Author Topic: Rusty Tank - Thoughts?  (Read 2015 times)
Offline Hills2Horizons
« on: March 21, 2024, 07:36:01 AM »
When I first re-did the tank a few years ago it was a lengthy process. Almost a week of nuts and bolts swimming around in acid, shake, shake, shake, dump, refill, repeat. But I got it cleaned up pretty well to where I wasn't nervous about running it.
Then - I opened the cap last night (photo) after it has been sitting since probably 2017-2018 with no fuel in it.
Thoughts? Should I just start the process again? Obviously the tank hadn't been repainted when I did it last time so I didn't care about the acid on the paint, but I do now. Would it be better/easier to just coat the inside?
1972 CB500F
Offline Pbeattie89
Re: Rusty Tank - Thoughts?
« Reply #1 on: March 21, 2024, 07:51:02 AM »
I personally dislike coating. There are too many horror stories of them failing, and they are way harder to remove than the rust. I've used vinegar with decent success. If you spill any on the paint, just rinse it off with water. Let it sit for 24 hours and then drain. I then half filled with water and added steel BB gun ammo and shook it up to knock everything loose. The BB gun ammo is easy to fish out with a magnet. Then rise with plenty of water and repeat if needed. After it's done to your satisfaction, just coat the inside with a little two-stroke oil if it's going to sit or fill it with gas.
Sent from my SM-G991W using Tapatalk
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #2 on: March 21, 2024, 07:55:00 AM »
electrolysis works, it's a little fiddly to set up but it works.
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline Pbeattie89
« Reply #3 on: March 21, 2024, 07:56:05 AM »
Brick house builds did a video of it on youtube.
« Reply #4 on: March 21, 2024, 08:38:17 AM »
 I've used the Evaporust, muriatic acid and vinegar methods. Recently I did a couple and used vinegar as a pre-treatment followed by Evaporust. I did it that way to save the expensive Evaporust for several uses.
 Cleaning vinegar is stronger than cooking type, I used a mix of both, I found the cleaning vinegar at Menards and added it to the cooking type that I already had. I left a trouble light bulb under the tank because it was cool in the shop and the process works better when it's not cold and it's the same with Evaporust.
 The rusty cleaning vinegar makes a safe weed killer when you're done with it. It for sure needs oiled when done.
  I used northern blue tank liner in my goldwing, so far so good but in a 750 tank it didn't do a lot.
Online newday777
« Reply #5 on: March 21, 2024, 08:47:44 AM »
It rusted from not coating it with 2 stroke oil when you emptied it.
Yes now you will need to derust it again before you use it(even if you decide to line it....I don't advise lining your tank.....).
Electrolysis cleaning works great with no damage to the paint. I have derusted many tanks this way, some have been rusted more than your tank is and have had great success. I follow up after rinsing out the washing soda mix with fresh water, dump out, then fill with Evaporust to the top for a couple days. Then dump the Evaporust back into the 5 gallon bucket to reuse on another tank. Then rinse the tank 4 times with 2 quarts of diesel fuel and shake to rinse and capture the moisture of the Evaporust. I dump the diesel fuel into another clean 5 gallon bucket (to save), pour in 2 more quarts of diesel fuel and shake again, repeat this rinsing 4 times. (The moisture separates and settles to the bottom of the bucket after a few days and you can drain off the diesel fuel to use the next time)
Then I coat the tank with 6-8 oz 2 stroke oil turning the tank so it coats all over including the top of the tank, then dump the excess oil. The coating will mix with the fresh gas you put in when you fill it. It won't hurt the carbs or motor. You can add 2 oz of 2 stroke oil to each fill up to preserve the tank will you are riding the bike too.
And you don't have to line the tank either, as long as the tank doesn't leak anyhow..
I drain my tanks each winter for storage and coat the tank with 2 stroke oil to preserve the tanks.
Stu
My current rides
Prior bikes....
« Reply #6 on: March 21, 2024, 10:35:59 AM »
Hello - I can't believe that's even the same tank. It looks GREAT. I can't remember what I coated it with but you are correct in that it was not 2-stroke oil, I do know that much.
1972 CB500F
« Reply #7 on: March 21, 2024, 10:56:14 AM »
So for this did you essentially just use the tank itself as the 'electrolysis tank' instead of submerging it INTO an electrolysis tank? If so that seems very straighforward based on with I just watched on how the process is done. Where did you attach the leads for the electrical current? Just around the gas filler neck?
1972 CB500F
Offline The Lone Builder
  • "Still running against the wind"
    • Belfast-2-Belfast-By-Bike
« Reply #8 on: March 21, 2024, 02:13:08 PM »
I have used both electrolysis and vinegar. The former is slow and the latter even slower!
The main problem I found with electrolysis was to get a suitable shaped electrode and then making sure it wasn't touching the tank. That said, it worked well.
CB750 K2 - From Belfast-2-Belfast
CB750 K1 - The less, said the better!
CB450 K1 - Stalled.
CB400F Supersport - Not Rusty any more!
Follow my journey through Africa @ http://Belfast2BelfastByBike.com
Offline rotortiller
« Reply #9 on: March 21, 2024, 02:41:52 PM »
Gotta love that POR-15 tank liner stuff. If used correctly the first time around you likely would not be in this situation. I did the pictured tank back in 2017 and it's still in the same condition. Maybe try vinegar and that evapo crap then etch carefully with POR-15 metal prep then use the good stuff :).  Do not make the tank airtight when using vinegar or it will pop lol.
« Last Edit: March 21, 2024, 02:44:10 PM by rotortiller »
Offline willbird
« Reply #10 on: March 21, 2024, 03:12:29 PM »
I just poured mine 100% full of Evaporust. Left it in about a week. I have another one to do with he same 5 gallons of Evaporust. The 5 gallon bucket full of it has had quite a few other things submerged into it too. I did not run out and get 5 gallons I just kept picking it up until I had enough to fill it all the way up.
Bill
Online newday777
« Reply #11 on: March 21, 2024, 04:03:02 PM »
Yes.
The negative goes on the back tang that the rear rubber holder grabs the tank in place. I sand off the paint
The electrode gets the positive lead.
« Last Edit: March 21, 2024, 04:06:00 PM by newday777 »
Stu
My current rides
Prior bikes....
« Reply #12 on: March 21, 2024, 09:21:37 PM »
I've long done something similar to this: after the vinegar (or whatever treatment) is used, I immediately soak the inside with oil, sometimes the 2-stroke kind. Then when using the bike, I always add a bit of oil to the gas at fillups (the 2-stroke oil stalls the ethanol's ability to strip lube from these older engine's combustion surfaces, and gas tanks, and carb bowls, etc.) and when I park it, I fill the tank fully up with the oil-treated gas. I've usually just fired up the bike and run it out with no trouble, even 2 years later. Meanwhile, 2-year-old untreated gas (i.e., no 2-stroke oil added) in a metal or plastic container won't even start my Honda mower, so the oil is helping quite a bit.
If it gets so bad that the tank needs coating, I can recommend the POR15 kits. Not simple nor quick to install, but seems to last forever. I have customers' bikes now with 15 years on POR15'd tanks, no grief at all.
Offline carnivorous chicken
« Reply #13 on: March 22, 2024, 07:50:36 AM »
I'd second (third?) that as well. I've had POR15 treated tanks with 15+ years of no issues as well. As long as you do it correctly, it seems to work well.
I'm about to repaint a 350F tank, and the rust isn't that bad but definitely needs cleaning. I'm always wary of people who recommend something acidic to clean as it's going to affect the metal, and I'd hate for a newly painted tank to develop pinhole leaks...
Offline willbird
« Reply #14 on: March 22, 2024, 01:13:40 PM »
It would be kind of cool to find some kind of hollow neutrally buoyant ball to use in the tank with evaporust to reduce the quantity actually needed to fill the tank. I seem to recall seeing somebody had made something to move rotate a partially filled tank to keep the entire inside wet ??
Offline willbird
« Reply #15 on: March 22, 2024, 02:42:47 PM »
Golf balls.
Do they fit ?
Offline britman
« Reply #16 on: March 25, 2024, 08:32:35 AM »
I am very old, therefore so are my methods.  A large hand full of dry wall screws, a few good size nuts for good measure.  A quart of acetone mixed with some lacquer thinner, then come  to doing the shimmy shake for about 15 or 20 minutes.  Empty the tank, a very strong magnet on a wand is a very good friend at this point in the process.  Rinse with a little more thinner and blow out the tank well with compressed air.  I usually let the tank air dry in the sun for a day or two.   For coating I use nothing but Caswell tank sealer, I have never had a failure, it has even sealed pinholes in few really bad tanks, and I order directly from the company website.  I just ordered the MC tank kit for a CL77 project and it arrived within a week......
« Reply #17 on: March 25, 2024, 09:41:40 AM »
How did you plug the petcock bung?
Offline willbird
« Reply #18 on: March 25, 2024, 11:42:24 AM »
I just left the petcock attached.
Bill
« Reply #19 on: March 25, 2024, 01:34:36 PM »
I buy rubber stoppers -- just bought some at Ace Hardware on my recent trip back to the States (I'm sure they exist here, couldn't find them at the places I tried). One big one for the top, one small one for the petcock hole, and I usually just use the two mounting screws with washers (for the 350F). Screw-on types are just one hole to plug of course...
Offline britman
« Reply #20 on: March 25, 2024, 02:35:15 PM »
Two petcock screws, a piece of old innertube, and a piece of aluminum cut to fit the the opining.   Rubber on the inside and bolt it up, works great....
« Reply #21 on: March 25, 2024, 03:01:50 PM »
 All good advice. I would remove the petcock, a friend bought my brothers XS1100 and de-rusted the tank with the works toilet cleaner with the petcock installed. It blew up, he had made what's known as a works bomb. I plugged a couple petcock holes with 6m screws wrapped with teflon tape and a golf tee in a rubber hose in the fuel hole.
 The last one I did I made an aluminum plate drilled for the 6m bolts and used an awl to poke the bolt holes in a rubber gasket, then thread the bolts through the rubber and into the tank.
« Reply #22 on: March 25, 2024, 03:17:21 PM »
I always undo a stopper after shaking around and when it's just going to sit for a while...
« Reply #23 on: March 26, 2024, 06:42:17 AM »
The old petcock was leaking and dont want to subject the new one to that.
That is what I had in mind, thanks
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #24 on: March 26, 2024, 07:54:44 AM »
Hopefully photos when done?
1973 CB 750 K3
