Author Topic: Hi All from Lindenhurst, IL  (Read 842 times)
Offline 88BuckMeister
« on: January 16, 2024, 11:12:57 AM »
I wrote out a whole thing and it didn't post. Ugh 😔 I'll start over.
I'm Buck. Happy to be here! I live in Lindenhurst, IL with my wife, 2 daughters and one daughter on the way. I'm a federally licensed A&P aircraft mechanic, but while I work on aircraft motors every day, I'm really fresh to this bike stuff. I got sucked into it when i was offered a 1974 CB550 with the bike in excellent condition, the motor pulled from the bike and being rebuilt, with about 2500 bucks in mods just ready to he assembled, clean title pit the door for 800 bucks. I took it, though I knew I'd have to learn how to work on bikes.
The guy who sold it to me had the cylinders bored to 60mm with a Dynoman 60mm piston kit. Because they viewed the ring compressors as one time use, they opted to not use any, and wound up bending the paper thin control rings and scratching the cylinders, which required the cylinders to be re-bored to 61mm and another $750 Dymonan 61mm piston kit to accommodate the larger bore. I was warned when I bought the bike about this, so I contacted Dynoman for advise. They told me don't use compressors, do it by hand and carefully. So I did, and I then bent the rings and scratched the cylinders. Luckily I was able to hone the scratches out and buy new rings. I then opted to not listen to them and go on ebay and buy the original OEM base tools and ring compressors as shown in the 550 manual. It worked like a charm, and now the cylinders are on. Every step forward I go, I learn something new but still feel a bit lost.
Another thing that came with the bike (aside from a brand new 4 into 1 exhaust) was new rocker arms, and a brand new Web Cams camshaft with SPECS UNKNOWN. So I called Web and inquired about it. They said he had them grind the cam to STOCK SPECS which I thought was bizarre, so I found a low mileage cam out of an '82 CB650SC to continue the mod instead of using the cam with stock specs. All the info about how awesome that 650 cam goes with the 591cc 61mm piston kit for this bike I got on this forum, so I jumped to become a member!
I was told in anither post to come here and introduce myself, and my bike. I've always loved Japanese 4's, and so I was excited to buy this bike and learn how to work on them by putting this bike together.
I was also told to start a build thread with pictures, but is this the place to do so??? Anyways, again, I'm Buck, I've got a 74 CB550 I'm assembling with very little bike mx experience, and will need all your help! Waiting for the 650 cam to come in to inspect it, and install the head. Idk maybe I'll torque the head on today, but I've read the lobes may require some material to have to come off the head and I'm worried about doing that with the head torqued on the motor. Again, anyways, nice to meet yall and let me know where to start my build thread so I can assemble this bike with the help of the greatest SOCH4 minds in earth!
Online Stev-o
Re: Hi All from Lindenhurst, IL
« Reply #1 on: January 16, 2024, 11:26:04 AM »
Welcome from Texas, the 550's are fine bikes [I have a '76 550 F Model]
Start your build thread in "Project Shop" area, it will get more views there...
http://forums.sohc4.net/index.php/board,103.0.html
Online tool14
« Reply #2 on: January 16, 2024, 12:12:06 PM »
welcome aboard
Offline newday777
« Reply #3 on: January 16, 2024, 02:10:58 PM »
Very cool story Buck and again welcome aboard.
The 550 is a great handling bike, lighter than the 750 but better weight to power ratio, so with this 61mm big bore and a 650 cam it should outdo any stock 750 and will give an 836 kit a run for the money.
Did your post get lost because of you trying to post pictures with it? If so, take screenshots and crop them of each of your pictures as the forum has a small picture format requirement, the screenshot reduces the size to fit the requirements. (I too struggled with this until I stumbled upon this discovery when I had posted a picture I had done a screenshot of!). I'm old and have a hard time with new apps and electronic gismos....hard to teach an old dog new tricks...
Stu
My current rides
Prior bikes....
Offline MD
  • Living in the North Woods overlooking The Lake.
    • MN North Woods
« Reply #4 on: January 16, 2024, 05:13:22 PM »
Welcome,
Thanks for the write up about your 550.
-MD
1975 CB550F Super Sport;  Lake Superior Circle 1000, 45-90 Saddle 1000, All in Yooper 1000 and SS 2000 in 48 hrs:  1985 GL1200A, MN in State SS1K
Offline denward17
« Reply #5 on: January 16, 2024, 07:08:17 PM »
Welcome Buck from NC.....
Great story on your 550.....
I'm currently in the throws of re-freshing one myself.
My build thread:
http://forums.sohc4.net/index.php/topic,193881.0.html
Good luck with yours.
« Reply #6 on: January 17, 2024, 11:25:16 AM »
You hit the nail on the head, it was the pictures! Only instead of saying something like "file exceeds maximum size" or something like that, it just deleted the whole thing haha
« Reply #7 on: January 17, 2024, 11:25:50 AM »
My build thread:
I'm going to have to dive into your project to get some help with mine! Thanks for the link!
Offline grcamna2
« Reply #8 on: January 17, 2024, 11:33:32 AM »
Welcome to the forum Buck.
Offline newday777
« Reply #9 on: January 17, 2024, 01:42:31 PM »
I've found that if I hit the reverse button you get back to the text again without loosing everything, learned it the hard way....
Stu
My current rides
Prior bikes....
Offline Captainkirk
  • Certified bike nut
« Reply #10 on: January 17, 2024, 08:37:31 PM »
Welcome to the forum, Buck!
Kinda funny how these things go 'round and 'round...I joined this forum like 10 years ago after buying the exact bike you now own, and it went through 2 other owners before I convinced you to buy it as a project. It's good for a kid to listen to his dad sometimes.  :)
I also told you these were good people here. I was right about that, too...
It's easier to ask forgiveness than to gain permission.
Offline Ozzybud
  • Honda Lover
  • Honda Lover
« Reply #11 on: January 22, 2024, 06:31:28 PM »
Welcome from Pacific Washington. Great project 550 you have.
I have a 1975 CB550K1
1976 Z50A YELLOW
1970 CT70 BLUE
1971 CT70H ORANGE
1972 CT70H GREEN
1973 CL200 BLUE
1973 CB350F RED
1975 CB360T RED
1975 CB400F BLUE
1975 CB550 ORANGE
1976 CB750F RED
Offline Godffery
  • Godffery's Garage
« Reply #12 on: April 17, 2024, 05:19:42 AM »
Welcome Buck,
From Godffery of Godffery's Garage, S/E WI. 53105
