Author Topic: Priming a CB750A Oil Pump  (Read 1363 times)
Offline LiveeviL81
  • Turbomatic
« on: April 05, 2024, 08:25:49 PM »
Hey all,
As I am approaching first start this weekend, I remembered reading about priming the oil pump for the standard CB750's I attempted to follow the instructions from a different post, but outside of leaking oil all down the side of the engine, I didn't have a ton of luck. Is there another method to priming the CB750A's since they run a different oil pump system?
Currently planning to pour some oil down the main gallery with the pressure sensor, along with seeing some people hook up a shop vac to blow into the oil filter feed, but I'm hoping not to resort to that.
Is it possible to build pressure with the kickstarter, or should I just run the electric starter until my main gallery gauge shows pressure?
Kaleb
Young, Dumb, and Broke, hoping to fix 2 of those.
Offline BenelliSEI
  • 1969 cb750
Re: Priming a CB750A Oil Pump
« Reply #1 on: April 06, 2024, 05:33:17 AM »
Pull you spark plugs and spin it (in 10 second shots to keep the starter from overheating) long enough to fill the oil filter housing with oil. I usually get pressure in under a minute of cranking.
