Author Topic: Seat Cover Installation  (Read 1089 times)
Offline grumpy56
« on: December 27, 2023, 06:20:26 PM »
New seat cover went on with not too much of a problem. However, the "tangs" on these "buttons" are really firm. Amy tip on how to spread these adequately? Channel locks on the buttons will do it, but there must be a better way. Thanks.
Offline MauiK3
  • A K3 is saved
  • Old guy
Re: Seat Cover Installation
« Reply #1 on: December 28, 2023, 06:45:33 AM »
Maybe a wedge shaped chisel?
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline CycleRanger
  • No comment about being an
« Reply #2 on: December 28, 2023, 07:47:18 AM »
That was my thought as well. Then maybe tap the tabs down with a small hammer?
Are these the buttons from 4-into-1?
I just bought a set of these for my CL350 seat.
I noticed they appear to be steel. I think the originals are aluminum.
I imagine Honda had some kind of special crimping tool.
I need to get some new foam before I recover my seat.
Offline grumpy56
« Reply #3 on: December 28, 2023, 08:16:51 AM »
Purchased my cover and buttons from SCI in Canada. They are steel and the original ones are also. however, the SCI versions seem to be of thicker stock.
Offline CycleRanger
« Reply #4 on: December 28, 2023, 08:40:27 AM »
I think the buttons from 4-into-1 are the same, with the thicker tabs.
Looks like they just cut a straight slot down the middle of the post as opposed to the originals having a V shaped slot.
Offline kerryb
  • Not a very
« Reply #5 on: December 28, 2023, 12:54:09 PM »
Are these the fasteners to attach the chrome seat trim?     The trim on my 70's k bikes is held on by an aluminum nail that gets a springlock fastener.  I tried to save the originals but ended up making new ones from aluminum roofing nails, by turning them down on the lathe.
Offline grumpy56
« Reply #6 on: December 28, 2023, 04:30:16 PM »
No, these are mostly decorative as there are steel tangs in the seat pan that hold it on tight.
Was able to bend the button tangs using channel locks, a paint stick, and a towel. Not as tight as I would like, but will do.
Do appreciate all your comments.
« Reply #7 on: December 28, 2023, 04:56:21 PM »
 400F?
Offline grumpy56
« Reply #8 on: December 29, 2023, 07:14:22 AM »
yes
