Author Topic: con rod bolts  (Read 360 times)
Offline tonyw
con rod bolts
« on: January 22, 2024, 04:07:01 AM »
Hi, I'm rebuilding a cb750 k3 and purchased new con rod bolts part number 13213-333-003 these are different to the originals which are no longer available. What's the torque for these ?
Re: con rod bolts
« Reply #1 on: January 22, 2024, 04:10:15 AM »
333 is 350/400 part number so got to ask if you are sure and torque would be same as original
Offline newday777
Re: con rod bolts
« Reply #2 on: January 22, 2024, 04:25:08 AM »
Welcome aboard the forum Tony
Would you explain the difference you have found in the new to the original bolts? Are they the same length and diameter?
According to CMS you did get the correct part number.
CMS shows the original 300 number was superceded to the current 333 number you posted.
How about posting a picture showing the old and new side by side.
And yes, the torque will still be the same as the old bolts.
« Last Edit: January 22, 2024, 04:57:17 AM by newday777 »
Stu
My current rides
Prior bikes....
