Author Topic: Re-jetting help after engine rebuild and modification  (Read 518 times)
Offline Diegoz89
« on: March 06, 2024, 05:58:16 am »
Hi.
I need some little help in carb tuning after my Honda CB500 k2 '76 engine rebuild and modification.
I will summarize the works done on the engine:
-cylinder re-bore +2.50 mm
-new piston diameter 58.50 mm (Daytona Japan manufacturer, it will bring to approx 550 cm3)
-other restoration works that does not affect carburetor tuning
I want to run these filter setup:
- stock Honda airbox + DNA filter via the following adaptor:
https://www.classic-bike-parts.de/Resto-mod-Honda-CB500-550-Four-Adapter-Kit-Airbox-Luftfilterkasten
Lastly, this is my exhaust setup:
-Marving 4 into 1 open  pipes.
As per the above configuration I have considered the following carb setup:
-carb floating set to 22mm;
-idle jet #40 jet (stock value);
-main jet set to #100;
-needle raised by a notch;
Please, any suggestion is welcome.
Thank you all.
Diego
Offline willbird
Re: Re-jetting help after engine rebuild and modification
« Reply #1 on: March 06, 2024, 12:28:37 pm »
That is an interesting looking filter setup :-). First look I have had at that the original 500/550 did in that respect.
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #2 on: March 08, 2024, 08:59:01 pm »
The airbox filter adapter is a legit mod.
Could probably go 2 sizes bigger in the jetting and have a happy running 550 with that increased airflow.
