Author Topic: Head Light switch reassembly of the slide ball bearing problems  (Read 1604 times)
Offline newday777
Has anyone put in new guts from aftermarket switches into old switch cases? I bought new switches from a couple of different suppliers and have had problems of the cases being too tight over the throttle tube causing binding of the throttle when tightened properly, so I got a good used set of K4 cases(had bad wires and switches)to put in the new guts.
I'm having a hard time getting the headlight switch spring and ball bearing back into the case because of the tight quarters of the case. I've tried using big, wide tweezers as well as my fat fingers (Scotsman).....
Any how to's to help out?
« Last Edit: January 01, 2024, 02:26:20 PM by newday777 »
Stu
My current rides
Prior bikes....
Re: Head Light switch reassembly ball bearing problems
« Reply #1 on: January 01, 2024, 01:39:28 PM »
I did it before.  I don't remember how.  I do remember it took 2 lost balls before the third made it back in there and that it was several years ago and I have not attempted it again.
Offline newday777
« Reply #2 on: January 01, 2024, 01:41:22 PM »
I found 1 of the 2 ball bearings that flew off.....so far
« Last Edit: August 05, 2025, 02:44:09 AM by newday777 »
Stu
My current rides
Prior bikes....
Offline grcamna2
« Reply #3 on: January 01, 2024, 02:18:03 PM »
I found 1 of 2 that flew off.....
The switch comes with two ball bearings inside;one(larger?)for the headlight switch slide bar and the other one(smaller I think)for the red top kill switch. So far I haven't lost one.. knock on wood.
75' CB400F/'bunch o' parts'
Offline newday777
« Reply #4 on: January 01, 2024, 02:23:17 PM »
Yes 2 ball bearings.
The headlight slide bearing is the problem I'm having with re-installing, holding the bearing in against the case and spring pushing in the tension as you try to get the contact plate slid into position.
« Last Edit: August 05, 2025, 02:46:11 AM by newday777 »
Stu
My current rides
Prior bikes....
Offline zabzob
« Reply #5 on: January 01, 2024, 02:23:22 PM »
I used a glob of dielectric grease to hold it in place while I slid it into place. The kill switch part was not difficult, the headlight switch significantly more so.
1975 CB750K5
Offline newday777
« Reply #6 on: January 01, 2024, 02:25:11 PM »
Yes I've slathered dielectric grease on multiple times and as you said the kill switch was a breeze.
Stu
My current rides
Prior bikes....
Offline Flyin900
Re: Head Light switch reassembly of the slide ball bearing problems
« Reply #7 on: January 02, 2024, 03:58:40 PM »
It's been awhile since did any of these and I think the surface is vertical that your trying to slide that gremlin into???
The grease and I believe I used a very thin jeweller's flat blade screwdriver blade to hold the ball and spring compressed into the socket in the housing while pushing the assembly down into the slotted grooves that hold it in place.
With the parts not OEM entirely, there maybe some fit issues that cannot be solved with the above option.  :)
1978 CB550K - Super Sport
1982 CM450A - Hondamatic
1982 CB900C - Custom
1983 CX650E - Eurosport
Offline CycleRanger
  • No comment about being an
« Reply #8 on: January 02, 2024, 06:50:11 PM »
I just did a rebuild recently on my CL350 controls and yeah, it sucks.
I had to replace the slider plastic piece for the hi/lo beam and it was a bugger getting it all back in place.
I had the best luck with a thin set of tweezers.
Also, if you have the controls completely apart like I did make sure the correct spring is in the correct place.
Offline newday777
« Reply #9 on: January 02, 2024, 07:49:20 PM »
Thanks. I'll be rechecking the springs next time I get in the shop.
Do you have pictures of your tweezers? I bought a couple at the local Ace hardware store.
Stu
My current rides
Prior bikes....
Offline CycleRanger
« Reply #10 on: January 02, 2024, 08:55:02 PM »
The tweezers. Nothing special.
Offline newday777
« Reply #11 on: January 03, 2024, 02:34:08 PM »
The smaller ones, left have pointed ends.
The longer have @ 1/4" wide ends.
I'm thinking about doing some modifications like bending the ends in a few degrees to grab more parallel to each other ends.
Stu
My current rides
Prior bikes....
Offline newday777
« Reply #12 on: January 11, 2024, 02:33:02 PM »
Well another got away....... it'll turn up someday.....
Today I ordered 100 4mm Stainless Steel ball bearings.... when they get here, that's probably when the others will return from their jaunt.....🤔
Stu
My current rides
Prior bikes....
Offline CycleRanger
« Reply #13 on: January 11, 2024, 03:27:47 PM »
Good luck, I've been waiting ten years for a kick starter ball bearing I lost to turn up.
Offline newday777
« Reply #14 on: January 11, 2024, 04:39:42 PM »
Now that is being patient 🙌
Stu
My current rides
Prior bikes....
Offline M 750K6
« Reply #15 on: January 12, 2024, 12:09:19 AM »
I specialise in carb needle C-clips.
Offline newday777
« Reply #16 on: January 12, 2024, 02:22:40 AM »
As in In Flight Clips??
Stu
My current rides
Prior bikes....
Offline Floshenbarnical
  • Money pit enjoyer
« Reply #17 on: January 12, 2024, 05:26:25 AM »
At least you didn't drop your ball bearing down a blind bolt hole. I never got that one out
"All things change in a dynamic environment. Your effort to remain what you are is what limits you."
'77 CB750 SS
« Reply #18 on: January 12, 2024, 01:03:17 PM »
ha ha yeah!  At least piston pin clips are big enough that they make a sound every time they bounce off something.  Doesn't mean you are ever gonna find it...but at least you have that hope!
Offline newday777
« Reply #19 on: January 12, 2024, 01:35:40 PM »
OK I now have 100 4mm ball bearings so if you loose yours, let me know.
Now to find those other 2 that went airborne.....🤔
Stu
My current rides
Prior bikes....
