Author Topic: Lithium ion Battery in a 1975 CB750 ?  (Read 463 times)
Offline John G
  • A 1975 CB Rebuild
« on: February 29, 2024, 10:26:44 AM »
What would happen if I ran a Lithium ion battery in my CB with the original electrical setup. I'm looking at a 12.V 20Ah Lithium ion battery.
« Last Edit: February 29, 2024, 10:28:47 AM by John G »
John G.
Offline M 750K6
Re: Lithium ion Battery in a 1975 CB750 ?
« Reply #1 on: February 29, 2024, 10:44:59 AM »
Check the output of the charging system is in the correct range for the battery. Need a different battery tender, that can maintain them.
« Reply #2 on: February 29, 2024, 12:12:01 PM »
The charging system is far too crude for a lithium battery
Offline John G
  • A 1975 CB Rebuild
« Reply #3 on: February 29, 2024, 01:37:57 PM »
Thanks Bryan, that's what I was thinking. Think I'll just stay with the old liquid acid battery.
John G.
Offline M 750K6
« Reply #4 on: February 29, 2024, 02:35:36 PM »
AGM will be fine.
« Reply #5 on: February 29, 2024, 03:35:21 PM »
Yup, agm ok
Offline Prospect
« Last Edit: February 29, 2024, 06:12:32 PM by Prospect »
Current Bikes
1969 CB750  Sandcast #256
1971 CB750K1
1972 CB750K1
1975 CB400F
1975 GL1000 Goldwing
1954 Harley Davidson Panhead
1957 Harley Davidson Panhead
Toronto Canada
« Reply #7 on: February 29, 2024, 09:48:00 PM »
Having read a lot about the charging system required where lion batteries are frequently used the voltage control of the standard Honda regulator is outside the specs required as it only has 3 settings, off, flat out and approx half charge
Offline Deltarider
« Reply #8 on: March 01, 2024, 12:21:22 AM »
The voltage spikes the old system brings, won't help much either, I'm afraid.
CB500K2-ED Excel black
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #9 on: March 01, 2024, 06:35:14 AM »
It does seem likely that a lithium battery would work, at least for awhile. The old charging system might cause early failure of the battery, not sure. What would be cool is if someone set up a "minder" brain between the battery and the + terminal to monitor charging and intervene if needed.
1973 CB 750 K3
10/72 build Z1 Kawasaki
