Author Topic: CB750K6 Tank Trim  (Read 470 times)
Offline M 750K6
CB750K6 Tank Trim
« on: January 03, 2024, 08:16:50 AM »
Hi,
I have replacements trim for the bottom of my tank. I can see there are painted tabs on the bottom of the fuel tank, bent over to hold the old trim. Is there a knack to replacing the trim? Do I just gently roll back the painted tabs, pull the old trim down and off, then push the new one on and bend the tabs back? Are the tabs prone to breaking?
Thanks,
Martin
Online newday777
Re: CB750K6 Tank Trim
« Reply #1 on: January 03, 2024, 11:16:10 AM »
That is the way. Just be gentle.
Stu
My current rides
Prior bikes....
Offline M 750K6
« Reply #2 on: January 03, 2024, 02:48:53 PM »
Scary! OK, thanks.
Offline BenelliSEI
  • 1969 cb750
« Reply #3 on: January 03, 2024, 03:05:08 PM »
If you open them up just a hair, you can slide them out the front and slide the new ones in the same way.
Offline M 750K6
« Reply #4 on: January 04, 2024, 02:03:32 AM »
OK, I'll try that first, don't want to scratch the paint. 👍
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #5 on: January 04, 2024, 06:42:25 AM »
They bend easily, be gentle
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline M 750K6
« Reply #6 on: January 04, 2024, 08:35:30 AM »
Done. I had to get a slim screwdriver into the tabs to open them, and then the trim pieces slid off and on. Some small paint damage on the tabs, which I've touched up. I very gently added more curve to the trim, before fitting. Would be easy to cause more damage. A proceed with care and patience type of job. Possibly easier in the summer, when everything is a bit more compliant.
Thanks for your help. 👍
