 15, 2024, 05:34:57 AM »
Heat wave here at my place in Michigan. only -5 F on the thermometer. !
« Reply #173 on: January 15, 2024, 09:08:34 AM »
 The heat wave moved my way, it is also -5* here this morning. I have a Honda sleeve to re-install, this morning it occurred to me that yesterday would have been a good chance to easily chill that sleeve to -15*
« Last Edit: January 15, 2024, 09:10:14 AM by Don R »
Online Kelly E
« Reply #174 on: January 15, 2024, 12:56:06 PM »
Heat wave here with the temperature at a balmy 32°F. Perfect weather for cutting a big hole in the wall to install a back door in the shop. 8)
1983 Honda CB 1100F
