Author Topic: 75 550K tank trim  (Read 641 times)
Offline bender01
75 550K tank trim
« on: March 18, 2024, 08:09:33 PM »
Anyone know a good replacement for the tank trim for a 75 550k?  It appears to be hard to find for me. Mine is loose so i pinched it to see if it would help to seat back in place and .. it just cracked making it worse. I can get crafty to keep it in place but I really would like to replace it. Thanks for some pointers in the right drection.
75 550 K1
74 750 K4
1968 450 K1 Super Sport
74 750k 836 project
Good luck!
Two Tired Quote !
Re: 75 550K tank trim
« Reply #1 on: March 18, 2024, 08:14:34 PM »
There is an Italian firm doing repro colies or ask Nurse Julie on hee for a one piece trim that looks ok(but it will post from uk)
Should be pic of italian firm attached
« Last Edit: March 18, 2024, 08:17:48 PM by bryanj »
Offline CycleRanger
  • No comment about being an
« Reply #2 on: March 18, 2024, 09:09:12 PM »
I used some flexible chrome auto door trim I got at the parts store. It's self-adhesive and comes in a roll.
Turned out ok. Sorry I don't have a better photo.
Offline Flyin900
« Reply #3 on: March 19, 2024, 02:23:49 AM »
+1 With the auto trim it is easiest to find. Not likely as accurate as the Italian reproduction item though. The auto trim is easy to install and is a reasonable facsimile of the original trim.
1978 CB550K - Super Sport
1982 CM450A - Hondamatic
1982 CB900C - Custom
1983 CX650E - Eurosport
Offline BenelliSEI
  • 1969 cb750
« Reply #4 on: March 19, 2024, 05:49:02 AM »
Canadian Tire has a few styles. The one I like is a “U” channel and fairly small. The bottom of the channel has a stream of adhesive that’s slightly skinned over. When you press it in place it pops, releasing the small amount of glue. I warm them up before pressing into place and tape them down for a few days. I’ve used it of my cb750 K7 and K8 and it looks original and never come off.
Not sure how it will curve around the neck part, maybe really warm it up first?
Offline CycleRanger
« Reply #5 on: March 19, 2024, 10:30:55 AM »
It is tough to get it to stick around the top edge of the tank, it's a pretty tight bend.
Heating it a bit is probably a good idea, I didn't do that.
Bang-for-buck however I thought it came out pretty good.
Offline bender01
« Reply #6 on: March 19, 2024, 07:35:28 PM »
Thanks.  Ill look some more. Maybe one of the specialty places will find some. DSS doesnt.
75 550 K1
74 750 K4
74 750k 836 project
Good luck!
Two Tired Quote !
Offline carnivorous chicken
« Reply #7 on: March 19, 2024, 08:10:26 PM »
Space Age Paint in Mesa, AZ, has flexible trim that can be bought in whatever length you want. I've used that for both tank and seat trim.
