Author Topic: CB350 F side stand  (Read 771 times)
Offline drodg33
CB350 F side stand
« on: January 05, 2024, 09:53:44 AM »
I have just recently acquired a 350F very original bike with 5900 miles on it.  I have a CB500F a K0 also.  I feel like the 350 has a very straight up side stand and it wouldn't take much to fall over to the right side.  I believe it is original but the lean is much less than on the CB500.  I am wondering if maybe I am just freaking out about something that I should not be.  I will try to post a picture but sometimes I have some issues posting photos.  Thanks
Offline newday777
Re: CB350 F side stand
« Reply #1 on: January 05, 2024, 10:00:12 AM »
Take your picture, then take a screenshot of the picture. That will reduce the picture size count so it should fit the forum parameters.
Stu
My current rides
Prior bikes....
Offline drodg33
« Reply #2 on: January 05, 2024, 11:25:38 AM »
A few photos
Offline drodg33
« Reply #3 on: January 05, 2024, 11:26:30 AM »
one more
Online grcamna2
« Reply #4 on: January 05, 2024, 11:29:37 AM »
Take a picture of the bike leaning over on the side-stand.
Offline Nurse Julie
« Reply #5 on: January 05, 2024, 12:46:59 PM »
Looks about right and the side stand is the correct part. Has it got bigger wheels or tyres fitted?
Trust me I'm a Nurse, I promise it won't hurt....much
Offline drodg33
« Reply #6 on: January 05, 2024, 12:54:07 PM »
Tire size I think is correct
Offline drodg33
« Reply #7 on: January 05, 2024, 12:55:15 PM »
A couple more photos
Offline drodg33
« Reply #8 on: January 05, 2024, 01:00:15 PM »
I did check.  The tires are new and the front is a 3.0x18 and the rear is a 3.50x18.  I believe the shocks are original.
Online grcamna2
« Reply #9 on: January 05, 2024, 01:43:06 PM »
I was going to mention about the rear shocks.. original length?
Offline newday777
« Reply #10 on: January 05, 2024, 01:56:44 PM »
They do stand upright a bit.
Here's your bike and a friend of mine's.
Stu
My current rides
Prior bikes....
Offline drodg33
« Reply #11 on: January 05, 2024, 02:44:26 PM »
Thanks for those photos.  You can see it is about the same as mine.
Offline newday777
« Reply #12 on: January 05, 2024, 05:35:59 PM »
Yes they do.
You can put it on the center stand if it's somewhere to worry about it.
I usually park my 750 on the center stand.
Stu
My current rides
Prior bikes....
Offline drodg33
« Reply #13 on: January 06, 2024, 08:32:29 AM »
Thanks for the feedback.   Great bike and beautiful originality
Offline Trevor from Warragul
« Reply #14 on: January 06, 2024, 08:56:53 PM »
I went out to the garage and tried to duplicate the angle.  I reckon yours isn't leaning enough...
Edit: Mine has the original shocks - I think yours might not be the correct length
« Last Edit: January 06, 2024, 09:05:27 PM by Trevor from Warragul »
1971 Kawasaki H1A
1972 Honda CB350F
1976 Moto Morini 3 1/2 Sport
1978 Honda CBX
1997 Suzuki Bandit 1200
1999 Ducati Monster 750
Online grcamna2
« Reply #15 on: January 06, 2024, 10:08:15 PM »
Trevor,I like the lean angle better on yours.
Offline newday777
« Reply #16 on: January 07, 2024, 02:05:55 AM »
Measure the length of your shocks, eye to eye, so he can compare.(center of bolt to center of bolt)
Stu
My current rides
Prior bikes....
Offline BenelliSEI
  • 1969 cb750
« Reply #17 on: January 07, 2024, 05:37:00 AM »
Note that Trevor has quite a bit of spring preload cranked into his shocks and you are at the lowest setting. This might be lifting his bike higher in the rear, assuming your shocks are not fully extended at rest. Try and crank them up few clicks and see if that helps.
Offline drodg33
« Reply #18 on: January 07, 2024, 11:33:10 AM »
Thank you .  Good idea
« Reply #19 on: January 07, 2024, 10:24:20 PM »
Am I being fat-shamed!   ;D ;)
1971 Kawasaki H1A
1972 Honda CB350F
1978 Honda CBX
Offline scunny
  • don't call me expert
« Reply #20 on: January 07, 2024, 10:49:34 PM »
Just had to comment but I will refrain  ;D
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline drodg33
« Reply #21 on: January 08, 2024, 06:45:00 AM »
Yes I like that lean angle better!!!  Thanks and we are going to adjust the shocks.
