Author Topic: Leaking Fork Seals - 400F  (Read 689 times)
Offline grumpy56
« on: January 18, 2024, 03:16:13 PM »
Installed two new Honda fork seals and they are both now leaking worse than they did before. No damage to fork tubes or lower legs  that I can tell. Before I rip it all apart again, tried 2 Seal Mates (both now bent) and could not get them inserted between tube and seal. Any suggestions? Thanks.
Re: Leaking Fork Seals - 400F
« Reply #1 on: January 18, 2024, 04:50:20 PM »
Got to ask what the #*&% is a seal mate
« Reply #2 on: January 18, 2024, 06:14:27 PM »
...seal mate is thin flexible plastic for stabbing down between seal i.d. and fork tube o.d. in an effort to free possible trapped debris that may be causing the leak
show us a picture of your seals from the top.  May be able to confirm that you installed the seals upside down.
Offline newday777
« Reply #3 on: January 18, 2024, 06:54:41 PM »
Did you install the seals with the numbers up or down?
Stu
My current rides
Prior bikes....
« Reply #4 on: January 19, 2024, 12:45:27 AM »
Never heard of seal mate in uk and considering fit of seal to tube would think damage to seal is highly likely
« Reply #5 on: January 19, 2024, 12:58:04 AM »
Oil seals can look different.
You need to verify the direction of the lips. Aiming towards the oil. Feel with finger.
Offline Tracksnblades1
« Reply #6 on: January 19, 2024, 01:14:51 AM »
They’re popular with the inverted forks with large tubes, especially dirt bikes. After removing the dust seal, you run it around the seal. It removes accumulated dirt in the seal…think of walking the piston seal of an automatic transmission down in the bore of a clutch pack…uses the same principle to right the seal’s lip in addition to remove any dirt trapped in it.
https://sealmate.net/
Age Quod Agis
Offline Nurse Julie
« Reply #7 on: January 19, 2024, 05:29:52 AM »
Are they the OEM Honda 400/4 double sprung seals, with oil spring and dust spring? If so, the writing on the seal faces upwards when fitted.
Trust me I'm a Nurse, I promise it won't hurt....much
Offline grumpy56
« Reply #8 on: January 19, 2024, 07:25:42 AM »
Installed seals have writing on top. However, they appear different than these other Honda seals I have.
Offline Nurse Julie
« Reply #9 on: January 19, 2024, 07:39:50 AM »
I don't recognise that part number at all 🤔🤔🤔.
It should be 91255-369-000.
Offline grumpy56
« Reply #10 on: January 19, 2024, 07:47:09 AM »
glad I didn't use those I guess....
Offline M 750K6
« Reply #11 on: January 19, 2024, 02:39:14 PM »
They're CX500 seals. One number out, I think you need 91254 for a CB400.
Offline Ozzybud
  • Honda Lover
  • Honda Lover
« Reply #12 on: January 19, 2024, 05:07:21 PM »
What year bike are you working on?
 xxxxx-413-xxx  the 413 is correct for 78-81 CB400T ,T1 T2
If its  400F You need the Seals for Cb360/CB400 xxxxx-369-xxx as stated above in another post.They must have changed the Diameter Slightly.
Not sure if you have seen this page? some great infor=.
http://oldmanhonda.com/MC/HCodes.html
ozzybud
1976 Z50A YELLOW
1970 CT70 BLUE
1971 CT70H ORANGE
1972 CT70H GREEN
1973 CL200 BLUE
1973 CB350F RED
1975 CB360T RED
1975 CB400F BLUE
1975 CB550 ORANGE
1976 CB750F RED
Offline grumpy56
« Reply #13 on: January 20, 2024, 07:51:03 AM »
Thank you all. I need to verify what seals I put in there (by P/N). My bike is a 1976 CB400F.
Offline CycleRanger
  • No comment about being an
« Reply #14 on: January 20, 2024, 09:28:34 AM »
Check the numbers on the top of the seals. They indicate the size of the seal.
I believe it should be 33x46x11
Also this Honda part number 91255-369-000 had been superseded by this number 91255-413-881.
So those OEM seals you show should be correct.
Offline grumpy56
« Reply #15 on: January 20, 2024, 10:32:23 AM »
thank you
Offline Nurse Julie
« Reply #16 on: January 20, 2024, 11:13:29 AM »
91255-369-000 are 36x46x10.5 mm.
Sooooo, that means the superseded part of 91255-413-881 being 33x46x11 are a different size by my reckoning, I wonder how that works then 🤔🤔🤔🤔
« Reply #17 on: January 20, 2024, 11:44:49 AM »
They wont fit the tube, unless the size is quoted wrong
Offline Nurse Julie
« Reply #18 on: January 20, 2024, 12:43:43 PM »
Yes Bryan, that is most likely the reason, size quoted is incorrect. The seals have to have an ID of 33mm as 400/4 forks are 33mm OD.
