Author Topic: CB500 advance mechanism differences.  (Read 968 times)
Offline Scott S
« on: March 03, 2024, 12:19:56 PM »
 I thought I had my '71 CB500 sold and noticed something odd today.
 The buyer asked me to install the Tytronics ignition. I got it installed and can't get the timing right. It doesn't seem to advance and runs rough in the upper RPM range. I had it running pretty good on points.
 The points plate is a TEC unit.
 To install the Tytronics, you remove the cam on the advance mechanism. I went to install it today and double checked where the "dot" is supposed to go. It should be about 4 o'clock, pointing to TEC on the advance.
 Here's where it gets weird. I cannot install the cam where it is in the correct position. Installed, it's pointing at about 7 o'clock. Turning it 180 degrees, it points at 1 o'clock. This is the advance mechanism that was on the bike when I bought it.
 The advancer has 323 stamped onit, as well as AD125-02, and a stamped emblem of some sort.
 See pics.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline Scott S
Re: CB500 advance mechanism differences.
« Reply #1 on: March 03, 2024, 12:23:54 PM »
 I dug around in my stash and found a TEC mechanism. The dot is at 4 o'clock, as it should be.
 I thought the bike ran OK with points, but the cam position is completely different on the TEC plate. Maybe that's why the electronic ignition couldn't be timed properly? Maybe I left something on the table by using  that mechanism, even with a good TEC points plate?
 What am I looking at here? I'll use the TEC advancer, and now I'm wondering if I should start it on points again or try it with the Tytronics?
 Here are some pics of the TEC unit.
'71 CB500 K0
'81 Yamaha XS650
Offline CycleRanger
  • No comment about being an
« Reply #2 on: March 03, 2024, 12:36:22 PM »
The second advancer is a Hitachi part.
I wonder if the Tytronic package has the wrong rotor.
Offline Scott S
« Reply #3 on: March 03, 2024, 12:52:23 PM »
 I had this Tytronics on a different bike without any problems.
 Was Hitachi OEM? Or an aftermarket part?
 The cam lobe on the Hitachi unit looks to be shaped differently, by eyeballing it.
'71 CB500 K0
'81 Yamaha XS650
Offline CycleRanger
« Reply #4 on: March 03, 2024, 01:45:59 PM »
I had this Tytronics on a different bike without any problems.    -Ah, ok.
Honda used both Hitachi and TEC advancers.
Offline Scott S
« Reply #5 on: March 03, 2024, 02:08:17 PM »
 The cams sure look way different on them.
'71 CB500 K0
'81 Yamaha XS650
« Reply #6 on: March 03, 2024, 03:44:59 PM »
Don't overlook the possibility that someone in the past swapped the cam on the advancer? This happened to me, and more than once (but on different bikes).
The AD125-00 and AD125-01/02 units have similar stamped numbers, but apply to different bikes. The "323" is for the 500/550 engines, the "300" for the 750 (although I've found them on CB400F from time to time, too).
Offline Scott S
« Reply #7 on: March 04, 2024, 10:50:15 AM »
 I just wanted to follow up:
 I put the points back on with the same Hitachi advancer. Bike runs great now!
 I have used Tytronics before with great results. That exact unit was on a different bike, but with a TEC advancer. I couldn't get it to advance with the Hitachi unit. I'm wondering if the Tytronics rotor was rubbing or binding somehow?
'71 CB500 K0
'81 Yamaha XS650
« Reply #8 on: March 04, 2024, 11:18:42 AM »
The Hitachi advancer on my 750 had a pin sticking out on the side that fit into a groove on the inside of the cam. It was necessary to remove the pin to fit the Gerex rotor, and the same for a Dyna rotor. The TEC advancers didn't have the pin.
Offline Deltarider
  • I'm back
« Reply #9 on: March 05, 2024, 05:04:30 AM »
This ^ and what Hondaman mentioned: make sure either you or the PO didn't reassemble the cam 180o degrees out.
CB500K2-ED Excel black
« Reply #10 on: March 09, 2024, 07:56:43 PM »
...make sure either you or the PO didn't reassemble the cam 180o degrees out.
I wish I could say I've never done that...
« Reply #11 on: March 09, 2024, 09:42:50 PM »
There were two different advancers on the 500, one of which is quite rare but either work fine
Offline jonda500
« Reply #12 on: March 10, 2024, 05:25:27 AM »
`I don't wanna say how long it took me to realise that this was the reason I had to switch the yellow and blue wires to get my 400-4 to start after overhauling it back in the late eighties, John
A starter clutch thread:
« Reply #13 on: March 11, 2024, 01:20:21 PM »
Yeah...that was how I "troubleshot" what I did to the advancer... :(
