Author Topic: jets... where to buy aftermarket ones  (Read 971 times)
Offline Gurp
  • I'm no.......
  • Once was a...
« on: January 22, 2024, 03:16:06 AM »
running a baffled but more open exhaust and no airbox. either my antipod setup or a breadbox. So need I ned to go up on my idle jet sizing but would like to hear from you guys on where to find good jets. P.S. I know stock airbox is the way to go but its not in my plans. Eventually I'll list my box of airbox parts when I get around to moving bc ill find them again. i think its 3 setups mostly complete but that would be looked for until at least may.
So good companies to get jets from and GO!
PS its for my 73 500 with a 74 550 on it running the 73 carbs. last i had it out it ran good on pods but def had a hangup or 2 as they all do running pods
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
Future project 77 Cb750 Amen Savior
Re: jets... where to buy aftermarket ones
« Reply #1 on: January 22, 2024, 04:11:41 AM »
Sirius Consolidated in canada but their website is not the best
Offline smee
« Reply #2 on: January 22, 2024, 05:18:58 AM »
www.jetsrus.com
They carry OEM jets
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #3 on: January 22, 2024, 05:20:40 AM »
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline Tom R
« Reply #4 on: January 22, 2024, 06:19:12 AM »
In my experience, using genuine main jets is less critical than genuine pilot jets…. Especially if you’re buying them in 3 or 4 sizes…. It starts to add up.  If you’re just going up or down one size might as well go genuine.
« Last Edit: January 22, 2024, 06:21:59 AM by Tom R »
CB750K5 - Slowly putting back together.
GS1100LT - Nicely upgraded over the years.
CB400F - Production lightweight race bike.
Cl175k7 - Gp200 race bike.
Offline Floshenbarnical
  • Money pit enjoyer
« Reply #5 on: January 22, 2024, 08:00:02 AM »
I would most definitely recommend jetsrus for OEM or OEM equivalent jets.
I was rejetting some PD42B carbs off a 78F and while jetsrus didn't have OEM pilot jets they had "OEM equivalent" and I found that going up 2 sizes was perfect for pod filters and open 4:1. They did stock OEM jets for the mains, and I was able to easily dial it in with them.
In my experiences it's not just about the "accuracy" of the ID of each jet *size*, it's about the potential margin of error for jets of the same size. You don't want #1 having a marginally larger diameter than #2 if you can avoid it
"All things change in a dynamic environment. Your effort to remain what you are is what limits you."
'77 CB750 SS
« Reply #6 on: January 22, 2024, 08:00:23 AM »
Sirius used to sell jet "kits" with several sizes in one box
« Reply #7 on: January 22, 2024, 08:06:03 AM »
Screenshot of sirius page
Offline denward17
« Reply #8 on: January 22, 2024, 08:46:23 AM »
Note:
I contacted Mike at jetsrus about jets for a 1976 CB550K with carbs=KEIHIN 087A
They did not have a cross reference for these carbs and no parts.
Probably doesn't apply to this thread though, just thought I would pass the info along.
Offline M 750K6
« Reply #9 on: January 22, 2024, 08:49:20 AM »
I recently had a poor experience with Keyster parts. In particular, the needle was a narrower diameter compared to the needles I removed. I was unable to get rid of a rich open throttle, until I went back to my old ones.
« Reply #10 on: January 22, 2024, 08:57:06 AM »
Pattern needles and needle jets are a biy of a problem but a mainjet is simply a piece of brass with a hole in it so pattern is ok as long as fitted in sets
« Reply #11 on: January 22, 2024, 12:32:29 PM »
Dont buy aftermarket jets!
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #12 on: January 22, 2024, 01:03:28 PM »
I get genuine mikuni delivered through amazon 🤷🏼
« Reply #13 on: January 22, 2024, 03:37:20 PM »
But these are keihn an not easily available
« Reply #14 on: January 22, 2024, 06:42:43 PM »
 One size different in an aftermarket jet might flow like multiple sizes different in any direction.
Offline Captainkirk
  • Certified bike nut
« Reply #15 on: January 22, 2024, 08:02:52 PM »
This^^^^^^^^^^^
It's easier to ask forgiveness than to gain permission.
Offline grcamna2
« Reply #16 on: January 22, 2024, 08:29:55 PM »
I have bought from jetsrus.com plenty and satisfied with their sizes being a choice of OEM and good aftermarket.
I have navigated their site and have the most success in matching jets when I look at all the 'jets' pages(they do have a good image/description to match-up to what you have);they have most configurations and sizes needed.
« Last Edit: January 27, 2024, 01:04:31 PM by grcamna2 »
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #17 on: January 24, 2024, 01:58:09 AM »
That's what I'm looking for is good idle circuit jets.
When I was younger I focused on the mains like all young punk kids. Lol
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #18 on: January 24, 2024, 02:01:00 AM »
I have bought from jetsrus.com plenty and satisfied with their sizes being very close to OEM.
I have navigated their site and have the most success in matching jets when I look at all the 'jets' pages myself;they have most configurations and sizes needed.
I'll check them out. As I really only need 1 or 2 sizes up on the pilots. I'll be running bread box with factory rubbers or the antipod setup designed by a forum member. (still need to reach out to ITG about replacement foam)
Offline willbird
« Reply #19 on: January 24, 2024, 07:27:02 AM »
It is a hole that has a needle inserted into it though...and there is a counterbore that determines what part of the needle is working. If they are consistent, 4 alike and a 105 actually gives us a richer mix than a 100 then I see them as useful...better than nothing for sure.
« Reply #20 on: January 24, 2024, 01:12:53 PM »
Needle dont get as far as the mainjet, or at least it shouldnt!
Offline willbird
« Reply #21 on: January 24, 2024, 03:38:23 PM »
I noticed it poking out with the jet holder removed but had not investigated how close to the needle it ends up.
Bill
Offline WideAWAKE
« Reply #22 on: January 24, 2024, 03:59:46 PM »
Even with genuine jets! Measure them!
I have a buddy who owns a shop and he had to start measuring ALL genuine jets because he was having too many cases of them being off.
He deals in high power 2 strokes where a little lean can make for some big problems but even genuine ones come from so many different places, measure them.
« Reply #23 on: January 24, 2024, 04:17:21 PM »
One problem with that is that due to the difficult to predict nature of fluid dynamics, two holes (i.e. jets) may not "flow" the same amount of fluid.  This is why Mikuni jet numbers don't necessarily corelate wiith Keihin even though they can sometimes physically inter change.  Mikuni jets are numbered based off the results of a flow test, so sure, hole size is gonna be the main attribute but not entirely.
Offline willbird
« Reply #24 on: January 24, 2024, 05:23:12 PM »
When I was a kid my dad worked at Tillotson Carburator in Toledo, OH. as a toolmaker He said that one could take a carburetor jet and twirl a #2 pencil lightly in the metering orifice, clean it, and flow test it again and see a change in the flow just from the pencil tip being rotated against the orifice.
He also said "carburetor" is a French word that translates to "Don't F**k with it" LOL.
Bill
