Author Topic: Electrical Question  (Read 736 times)
Offline Vintageguy
Electrical Question
« on: January 06, 2024, 08:55:09 AM »
1978 750F. Want to change out my rear directional signals with better ones. Question is; The existing units have 2 wires as opposed to only one, and they are both plugged in under seat. Do I not need both wires in order for the new units (with only 1 wire) to work properly? Thanks for any/all responses.
Offline 69cb750
Re: Electrical Question
« Reply #1 on: January 06, 2024, 08:56:27 AM »
One wire 12 volts, one wire ground, you need both.
Offline Vintageguy
« Reply #2 on: January 06, 2024, 09:07:52 AM »
Why is it, then, that my replacement units came with only one wire? Thanks
Offline Scootch
  • Someday I'll know what I needed to know years ago
« Reply #3 on: January 06, 2024, 09:15:52 AM »
One wire for running lights and one for turn signals? Gnd supplied by the frame.
Offline grcamna2
« Reply #4 on: January 06, 2024, 09:20:34 AM »
The mounts are grounded to the frame which needs a good(green)ground wire to the main wiring harness;have you checked the factory Honda green ground wire on your main harness and verified it has a metal-to-metal connection to your frame ?
They sometimes don't because the frame paint interrupts the ground connection.
75' CB400F/'bunch o' parts'
« Reply #5 on: January 06, 2024, 09:40:46 AM »
F2 were rubber mounted and needed the seperate ground wire, aftermarket didnt fit the ground wire and left it to the owner to sort out
