Author Topic: Don's 81 GS1100e happy Suzuki.  (Read 47625 times)
Re: Don's 81 GS1100e
« Reply #325 on: April 13, 2024, 08:50:55 AM »
 Negative is on the end, the positive is towards the middle, both labeled on the unit and the wire color.
  Removing the baffles/homemade velocity stacks inside the pods improved the WOT air fuel ratio. At over 85mph (max speed readable) and the throttle wide open the a/f ratio stays no fatter than the mid 10's.  I can say for sure the seat needs a bigger hump to keep my ass from sliding back. It's also hard to look at the gauge while doing that, a camera recording it is a great idea.
  It still has an occasional exhaust pop and mid throttle burble, that has me concerned, when I get time, I may do a leakdown test. The usual methods don't show a vacuum leak.
« Last Edit: April 13, 2024, 09:44:14 AM by Don R »
Offline grcamna2
« Reply #326 on: April 13, 2024, 09:51:19 AM »
Yes !  :)
Don,you completely went through the carbs ?
« Reply #327 on: April 13, 2024, 10:09:47 AM »
 No, I haven't rebuilt the choke plungers, and I only cleaned the jets and passages and verified they were open with carb spray but without total disassembly.
Offline grcamna2
« Reply #328 on: April 13, 2024, 10:21:09 AM »
I think a nice set of bigger carbs will certainly benefit that bike Don !  ;)
« Reply #329 on: April 13, 2024, 12:24:05 PM »
 You're probably correct, I met a guy at Advance auto yesterday that owned some GS1100's back in the day, he ran the 29 and 33 smoothbore carbs. He preferred the 29's but because he was willing to give up top end and wasn't getting the 33's jetted right. I believe his bike was less stock than mine.
 I may still have one carb acting up the exhaust probe is getting is a mix of all 4 cylinders.
 I've been working on the race car and tow rig this week. When I get this work done I want to move the trailer over and back so the 40 chevy can come out of storage. I made some repairs last fall and want to see how it goes on the highway. I have a lifetime collection of toys that all need maintained.
Offline grcamna2
« Reply #330 on: April 13, 2024, 12:27:16 PM »
I like the sound of many choices/collection.  :)
Offline Kelly E
  • Geriatric Hooligan
« Reply #331 on: April 13, 2024, 02:34:08 PM »
We put 170 air jets in the stock carbs on the 81' with K&N pods and cured the mid-range stumble.
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
« Reply #332 on: April 16, 2024, 12:06:02 PM »
 The part throttle thing is a cruise rpm miss more than a stumble. I really have a lot to learn, I was surprised to see difference of 10-1 to 12-1 in the 5th gear, 70 mph AFR when the wind direction was reversed. This was with the pod restrictors that are now gone.
  I was thinking about why my helmet is suddenly lifting so bad, then I realized it's the 85 mph speedometer. No idea how fast I was going, except over 85. I didn't check the tachometer. It was all I wanted to do to glance at the AFR meter for the WOT check.
  APE pod filters were ordered online, I hope they get along OK after Big Jay's passing, I'm sure the employees and family need the business to continue as well as possible.
« Reply #333 on: April 18, 2024, 10:45:52 PM »
 I mounted the Polaris type V-Reg. The excess temporary wiring is for the AFR gauge. Revved up a little it charges at 14.5 volts.
« Last Edit: April 18, 2024, 10:49:12 PM by Don R »
Offline grcamna2
« Reply #334 on: April 18, 2024, 11:09:43 PM »
Hoping it'll get enough cooling ventilation.
« Reply #335 on: April 19, 2024, 07:16:49 AM »
I put mine in a similar location, layed vertical under lh side top frame rail.  It has given no problems.
« Reply #336 on: April 19, 2024, 09:55:11 AM »
 I lowered it to make an air gap under the seat, I'm also hoping it will cool enough. I'll give it a workout with the AFR gauge working and high beam then check it for heat. The replacement stocker is still in place just in case of whatever.
Offline grcamna2
« Reply #337 on: April 19, 2024, 10:28:00 AM »
As long as it gets airflow  :)
« Reply #338 on: April 19, 2024, 09:03:56 PM »
 I think the lack of an airbox makes an airflow difference. When I get the APE pods on it, I'll re-check the AFR and see if I can duplicate the difference in air/fuel when the wind direction changes.
« Reply #339 on: April 20, 2024, 07:12:31 PM »
Yeah, I notice a little on a really windy day.  Every once in a while go to grab a handful during a just right gust and it will just go whifff for a second...but really, my gs1100 with pods is about 110 percent better overall fueiing than any of my other bikes stock, pods, etc.
« Reply #340 on: April 21, 2024, 03:39:18 PM »
 Yup, going one way 12.5-1 or so, coming back, same speed same road, same wind, it was around 14.2-1.
 I may construct a set of shields to cover the filter area from the side just to see if it's side wind doing it or head wind differences.
« Last Edit: April 21, 2024, 07:27:16 PM by Don R »
Offline Kelly E
« Reply #341 on: April 21, 2024, 09:35:30 PM »
I'm trying to get my nephew's to 3D print a storage box that hangs from the frame rails. It will fill the space the airbox used to fill. A useful addition and I will see if it helps with the pods issue. Problem is they are too busy with robotics right now. 8)
It's not a problem on the 80' GS 1100E with the RS36 carbs that I can tell.
1983 Honda CB 1100F
« Reply #342 on: April 22, 2024, 08:02:45 AM »
 When I made the V-Reg bracket I thought it should be a drop in tray that can lift out or hinge up. It would be nice to carry a tool kit. The tail fairing also could have been made to hold something like the Honda Super Sport does.
 I noticed the LED taillight bulb messes with the warning panel, it thinks the bulbs are burned out.
Offline Kelly E
« Reply #343 on: April 22, 2024, 09:22:30 AM »
Originally the tool kit bag was stored in the tail. There's supposed to be a rubber strap to secure it. I want my nephew's to also 3D print a storage box for the KZ 1000 too since it's also running pods and RS34 carbs.
1983 Honda CB 1100F
« Reply #344 on: April 22, 2024, 08:02:29 PM »
Yep, my '82 has storage (Not much) in the tail section
« Reply #345 on: April 22, 2024, 08:49:09 PM »
 I better look again. L0L!
Offline grcamna2
« Reply #346 on: April 22, 2024, 09:33:35 PM »
The rubber toolkit hold-down band/strap is still available.  pt.# 09462-00072
« Reply #347 on: April 23, 2024, 05:17:24 PM »
The 78-81 CX500 and CX500 Deluxe versions had a plastic blow mold toolbox older that fit in the tail cowling in front of the headlights. It disappears on many bikes that have had many owners or went through a re-paint... the rear of the seat covers the opening. FWIW...
I looked for a while as a PO sold or removed it...the PO did some shoddy work, teenager who basically assumed title on an abandoned bike by a teacher that lived in Delaware on the island and this kid and his dad ended up with it. It was unclear from the listing he still considered it a project so I wonder if he ever got it legal and rode it or if it was always a project. It ran fine but had some issues that I had to address before titling it in AZ after the shipper got it to AZ. The photos were too kind as the paint on the frame was truly a botch job and I am going to have to strip the frame and repaint it...looks like it was brushed and tried smoothing it after it began drying as there were clearly brusharks to go with the areas where he stripped paint likely some corrosion issues I am guessing from being in a coastal Atlantic island and thought he could just paint those areas he stripped to bare metal....total botch job.
Hope you get it sorted...
« Reply #348 on: April 29, 2024, 07:56:15 PM »
 I rode to the industrial area where my 40 Chevy was in storage today, once there I could see open street with no driveways for several blocks and let the gs loose a little. Holy crap, the sound of that Kerker was incredible, it was the first time I could hear it echo off of a building.
 The metering rod needs to drop at least one step and maybe another main jet size. No word from APE on my air filter order. I'll give them some time, they have only been open a week since the loss of big Jay.
« Last Edit: May 10, 2024, 12:40:49 PM by Don R »
« Reply #349 on: May 10, 2024, 01:08:11 PM »
 I rode the Rat Race 836 with 29's but without air filters to the storage unit and removed the air filters from the Suzuki, I put on the Honda's velocity stacks for an air/fuel ratio test. Oh my, it went instantly lean and ran extremely lean all the way home. I was going to go back for the air filters but there was need for a restroom that doesn't exist at the storage unit, so I hobbled it home.
 I called APE and got a set of their filters ordered, of course they checked when I asked, and don't have them. The TSR said a week tops so I decided to wait. Jegs sat on my money for a month so what the hell?
 Part 2, I ate a sandwich, went back out and it ran fine. The air fuel ratios appear a little leaner than with the filters on. I have a largish inline fuel filter on it that appeared empty when I stopped to check things, now it has gas in it, either it gelled up or the new K&L petcock acted up. It almost takes pliers to move the lever on that petcock, not a big issue because I rarely ever need to move it.
  This unexplained #$%* really gets my goat. I feel like I need to figure these things out to avoid it again in the future.
« Last Edit: May 10, 2024, 05:56:55 PM by Don R »
