Author Topic: 400F starter motor troubleshooting  (Read 398 times)
Offline jakec
« on: May 18, 2024, 12:20:24 PM »
My 400 starter motor stopped working. I have already rebuilt the switch with the 3D printed housing, and it's working (turning off the headlight when you press the button). All my other connections are clean and connected too (yellow/red and green/red). I traced them all over the bike and checked them. I also bench tested the motor out of the bike and it's working. Finally, I just jumped the green/red wire from the solenoid directly to the frame grounding point for the battery. Still nothing, and the solenoid isn't making any noises either. Does this mean the solenoid is bad? I can't think of anything else.
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Offline jakec
Re: 400F starter motor troubleshooting
« Reply #1 on: May 18, 2024, 12:21:44 PM »
I should say the bike runs, I just have to kick it. Oh, and I have jumped the posts on the solenoid and it did turn over. But like I was saying, all the yellow/red wires are connected, and that would be the likely culprit right..
« Last Edit: May 18, 2024, 12:30:49 PM by jakec »
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
« Reply #2 on: May 18, 2024, 01:01:22 PM »
Try testing the solenoid by putting both small wires one to each side of battery, if no click solenoid duff if it clicks wiring duff
Offline jakec
« Reply #3 on: May 18, 2024, 01:38:00 PM »
Ok I just left the green/red wire plugged in normally and jumped the yellow/red straight to the battery and it turned over. So that means the yellow/red is causing a problem somewhere, if I'm following along
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Offline jakec
« Reply #4 on: May 18, 2024, 01:44:38 PM »
There are only the two locations where the yellow/red has a connection, right next to the solenoid and then under the tank where the end of the handlebar switch leads are. Both are clean and connected. And I have the switch pod opened up and I'm looking down at the switch housing and it looks perfect..
I jumped the wire in that area to the battery and it turned over (eliminating switch pod). So I guess it is that switch. The button has already been rebuilt with the 3D printed housing, and it worked for a while before it stopped working.
« Last Edit: May 18, 2024, 01:49:39 PM by jakec »
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Offline jakec
« Reply #5 on: May 18, 2024, 01:59:24 PM »
I took the switch apart and nothing looks wrong with it. And it was still doing its function of turning the headlight off. So I guess there must be a break in the wiring somewhere, maybe inside the handlebars. But its all still in its factory black sheathing.
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
« Reply #6 on: May 18, 2024, 02:00:22 PM »
either the switch is corroded or the wire broken between switch and tank
Offline jakec
« Reply #7 on: May 18, 2024, 02:16:21 PM »
Yeah the switch is totally perfect inside and out, so it must be a broken wire. Kinda considering putting a switch somewhere else maybe, idk. I don't want to disturb the black sheathing tracking it down. Not to mention taking apart the handlebars and pulling the wires.
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
« Reply #8 on: May 18, 2024, 05:08:12 PM »
Test for power with switch pushed at either end of the wire
