Author Topic: K8 750 and k3 750 wheel a direct swap?  (Read 370 times)
Offline 78whiteorbs
« on: April 10, 2024, 01:58:45 PM »
Is a K8 750 and k3 750 wheel a direct swap?
Have a 78 and a 73 . My 73 750 tires lookin suspect so until I replace and install could I swap my 78 750 over. I'm thinking yes.
While I'm asking I have a 16 harley rim in the back of my 73 and don't particularly  care for the anesthetics. Will the 78 rear swap over too? It's stock.
Offline Pbeattie89
Re: K8 750 and k3 750 wheel a direct swap?
« Reply #1 on: April 10, 2024, 02:21:29 PM »
From what I understand, the later k7 and k8 have a different offset to the chain. That may cause some issues. Someone with more experience will likley chime in soon.
Sent from my SM-G991W using Tapatalk
« Reply #2 on: April 10, 2024, 03:00:25 PM »
You just have to keep the sprocket carrier with the bike....hubs are the same but the sprocket carriers are different.
Also, although your 73 apparently had a 16" hog wheel, it is supposed to have an 18" rear stock.  The 78 has a 17".
Offline 78whiteorbs
« Reply #3 on: April 10, 2024, 04:36:01 PM »
Thanks on the rear wheel info.
Can I put my front 78 wheel on my front 73?
Offline Tracksnblades1
« Reply #4 on: April 10, 2024, 05:46:08 PM »
The 78k had 630 chain too…and a 10mm longer output shaft for its double roller output bearing upgrade..😁
Front sprocket used a single bolt for retention instead of the two bolts with the interference spline plate..
« Last Edit: April 10, 2024, 05:52:16 PM by Tracksnblades1 »
Age Quod Agis
Online Alan F.
« Reply #5 on: April 10, 2024, 06:26:12 PM »
Yes it'll fit just the same even though the hub will be a different design. Brake disc should line right up as well, speedometer drive will be right at home too.
Offline 78whiteorbs
« Reply #6 on: April 10, 2024, 06:51:32 PM »
Excellent thanks
