Author Topic: 2024 BMST  (Read 7405 times)
Re: 2024 BMST
« Reply #125 on: August 21, 2024, 09:59:02 PM »
Hey Dennis, how about you PM me the phone # and a contact name of the shop, and I'll call them and see if they can email the graph directly to me.
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
Re: 2024 BMST
« Reply #126 on: August 23, 2024, 06:54:35 AM »
Daybreak Zero
Re: 2024 BMST
« Reply #127 on: August 23, 2024, 06:59:43 AM »
Daybreak Zero
Great pic Bomber!   Plz update us as much as possible.  Thx
  • Holy Cow! I'm a
Re: 2024 BMST
« Reply #128 on: August 24, 2024, 04:24:47 PM »
Guys, the wind picked up.
My homies are running damage control - ya'll should get out here before 8pm 82424
Re: 2024 BMST
« Reply #129 on: August 24, 2024, 06:48:06 PM »
Any news yet???
  • Holy Cow! I'm a
Re: 2024 BMST
« Reply #130 on: August 25, 2024, 06:08:51 PM »
Nice run Dennis  8)
Re: 2024 BMST
« Reply #131 on: August 25, 2024, 06:27:02 PM »
  • Holy Cow! I'm a
Re: 2024 BMST
« Reply #132 on: August 25, 2024, 08:49:19 PM »
Nice run Dennis  8)
There was racing today, old scrambler got a few passes in.
Re: 2024 BMST
« Reply #133 on: August 25, 2024, 08:51:08 PM »
How fast did he go?
Online RAFster122s
Re: 2024 BMST
« Reply #134 on: August 25, 2024, 09:19:28 PM »
Saw a post on FB where he indicated it is not running at peak and is going to take some tuning... It didn't sound clean starting off...
Online RAFster122s
Offline dragracer
  • CB750F Dragbike
Re: 2024 BMST
« Reply #136 on: August 27, 2024, 10:44:39 AM »
Any update??
Online RAFster122s
Re: 2024 BMST
« Reply #137 on: August 27, 2024, 11:45:32 AM »
Nothing verbal getting posted on FB thread, went through scrutineering for bike and gear...
Offline Old Scrambler
Re: 2024 BMST
« Reply #138 on: August 27, 2024, 08:58:38 PM »
Nothing good to report :(
Shifting problems to catch 4th & 5th gears.............not enough power to pull record-breaking speed in 5th..........will attempt 4th-gear passes in the AM...........spent most of today repairing rocker threads from a loose adjuster. The motor runs sweet but does not have the top-end power I was hoping for............plug color and megaphone color look good from tan to medium gray...........Rider's meeting at 7-AM ;)
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Re: 2024 BMST
« Reply #139 on: August 27, 2024, 08:59:54 PM »
What jets are you running?
Re: 2024 BMST
« Reply #140 on: August 27, 2024, 09:06:12 PM »
Rich Magee set 3 new records with his CB550 8) 8) 8)
Quite a few newbies and some very "lost' spectators driving where they are not allowed.
Jerry Griffin helped the team from Florida with a CB750 sidecar rig tear their motor apart for impound inspection after they qualified for a record.
Bill Wolf has a well built CB750 running the modified 1000 class.........no reports of any records on a low-hanging target.
« Last Edit: August 27, 2024, 09:09:46 PM by Old Scrambler »
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
Re: 2024 BMST
« Reply #141 on: August 27, 2024, 09:08:22 PM »
Scott.................117.5s
Will try 120s after 1st run in the AM
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
Re: 2024 BMST
« Reply #142 on: August 27, 2024, 09:11:11 PM »
Dennis, the 120's were extremely lean when you had the bike here. PLEASE install the 127.5 main jets!!!!
Re: 2024 BMST
« Reply #143 on: August 27, 2024, 09:17:43 PM »
Also, set the ignition timing back to 30* total advance, or static halfway between the T and F marks.
Re: 2024 BMST
« Reply #144 on: August 27, 2024, 09:56:26 PM »
This is your bike with 120 main jets. It's too lean for pump gas, much less the oxygenated fuel you are running. The peak HP was only 63.32.
« Last Edit: August 27, 2024, 10:08:07 PM by scottly »
Offline johno
Re: 2024 BMST
« Reply #145 on: August 28, 2024, 01:03:51 AM »
Ditto Scottly :o
If your running the oxy rich fuel on 120 mains ya gunna be running seriusly lean ...... with 750 displacement the AF get really sensitive and needs to be spot on or slightly rich. On my 750 on first dyno I stuffed up the jetting and it was between 14 and 15 to 1, flames popping out the exhaust,
Lost heap of HP with a new fresh build and it only pulled 67HP, big downer from the 80 I was hoping for  ;D changed jets etc 2 runs and peaked at 79HP.......and that was on Sunaco avgas not the groovy stuff.......which would make a bigger difference etc.      So Den, that's 2 votes for #$%* load more fuel. The old saying is better too much than not enough when your playing with oxy stuff.
Are you running titanium adjusting nuts ?   I had big dramas with them and now back with stock.
Hope the weather holds Den and for an old fart like you its just another day in the office.👍🏁
cheers Johno
GRASSHOPPER SOHC HONDAS ARE THE MEANING OF LIFE.
Re: 2024 BMST
« Reply #146 on: August 28, 2024, 07:08:46 AM »
Awesome, congrats to Rich.  Thx for the update.
Scott - you should be there!
Re: 2024 BMST
« Reply #147 on: August 28, 2024, 08:29:09 PM »
Any updates???
Online RAFster122s
Re: 2024 BMST
« Reply #148 on: August 28, 2024, 09:04:06 PM »
Post on FB account indicated no progress on breaking record but they were slowly chipping away at the problems that have presented themselves.
Offline dragracer
  • CB750F Dragbike
Re: 2024 BMST
« Reply #149 on: August 29, 2024, 03:15:54 PM »
Still holding on for updates. Any news from today??
