Author Topic: Do you use a spoke torque wrench?  (Read 1511 times)
Offline Magpie
« on: April 08, 2024, 12:30:57 PM »
The spoke torque wrenches seem crazy expensive. Can anyone recommend a less expensive one? I know you get what you pay for but..............
Thanks, Ciiff.
Re: Do you use a spoke torque wrench?
« Reply #1 on: April 08, 2024, 01:44:42 PM »
Never used one
Offline Bodi
« Reply #2 on: April 08, 2024, 02:14:45 PM »
I just tension them by sound, should all ting about the same tone.
Offline Alan F.
« Reply #3 on: April 08, 2024, 02:26:26 PM »
I'm with Bodi.
I've seen mention of 3.75 - 4 ft/lbs or 45 - 48 in/lbs or  5.08 - 5.42nm
It might be interesting to check with a torque wrench and flat/straight screwdriver bit at the spoke nipple slot inside the rim next time I build a wheel, which should hopefully be soon just waiting on spokes now.
I think I bought the Harbor Freight 1/4" drive torque wrench when it was $8.99 a few years back, it goes down to 20 in/lbs.
« Last Edit: April 08, 2024, 02:31:52 PM by Alan F. »
« Reply #4 on: April 08, 2024, 02:46:14 PM »
like bryanj Ive never used one,they could be detrimental even?having equal tension on the spokes might run it out of true?to keep from egg shape some spokes may need more tension on them?
Offline Ichiban 4
  • "Ichi"
« Reply #5 on: April 08, 2024, 02:49:06 PM »
Thanks, Ciiff.
___________________________________________________________________________________________________________
Just chiming-in here..Back in the 60's thru 70's..when spoke/wire wheels were dominant on bikes..we just used our experience and 'feel'
for the tightness with our hands [using a plain 'spoke wrench']..and as others here have mentioned.  After a little experience and getting a feel for how tight the spokes should be [listening to the 'tone' of spoke..when 'plunked' also serves to judge how tight they are..again as previously mentioned]..the rest becomes pretty straight forward..I suggest.
As we all probably know here..any extensive spoke tightening should be done with tube and tire removed [so as not to puncture the tube inadvertently]..and on a truing stand.
I sometimes wonder if one of reasons that wire/spoke wheels became less prevalent..was due to the extra time and skill required of technicians
to 'build and true' them (?) Personally..I actually prefer a well-built wire wheel over the alternatives nowadays..but I'm also old school' on a lot of my preferences nowadays LOL
Cheers
Ichi
Al Summers
Present: '77 550K
Offline Magpie
« Reply #6 on: April 08, 2024, 06:37:17 PM »
Thanks guys. I think I'l go with the "ting"or "ping" method.  ;D Cliff.
« Reply #7 on: April 08, 2024, 08:42:48 PM »
A clean tone on all spokes ;)
Offline BenelliSEI
  • 1969 cb750
« Reply #8 on: April 09, 2024, 06:22:12 AM »
Cliff…. That works just fine. After about 100 km I usually pull every spoke another 1/4 turn to make sure. Any that feel looser get 1/2 turn.
Offline willbird
« Reply #9 on: April 09, 2024, 07:15:32 AM »
Thanks, Ciiff.
Cheers
Ichi
Even cars at one time had spoked wheels...my dad worked with a guy in the 70's who had a set on a caddy and wanted to trade them out for more modern wheels because his wife liked to hit curbs with them which required them to be re trued.
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #10 on: April 09, 2024, 07:54:55 AM »
I use one. I get them to a point that is close and evenly tight. Then I make finer adjustments by hand. My goal is to know that they are all at least at the lower end of the torque value so I can adjust up through the range to true the wheel. With steel wheels this sometimes requires getting some somewhat tighter than others. Have to remember that pulling a rim sideways or vertically will tighten or loosen the opposing spoke depending on direction.
1973 CB 750 K3
10/72 build Z1 Kawasaki
« Reply #11 on: April 09, 2024, 08:57:32 AM »
  This is a good discussion, I like them because we can all learn a little or at least hear that we might be on the right track. I did a wheel recently that got too tight, and I kept getting tighter trying to true it. I finally backed them all off and left it untouched for a couple days. When I went back to it later, it trued up fairly easily.
 I've been going from feel also and have wondered how to adapt a torque wrench for checking purposes. Wouldn't a crow's foot type tool add to the length of the wrench and change the readings a little?
Offline Alan F.
« Reply #12 on: April 09, 2024, 10:16:18 AM »
Don't forget 754 Frank's tip for 'setting' each spoke nipple to the rim with a brass drift before truing.
Offline M 750K6
« Reply #13 on: April 09, 2024, 10:37:49 AM »
It doesn't seem right, but if the crow's foot is at 90 degrees to the plane of the torque wrench, the torque values are unchanged. This is true of any extension pieces too. Keep to 90 degrees and the torque value is unchanged.
Offline newday777
« Reply #14 on: April 09, 2024, 03:56:37 PM »
As in hitting the nipple head with the drift to set it to fit it to the rim hole angle?
Stu
My current rides
Prior bikes....
Offline Bodi
« Reply #15 on: April 09, 2024, 07:19:42 PM »
Yes. To seat the spoke nut taper in the nipple. And a dab of grease or antiseize in the dimple makes truing and tensioning much easier.
Offline Alan F.
« Reply #16 on: April 10, 2024, 04:32:45 PM »
Nope, it wasn't interesting at all but I learned that I'm probably tightening spokes to approximately 2.5 ft/lbs.
The pain in the a$$ part was removing a few spokes to file off the burrs that I raised on the brass nipples...
Offline Bankerdanny
  • Endeavor to persevere
« Reply #17 on: April 12, 2024, 09:10:35 AM »
When I relaced the wheels on my 550F I just looked for a as little run out as I could manage and a consistent tone to the spoke when tapped with a screwdriver.
Offline M 750K6
« Reply #18 on: April 13, 2024, 03:14:55 AM »
I don't try to get the same note from each spoke. I've found, so long as I get the wheel true, all I then do is tighten any spokes that have a dull sound, until they ring. Never takes the wheel out of true and they run fine on the road..
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #19 on: April 13, 2024, 07:51:04 AM »
I'll dig mine out, the wrench has crows feet for different spokes and is set up with that in mind, it's specifically for spokes so it's calibrated accordingly.
1973 CB 750 K3
Offline Alan F.
« Reply #20 on: April 13, 2024, 12:25:18 PM »
Has anyone else ever laced a "straight pull" spoked wheel?
With no J-bend on the spokes lacing them up is a breeze because they all point in the correct direction when inserted into the hub, I was also surprised that removing any spoke was easy and nothing interfered.
Online jgger
« Reply #21 on: April 13, 2024, 02:09:25 PM »
I was checking out a BMW  adventure bike in a parking lot awhile ago, and it had 2 piece straight spokes. Instead of a nipple in the rim, it had a right/left threaded coupling in the muddle of the spoke.
Offline grcamna2
« Reply #22 on: April 13, 2024, 03:19:55 PM »
Thanks, Ciiff.
Cheers
Ichi
Truing the wheel 'round' (no up & down 'hop')and 'straight' (no side to side runout)with the spokes all evenly tensioned is most important.
When the wheel is nicely trued,all the way a 'round'  :) ,then it's good to go all around to each spoke while it's on the stand to give a 1/4 turn to each spoke for a full 360 revolution;this can be repeated(one revolution/360 degrees is mostly sufficient)a couple full 360 revolutions of the wheel,if needed.. and will draw All the spokes much tighter to their final torque.
I mention this as a time for final torque;you'll 'feel' each one of similar torque.
I need to mention that it helps to put a little motor(etc.)oil upon assembly of the spokes into the wheel on the inner flange of each spoke nipple where it contacts the hole in the rim(or just a spot of grease)and a bit of oil on the threads of each spoke;this will help finish torque.
Cliff,which style spoke wrench are you employing ?
« Last Edit: April 13, 2024, 03:31:05 PM by grcamna2 »
Offline Magpie
« Reply #23 on: April 16, 2024, 12:59:43 PM »
These 2.
This rim is so out of whack it's trying my patience.
Offline grcamna2
« Reply #24 on: April 16, 2024, 01:14:22 PM »
Those two wrenches look good for the job & look long enough to apply decent torque to each spoke.
I have the same truing stand..
The rim is OEM? where did you source the rim ?
I ordered a rim for a 'good price' online and had a similar issue;the rim didn't 'true' when I applied even tension to each spoke.
 I found the new rim was somehow 'out' even when new;it could have gotten slightly bent during loading/transit from the country of origin from being in a container & the load inside the container shifted,at some point?  I don't know.
I ended up working with it until I found which spokes I could tighten that gave a good result;the majority of the spokes held that rim 'in true'..
There are a few spokes/positions on that rim which must have been the position where the rim was slightly damaged/bent 'just enough' to keep it from achieving a 100% True.
I then worked all the spokes while keeping in mind the slight 'inherent twist' to that rim and adjusted some of 'those spokes' areas on that rim with a bit less tension on one side.. and tightened the other ones around them(some tighter)to compensate for the slight rim deformity.
I first get the rim good side to side,then I work to see if it has any up and down 'hop' to it:I then go after truing it 'Round' so the rim will spin 360 degrees Round w/o any Up & Down 'hop' in it.
I know there's a better word than 'hop'.. I usually call it Up and Down 'hop',rather than 'side to side' runout.
I would have rather just returned the defective/damaged rim and ordered better $ rims from Buchanans,etc.
A rim like that will eat-up alot of my time and use up patience,never allowing me a 100% TRUE result,but I can work with it to get it as close as I can to tolerate it..
Reminds me of certain negative people that I've met in my life: Taker's   >:(
No matter how much time I spend with them,it's a poor result later,for various reasons.  :o ::)
« Last Edit: April 17, 2024, 10:08:01 AM by grcamna2 »
