Author Topic: Struggling with setting timing on CB750K6  (Read 338 times)
Offline God of Thunder
  • Trained to reign as the one!
« on: May 01, 2024, 12:00:56 PM »
hi everyone! I had to adjust the points gap on my CB750K6. With doing this - I read I needed to reset the timing. I watched a video from "Andy Mechanic" on YouTube and this looked fairly simple. However - no matter how many times I do it just like the video, my test light doesn't light up on the F mark. The bike is trying to start, but can't quite do it - and I think its due to my timing. This seems like a fairly simple process that I'm struggling with. Does anyone have any suggestions? Heck I'd pay someone to FaceTime me to help me get it set!
1970 CB750K1
1976 CB750K6
Offline M 750K6
Re: Struggling with setting timing on CB750K6
« Reply #1 on: May 01, 2024, 02:56:48 PM »
From experience, if your points gap isn't set correctly, it can require more movement of the points plate than is available, particularly on 2 and 3. I'd double check the points gaps first.
« Reply #2 on: May 01, 2024, 04:09:43 PM »
When you move the points plate the points gap always alters, it is a jugglig  job to get gap at 0.35mm(14 thou) AND timing on Fmark using static bulb.
NOTE
DO NOT TURN THE CRANK WITH THE BIG NUT ON THE ADVANCER if you have you may have bent the advncer shaft
« Reply #3 on: May 01, 2024, 07:17:23 PM »
NOTE
What he ^^^ said...
The gap should be about 0.014" with the points cam fully opening the points. For the 1-4 points this means you want to see the 2-3 timing marks in the little window, and vice-versa for the 2-3 side's points.
Turn the engine with either the kickstarter or the electric start ('bump', but harder to do) with the sparkplugs out. If you turn the big nut by the points backward (CCW) just once, it bends the points shaft. Then you'll chase your tail trying to get the timing right: it will wobble when the engine runs, making the timing marks jump all over under a timing light - and that spark is actually doing that!
If your points are Daiichi: you may not be able to get them to set up with the normal 0.014" gap on both sets, or sometimes even with 0.016" gaps, which will cause other timing issues. To do the 0.014" gaps requires bending the ground arm(s) slightly in toward the moving arm(s), about 0.002" to 0.004" in most cases. This is because the geometry is 'off' a little bit on the Daiichi parts.
« Reply #4 on: May 02, 2024, 03:45:54 AM »
More reading good to know
https://www.motorcycleproject.com/text/sohcign.html
(If hammer the bosses to tighten the plate. Hammer straight on with a sharp metal hammer. Not from side with risk to snap a boss. No problem if it swell on both sides )
Adjusting ignition.
http://www.hondachopper.com/garage/carb_info/timing/timing1.html
