Author Topic: Spark advancer shaft  (Read 472 times)
Offline jwurbel
« on: April 15, 2024, 10:40:01 AM »
Had 200-400 rpm flutter on tach.  Used dial gauge per Hondaman and got down to maybe 100-150.  Don’t think I can get much better without replacement.   Should I just let it go and be happy or do the replacement?
Re: Spark advancer shaft
« Reply #1 on: April 15, 2024, 11:24:22 AM »
 If you haven't yet, check the advancer springs to be sure the timing isn't fluttering there. My F1's weights were flopping around at idle.
Offline jwurbel
« Reply #2 on: April 15, 2024, 11:28:27 AM »
Did and they are not.  Good thought however
Offline newday777
« Reply #3 on: April 15, 2024, 11:42:34 AM »
You say you used a dial gauge per Hondaman.
Did you use a dial indicator like this and to what did you get it to? Less than .002"?
« Last Edit: April 15, 2024, 11:49:13 AM by newday777 »
Stu
My current rides
Prior bikes....
Offline newday777
« Reply #4 on: April 15, 2024, 11:53:28 AM »
From Hondaman's CB750 Book
Stu
My current rides
Prior bikes....
Offline jwurbel
« Reply #5 on: April 15, 2024, 01:20:19 PM »
Like that and got the dial I thought to zero.  No movement on the dial pointer.  Measured more than once.  But it was my first time ever using one.  So it could have been off, but I don’t think so.
Offline newday777
« Reply #6 on: April 15, 2024, 05:34:18 PM »
If you didn't start by pushing the indicator so it was at least. 020 and the turn the face to zero so there was pressure on the indicator to see if there was movement then you may need to redo it again if you have Flux idle.
Stu
My current rides
Prior bikes....
Offline jwurbel
« Reply #7 on: April 16, 2024, 06:35:52 AM »
I didn’t.  Kept it at zero, looking for any movement.  Probably will have it do again
« Reply #8 on: April 16, 2024, 06:41:02 AM »
Zero or not, most important within the working range so it is not close to max or opposite pressed almost into bottom.
If needle does not move at all or only vibrate, very good ;D
This thread reminds me to measure my K2's shaft. It might wobble a little....
« Last Edit: April 16, 2024, 06:43:02 AM by PeWe »
Offline newday777
« Reply #9 on: April 16, 2024, 06:52:18 AM »
If you set it at zero at the high point you won't know how much it is off by to straighten it as the gauge won't reach out to the furthest point.
Stu
My current rides
Prior bikes....
« Reply #10 on: April 16, 2024, 07:00:13 AM »
If running Dyna-S or similar not that sensitive as points if shaft  wobbles.
Offline jwurbel
« Reply #11 on: April 16, 2024, 10:51:06 AM »
Actually using Hondaman’s transistor ignition module
Offline newday777
« Reply #12 on: April 16, 2024, 11:31:34 AM »
Stu
My current rides
Prior bikes....
