Author Topic: Stupid F2 Comcast front wheel (solved, probably)  (Read 386 times)
Offline Floshenbarnical
  • Money pit enjoyer
« on: January 22, 2024, 05:03:18 AM »
Hello all,
I'm replacing the bearings in my Comstars. Currently the rolling resistance on the wheels is like the bearings are lubricated with cake batter. That can't be good.
I am however perplexed and infuriated with the front wheel - I have removed the bearing retainer on the right side, but now I have an axle sticking into a bearing with no way to get purchase on the bearing. On the other side, the speedo drive spins and spins but I can't see a way to remove it. My assumption is that the axle needs to come out first but I decided I would rather ask you folks for advice before I start hammering on things.
What are the correct steps to disassemble the bearing assembly in a 1977 F2 Comcast front wheel.
« Last Edit: January 22, 2024, 08:02:44 AM by Floshenbarnical »
"All things change in a dynamic environment. Your effort to remain what you are is what limits you."
'77 CB750 SS
Offline Alan F.
Re: Stupid F2 Comcast front wheel
« Reply #1 on: January 22, 2024, 05:14:11 AM »
You need to remove #13 (it's a nut) from #2 (axle)
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #2 on: January 22, 2024, 05:18:39 AM »
I usually use an appropriately sized drift pin or punch in the hole at the opposite end of the axle (#2) while removing nut #13.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline Alan F.
« Reply #3 on: January 22, 2024, 05:37:00 AM »
I agree, you need to use something that won't bend.
  • Money pit enjoyer
« Reply #4 on: January 22, 2024, 05:42:55 AM »
So I need to remove the nut on the right side of the wheel opposite the speedo drive. I'm not sure what method you're talking about - a punch in the whole at the opposite end?
'77 CB750 SS
Online Don R
« Reply #5 on: January 22, 2024, 06:04:08 AM »
 Yes, the axle end has a hole instead of a hex, the nut is on the other end like shown in the picture. I have had to heat the nut before but try with the biggest Phillips screwdriver that you can get in there and a big crescent wrench on the other end.
 Take note of the direction of the nut and the order of the spacers.
« Last Edit: January 22, 2024, 06:06:28 AM by Don R »
  • Money pit enjoyer
« Reply #6 on: January 22, 2024, 06:39:57 AM »
So the screwdriver will immobilize the axle while I twist the nut?
Thanks for the assistance.
Finally, should I be trying to buy OEM Honda pads? Kevlar or sintered metal?
'77 CB750 SS
« Reply #7 on: January 22, 2024, 07:58:51 AM »
When the axle is out you use a drift to push the internal spacer sideways and knock the bearing out by using the drift on the inner race, once one bearing and spacer is out you can knock the other one out.
Pads your choice
Offline BenelliSEI
  • 1969 cb750
« Reply #8 on: January 22, 2024, 08:01:12 AM »
Correct.
  • Money pit enjoyer
« Reply #9 on: January 22, 2024, 08:02:28 AM »
As usual, thanks. I'm sure y'all eagerly await my next stupid question
'77 CB750 SS
Offline Alan F.
« Reply #10 on: January 22, 2024, 10:31:53 AM »
Questions come up, but once you've done a thing the answer stays with you. Rinse and repeat a few times and you're in the know. It just takes time and motivation.
