Author Topic: Starter issue or just bad battery...again..CB550  (Read 3492 times)
Offline denward17
Re: Starter issue or just bad battery...again..CB550
« Reply #50 on: April 04, 2024, 02:19:08 PM »
No visible deficiencies or smells.
Will try to take apart in the next day or so and respond.
Offline BenelliSEI
  • 1969 cb750
« Reply #51 on: April 04, 2024, 02:34:16 PM »
Den…..That terminal looks fine and what you describe sure sounds like the problem.
Around here we have a local guy that works out of his farm property. Nice little building where all he does are starter motor, generator and alternator rebuilds. Smelly shop, but he does outstanding work. Most of the repair shops in the area bring him “cores” by the basket load.
He usually has my stuff turned around in a day and only does what needs doing. Sniff around a bit and see if there are any shops like that in your area?
Offline denward17
« Reply #52 on: April 04, 2024, 03:19:20 PM »
Will check with a local electric auto shop tomorrow.  Good idea, Thanks John.
« Reply #53 on: April 04, 2024, 03:34:22 PM »
Is there any free play in the starter shaft, like from a worn bushing?
Offline denward17
« Reply #54 on: April 04, 2024, 04:22:24 PM »
There is no free play in the starter shaft in any direction.
Is it just worn out brushes?
Offline grcamna2
« Reply #55 on: April 04, 2024, 05:41:33 PM »
I hope to hear what you find when the starter is disassembled;make sure to mark the removable end covers with a small pointy punch,to keep them in the correct orientation when you reassemble it.
75' CB400F/'bunch o' parts'
« Reply #56 on: April 04, 2024, 08:13:00 PM »
Whenever I rebuild these engines I take the starter's covers (ends) off and clean out the pile of carbon that builds up from the brushes in there. It sometimes shorts out the (+) terminal to the case, which makes for an intermittent short. Then I replace the brushes, if they are too worn down. You can get the brushes from Honda or PartsNmore, among other places.
« Reply #57 on: April 04, 2024, 08:56:53 PM »
I have had a Toyota starter that cranked the engine slowly, making me think the battery was on it's last legs. I replaced the battery, and the starter still cranked the engine slowly, so I pulled the starter, which was not an easy job, and found the brushes were worn to a nub. I was able to get replacement brushes from a mom-and-pop automotive electric shop nearby, but they shut down a few years ago. :(
Rebuild kits are available for the 550 starter, and there are used complete starters for sale on ebay and amazon. You might also consider posting a wanted ad here to see if a member has a starter they can part with.  :)
Offline grcamna2
« Reply #58 on: April 04, 2024, 09:55:20 PM »
Bike owners abuse starters by cranking them non-stop,which overheats the internals & melts stuff..
I crank them in short bursts or 5-10 seconds max;if it doesn't start then the engine,etc. needs some help. I like electric & kick start bikes;having both on a bike is a real plus.
« Reply #59 on: April 04, 2024, 11:56:32 PM »
All 500, 550 four starters are the same
Offline Little_Phil
« Reply #60 on: April 05, 2024, 03:29:25 AM »
I bought a new battery in January for one of my 550s. Convectional Exide wet.
When you had a problem with the first battery I checked mine. 10.7V with the starter spinning. lights on. I do have a relay so that the full voltage available to the coils, thus bypassing some wiring for the ignition.
Offline denward17
« Reply #61 on: April 05, 2024, 06:34:36 AM »
There are alignment marks already on the body.....
Here are a few pics from taking the top off.
There is some dust from the brushes, as expected I assume.  Does the brushes need to be changed?
Do I need to completely open up the rest of the starter?
Offline grcamna2
« Reply #62 on: April 05, 2024, 08:04:28 AM »
This one looks like it's been opened already?  The brushes look fresh,but somehow,not quality/cheap?
Considering what you've been through so far.. if it was me,I would consider getting a known-good spare,used starter(not yet been opened)to see the difference in draw.
You might then compare the two in how they perform,brushes,etc.. or bring them to a quality starter rebuild/auto electric shop to have a trusted tradesman give you their understanding,imo.
« Last Edit: April 05, 2024, 08:08:26 AM by grcamna2 »
Offline denward17
« Reply #63 on: April 05, 2024, 08:33:02 AM »
Dug a little deeper.....
« Reply #64 on: April 05, 2024, 08:42:36 AM »
The armature looks like it has been rubbing on the field pieces; is the bushing in the end-cap worn? Also, the top brush lead in the first pic looks over-heated in one area. The end of the armature shaft looks over-heated as well. I would just get a new starter.
Offline denward17
« Reply #65 on: April 05, 2024, 09:19:35 AM »
I cleaned it up, put it back together and re-tried on the bike, same thing.
I was thinking of taking to a local starter shop this afternoon, or should I just bite the bullet and look for another starter?
« Reply #66 on: April 05, 2024, 09:22:26 AM »
I would just look for another starter.
« Reply #67 on: April 05, 2024, 09:23:04 AM »
Used starter, looking at that pic yours has been severly abused by a po
Offline denward17
« Reply #69 on: April 05, 2024, 10:10:18 AM »
Thanks Guys for the help in troubleshooting, much appreciated.
« Reply #70 on: April 05, 2024, 10:12:54 AM »
BTW, I would post a wanted ad here on the forums before resorting to feebay. ;)
Offline enwri
  • So that noise is normal?
« Reply #71 on: April 05, 2024, 10:51:26 AM »
It's just the little push in bush that has disintegrated, hook out what's left in the hole and measure it then the shaft then how deep.
you've got to be able to do better than this listing.., they're cheap.
https://www.ebay.com.au/itm/145155502411
Even if the shaft is a bit worn, as long as the armature can't hit the sides it'll last years.
had another look at the shaft,  maybe give it a bit of a polish too.
or just get a new one...
« Last Edit: April 05, 2024, 10:54:11 AM by enwri »
77 CB 750 k.. 29 years and counting.
91 TDM 850 (No.34) so comfy and soft
8? XJ 550 meh...
76 XL 350 Super Sport stump puller..
80 XR 200 idiot proof
75 MX 250 b dangerous
Online Mark1976
« Reply #72 on: April 05, 2024, 11:03:22 AM »
   That starter's trash, the armature be grounding out against the field coils, which causes excessive arcing (polling) and shows up as a slow turning starter, find an other starter.
Start with the end in mind...
Offline grcamna2
« Reply #73 on: April 05, 2024, 11:26:17 AM »
+1
Offline denward17
« Reply #74 on: April 05, 2024, 11:46:50 AM »
Got one ordered, a used piece from ebay, hopefully it will work.
