Author Topic: NOS Honda cb750 Engine/Trans.  (Read 2695 times)
Offline BenelliSEI
  • 1969 cb750
Re: NOS Honda cb750 Engine/Trans.
« Reply #25 on: February 24, 2024, 11:47:31 AM »
Points look square and new…… I wonder if it just got a “bench test”. The story is it was sent to a dealer as a warranty replacement and never installed. I will pull the cam cover at one point and see what the cam and rockers look like.
Any other suggestions?
Offline BenelliSEI
  • 1969 cb750
« Reply #26 on: February 25, 2024, 08:54:13 AM »
Anybody need this? Not sure what I’m doing with it……
Offline Tracksnblades1
« Reply #27 on: February 25, 2024, 07:21:01 PM »
Wondering why it has intake rubbers and clamps for the carbs….?
T do you think it’s  a take out instead..?
The way the wire is cut…?
Age Quod Agis
Offline BenelliSEI
  • 1969 cb750
« Reply #28 on: February 25, 2024, 07:50:11 PM »
Honestly don’t know. Could be. Will have a look and see what the cam/rocker wear looks like. Maybe pull the pan too?
Online newday777
« Reply #29 on: February 25, 2024, 08:46:28 PM »
Where as the motor has stamped vin, I would suspect it was a warranty take out for some reason and would probably want to tear it open to do a close inspection on it. It could be on the power side or the out put of the transmission.
Stu
My current rides
Prior bikes....
Online newday777
« Reply #30 on: February 25, 2024, 08:48:10 PM »
I wonder if you contacted Honda warranty claims if they could do a search on the vin to see what was the reason for it being replaced.
Stu
My current rides
Prior bikes....
Offline BenelliSEI
  • 1969 cb750
« Reply #31 on: February 26, 2024, 05:33:46 AM »
Stu….. Honda started selling Civics here in 1976. There were about 10 people in the “Auto Division” and 2 or 3 distributing the motorcycles. I’ve tried in the past, with no results.
Online newday777
« Reply #32 on: February 26, 2024, 05:41:53 AM »
Understood. 1976....pre computer and no input to the computer programs. Hard copy files only and most were deep sixed long ago even if the dealer is still in business.
Stu
My current rides
Prior bikes....
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #33 on: February 26, 2024, 07:05:33 AM »
Might make a cool go-cart or golf cart.
1973 CB 750 K3
10/72 build Z1 Kawasaki
« Reply #34 on: February 26, 2024, 07:16:05 AM »
+1...def does not look like a "new" motor.    Do you happen to have [or can borrow] one of those borescopes to look inside?
Offline BenelliSEI
  • 1969 cb750
« Reply #35 on: February 26, 2024, 12:27:57 PM »
I have an old one that may work. I think the cam and rocker gear might tell a story too? No use for it, bought on a whim!
I thought about putting it in a golf cart. The challenge would be reverse gear and adequate cooling……
« Last Edit: February 26, 2024, 02:35:10 PM by BenelliSEI »
