Author Topic: I need ignition with built in advance (1995 zx600r/gpx600r)  (Read 636 times)
Offline MJL
  • Don't listen to me, I'm no
« on: April 29, 2024, 05:46:02 AM »
My Kawasaki 600r has electronic ignition. It is a pair of hall effect sensors that feed an ignitor. The ignitor handles all of the timing advance. New ones are not available,  and I hesitate buying used. I've tried a few things to replace it with something new, like this https://s3.amazonaws.com/gpzweb/Ignition/GPZgmHEImod.html which worked, but there is no spark advance, I took the Power-Arc ignition off my 750 and adapted it to the Kaw and it worked, but it doesn't fit under the cover. Last night I bolted on a spare Honda cb750 points plate, which fit, but I think the hole in the end of the crankshaft is in the wrong spot, plus it's too tall to fit under the timing cover anyway.
So, I am looking for something that would have spark advance and allow use of the timing cover. Maybe a pair of those cheap little minibike CDI boxes?
Offline Leino
  • Not much of an
  • in drag racing since 2005
Re: I need ignition with built in advance (1995 zx600r/gpx600r)
« Reply #1 on: April 29, 2024, 11:47:31 AM »
If you don't mind doing a little wiring work, Ignitech.
Offline MJL
« Reply #2 on: April 29, 2024, 03:56:24 PM »
I'll look into that.
Right now I've got the gm hei modules hooked up, and it's running on three cylinders, so I'm going to have to pull the carbs. That's such a pain on this bike.
