Author Topic: Starter issue or just bad battery...again..CB550  (Read 3480 times)
Offline denward17
« on: April 03, 2024, 01:57:55 PM »
About 4 weeks ago ordered a new Scorpion battery for the '76 CB550K I am refreshing.  It started with about 12.7v out of the box but would barely turn engine over.  With my cheap multimeter measuring volts while holding the start button, it would drop to about 6v.
Supplier thought the battery was damaged, so sent a new battery.  Got it today and out of the box it read 12.87v.  Hooked it up tried to start bike.  Same thing happened.  It would barely turn engine over then go flat.  Reading while holding the start button was about 7v.
Is this another bad battery or do I have an electrical problem?
Bike will start with kick start and runs good, although I had the headlamp/tail lamp fuses out.  With 2500RPM or so the battery would show about 14+ volts.
Forgive me, I am not an electrical guru, but can follow instructions.
Thanks for any assistance...
Re: Starter issue or just bad battery...again..CB550
« Reply #1 on: April 03, 2024, 02:18:01 PM »
New batteries should be charged before fitting
Offline BenelliSEI
  • 1969 cb750
« Reply #2 on: April 03, 2024, 02:23:55 PM »
Den….. my cheapo AGM come charged and ready to go. That one sounds like it needs a charge. Are you certain something is not jamming in your starter motor or the spur gears? Probably not, as even that should not suck the battery down that fast.
Try just turning the lights on. Does that kill it fast too?
Offline denward17
« Reply #3 on: April 03, 2024, 02:26:50 PM »
Paperwork with battery indicates it is ready to go.  Right now at 12.7v.
I did put the charger on it, will check later today/tomorrow.
« Reply #4 on: April 03, 2024, 02:36:28 PM »
Voltage measurement is NOT  state of charge
Offline M 750K6
« Reply #5 on: April 03, 2024, 02:54:50 PM »
Could you have a poor earth to the starter, or poor connections through the circuit to/from the starter button?
Offline denward17
« Reply #6 on: April 03, 2024, 03:20:12 PM »
I don't know but will pull off the trans cover tomorrow and check the connections.
« Reply #7 on: April 03, 2024, 04:06:29 PM »
Trans cover wont show ground lead, check at rear top engine mount that bolt is tight and no paint either side of bracket
Offline denward17
« Reply #8 on: April 03, 2024, 04:22:25 PM »
Upper engine mount bolt is torqued to spec, with dielectric grease.  Frame was touched up with paint, but I did sand the mounting points on both sides of clutch bracket, and on the outside of the upper bolt contact point on the left side.
Would that copper washer make a difference on the clutch cable bracket upper bolt?
« Last Edit: April 03, 2024, 04:26:12 PM by denward17 »
Offline denward17
« Reply #9 on: April 03, 2024, 04:52:23 PM »
After charging for 2.5 hours, voltage check was 12.8, turned ignition switch on with all fuses in and battery voltage dropped to 11.9.
Will let it trickle charge overnight.
Offline grcamna2
« Reply #10 on: April 03, 2024, 05:17:21 PM »
Possibly check this next time you install the battery by:installing the + positive lead to the battery,then hooking a 12vt. test light between the Neg.- battery cable and the Neg.- battery post.
The bike may have a bare + connection touching the frame/starter?
« Last Edit: April 03, 2024, 08:12:28 PM by grcamna2 »
75' CB400F/'bunch o' parts'
« Reply #11 on: April 03, 2024, 06:58:47 PM »
That ground lug goes in between the engine and frame on the long upper cross-bolt in your picture. Where it is now will cause losses between the aluminum engine case and the steel frame where they meet up.
Offline denward17
« Reply #12 on: April 03, 2024, 07:02:57 PM »
Just so I am clear, the ground lug goes between the engine and the clutch holder bracket?
Mark, Are you referring to the bolt circled in the picture attached?
« Last Edit: April 03, 2024, 07:15:12 PM by denward17 »
Offline denward17
« Reply #13 on: April 03, 2024, 07:12:10 PM »
The bike may have have a bare + connection touching the frame/starter?
Tried it, no light..
« Reply #14 on: April 03, 2024, 07:31:51 PM »
Yep, that's the one!
The frame bolster is actually spaced outward there by 1mm wider than the engine to accommodate it.
Online scottly
« Reply #15 on: April 03, 2024, 07:42:01 PM »
What are you using for a charger? Battery "maintainers" may not put out enough voltage to fully charge a battery, which should be 14V or more. Check the voltage with your meter while the battery is on the charger.
Online scottly
« Reply #16 on: April 03, 2024, 07:47:32 PM »
You might have a bad starter, drawing way too much current? That's where I would start looking..
Offline denward17
« Reply #17 on: April 03, 2024, 07:54:39 PM »
It's a Schumacher 10amp, but in auto mode it only pulses to what appears to be 2 amps.
Online scottly
« Reply #18 on: April 03, 2024, 08:04:02 PM »
Monitor the voltage while on the charger!!! Use a separate meter. DO NOT rely on the auto mode, as those stupid "smart chargers" get confused by our small batteries: they are programed for larger car batteries. If the voltage gets up to 14 +, shut the charger off.
Offline grcamna2
« Reply #19 on: April 03, 2024, 08:19:52 PM »
I think it will help to clean the back side of the frame(top/rear engine mount long bolt)for a better connection(engine paint?)where that - ring terminal goes between the frame and the engine case.
You want metal to metal contact, w/ a little dielectric grease to keep corrosion from forming later.
Online scottly
« Reply #20 on: April 03, 2024, 08:28:01 PM »
The problem is not with a bad ground, which would decrease the current draw by the starter, instead of sucking the battery down to 7 volts.
Offline Ozzybud
  • Honda Lover
  • Honda Lover
« Reply #21 on: April 03, 2024, 08:57:22 PM »
Looks like you have the ground lug on the correct bolt and in the correct location.
pic below is my CB550. It was virtually untouched when i purchased it and see no reason someone to move it,also
every other Picture on the internet shows it in that location.
You can check for a bad connection by checking for resistance between that wire and the frame/ engine. should be zero resistance.
I doubt that this is your issue,
1976 Z50A PARAKEET YELLOW
1970 CT70  CANDY SAPPHIRE BLUE
1971 CT70H CANDY TOPAZ ORANGE
1972 CT70H CANDY EMERALD GREEN
1973 CL200 CANDY RIVIERA BLUE
1974 CB350F GLORY BLUE BLACK METALLIC
1973 CB350F FLAKE MATADOR RED
1975 CB360T LIGHT RUBY RED
1975 CB400F VARNISH BLUE
1975 CB550 FLAKE SUNRISE ORANGE
1976 CB750F CANDY ANTARES RED
Offline BenelliSEI
  • 1969 cb750
« Reply #22 on: April 04, 2024, 06:22:05 AM »
I’m betting your vendor has a supply problem. That battery sounds pooched too.
« Reply #23 on: April 04, 2024, 07:00:58 AM »
Ive purchased several Scorpion batteries over the years, never an issue.
Den - you have a 750 battery , right?   I'd try connecting that to your 550 to check starter, etc.  [I know it wont fit in the battery box, just connect the cables and secure it somehow. Or jump it with your car]
Offline BenelliSEI
  • 1969 cb750
« Reply #24 on: April 04, 2024, 07:50:05 AM »
Good idea, Steve.
