Author Topic: CB550 Fork Bolt Stud Replacement  (Read 466 times)
Offline TheHulk
« on: April 28, 2024, 08:17:47 PM »
My rear left Fork Bolt Stud is stripped. OEM number is #92700-08050-30, ordered two from ebay.
I have seen instructions and videos online for removing the tricky center bolt in each fork leg, but nothing on how to replace these.
Has anyone done this, or could point me in the right direction?
Part #24 in the diagram linked below for reference.
https://www.partzilla.com/catalog/honda/motorcycle/1978/cb550k-a-550-four-k/front-fork
Re: CB550 Fork Bolt Stud Replacement
« Reply #1 on: April 29, 2024, 12:08:29 AM »
Normaly double nut but if old ones stripped vice grips
Online newday777
« Reply #2 on: April 29, 2024, 01:02:52 AM »
Like Bryan, lock on vice grips on the stud, heat the fork leg around the stud with a good heat gun to expand the aluminum(the heat also releases any locktite if there was any was used on the stud), then pull on the vise grips to unscrew. (Remember lefty loosey) Reset the vise grips as needed to finish unscrewing. Having the fork leg in a vise(with soft jaws to protect the aluminum) helps to unscrew the stud too.
« Last Edit: April 29, 2024, 01:08:18 AM by newday777 »
Stu
My current rides
Prior bikes....
Offline TheHulk
« Reply #3 on: April 29, 2024, 10:25:29 AM »
Awesome. Sounds pretty straight forward. Thanks!
Offline Ozzybud
  • Honda Lover
  • Honda Lover
« Reply #4 on: April 29, 2024, 11:39:20 AM »
+1 to Heat and Vise Grips.
Ozzybud
1976 Z50A YELLOW
1970 CT70 BLUE
1971 CT70H ORANGE
1972 CT70H GREEN
1973 CL200 BLUE
1973 CB350F RED
1975 CB360T RED
1975 CB400F BLUE
1975 CB550 ORANGE
1976 CB750F RED
