Hey all. I'm the new guy. Glad to be here, since I've utilized this forum religiously for 2 weeks now! I'm assembling a CB550 top end right now. It has the 591cc 61mm Dynoman big bore kit in it. I wasn't sure about putting anything on the base gasket, so I just lightly lubed it with assembly lube (I'm an A&P aircraft mechanic so I have the good stuff at work), mimicking the paste pattern you see on OEM NOS base gaskets in pictures. I have an '82 CB650SC camshaft on the way to finish the mod (the guy I bought the bike from sent his cam into Web, and had them take a racing cam and do a custom grind to FACTORY SPECS which I found extremely bizarre) so I have a factory spec brand new Web cam but I'm going the 650 cam route unless any of you scream at me not to.
So to my question...the OEM honda head gaskets do appear to have some sort of assembly paste on them. Should I torque this head gasket dry? The surfaces appear to be pretty mint, no dings dents or damage...Im a federally licensed mechanic, but I'm fresh to the bike stuff and getting hooked fast with my 550, and open to any and all advise on this build. Thanks- Buck
